243-002-542-101
243-002-542-101
    插件,P=5.08mm
243-002-542-101 数据手册
243 SERIES Card Edge Connectors 0.200” (5.08mm) Pitch Features: • • • • • • • • 0.200” (5.08mm) Contact Spacing x 0.200” (5.08mm) row spacing Accepts 0.062” (1.57mm) nominal thickness P.C. board High profile insulator body, 0.656” (16.66mm) Insulator bushings press into metal backplane Modular design permits any connector length assembly Contact termination 0.045” (1.14mm) square wire wrap Accepts between contact and in-contact polarizing keys RoHS Compliant Specifications: Insulator Material UL 94V-0 Thermoplastic Polyester, White Color Contact Material Copper Alloy Contact Plating Gold Plating Over Nickel for Entire Contact Current Rating 5 amps Contact Resistance 10 milliohms maximum Dielectric Withstanding Voltage 1800 V AC rms at sea level between adjacent contacts Insulation Resistance 5000 megaohms minimum Operating Temperature -40°C to +105°C Insertion Force 16 oz (4.45 N) maximum per contact pair when tested with .070" (1.78mm) thick gauge Withdrawal Force 1 oz (0.28 N) minimum per contact pair when tested with .054" (1.37mm) thick gauge Example Part Number: 243-006-542-201 Series Total Number of Contacts Contact Code Contact Rows Total Number of Contacts: Contact Rows: 002 or 003 Single Row 004 or 006 Dual Row Contact Code: Tail Description: Tail Size: Tail Length “G”: 542 Wire Hole .045 (1.14) Sqaure .650 (16.51) Contact Rows: Description: Series: 101 Single Row 243 201 Dual Row www.edac.net customerservice@edac.net
243-002-542-101 价格&库存
很抱歉,暂时无法提供与“243-002-542-101”相匹配的价格&库存,您可以联系我们找货
