EBM40DSSH
EBM40DSSH
    SULLINS
    CONNEDGEDUALFMALE80POS0.156
EBM40DSSH 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2714 INITIAL RELEASE 1/3/2013 JH F F E D E E B A 2X .075 1.91 SEE NOTE 13 .125 3.18 D +.005 +0.13 .370 9.40 - .015 - 0.38 D C .180 4.57 .030 0.77 A .550 13.97 .250 6.35 A .156 3.96 C .250±.025 6.35±0.64 .200 5.08 ROW SPACING .025 0.64 FITS .040[1.02] MIN HOLE _ _M_ _DSSH C SECTION A-A CONTACT MARKINGS (LETTERS G, I, O, & Q NOT USED) B A NOTES: CONTACT ID 1. INSULATOR MATERIAL: SEE PART NUMBER CODING SCALE 4:1 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 950 VAC MINIMUM AT SEA LEVEL 8. CURRENT RATING: 3 AMP 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 8 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB. 16. MODIFICATION: NO STANDOFFS. RoHS COMPLIANT Pb 8 7 6 5 4 SIZE 06-25 & 30 1 2 ... 23 24 ... 29 30 A B ... A B ... H J SIZE 28 & 31 1 2 ... 23 24 ... 30 31 A B ... A B ... J K SIZE 36 - 43 A B ... A B ... X Y 1 2 ... 23 24 ... 42 43 SIZE 47 & 50 1 3 ... 97 99 2 4 ... 98 100 DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: .XX= .XXX= .XXXX= ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 B CUSTOMER COPY DATE NAME 1/3/2013 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC, HP PART NUMBER SIZE C _ _M_ _DSS_-(S38, S81, S328) CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C12137 SHEET 1 OF 3 1 REV A FILE NAME: C12137, _ _M_ _DSS_-OMIT, S38, S81, S328 8 7 4 5 6 1 2 3 F F E E D D 2X #4-40 THREADED INSERT D 2X .125 3.18 C .245 6.22 _ _M_ _DSSS _ _M_ _DSSI A C 2X .126 3.20 L±.015[0.38] (L= DIM 'A' + .252[6.40] B B C _ _M_ _DSSB CUSTOMER COPY DRAWN _ _M_ _DSSN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 1/3/2013 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC, HP PART NUMBER SIZE C _ _M_ _DSS_-(S38, S81, S328) CAGE CODE 54453 SCALE: 1.2:1 2 DWG. NO. C12137 SHEET 2 OF 3 1 REV A FILE NAME: C12137, _ _M_ _DSS_-OMIT, S38, S81, S328 8 7 4 5 6 1 2 3 F F E E D D C C B B CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 1/3/2013 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC, HP PART NUMBER SIZE C _ _M_ _DSS_-(S38, S81, S328) CAGE CODE 54453 SCALE: 1.5:1 2 DWG. NO. C12137 SHEET 3 OF 3 1 REV A FILE NAME: C12137, _ _M_ _DSS_-OMIT, S38, S81, S328
EBM40DSSH 价格&库存
很抱歉,暂时无法提供与“EBM40DSSH”相匹配的价格&库存,您可以联系我们找货
