TSW-103-08-F-D-RA
TSW-103-08-F-D-RA
    SAMTEC(申泰)
    弯插,P=2.54mm
    2X6P 间距:2.54MM 方针 弯插
TSW-103-08-F-D-RA 数据手册
THROUGH-HOLE .025" SQ POST HEADER (2.54 mm) .100" PITCH • TSW/HTSW SERIES TSW/HTSW - SERIES Board Mates: SSW, SSQ, SSM, ESW, ESQ, BCS, BSW, CES, SLW Cable Mates: IDSD, IDSS = Standard Strip SPECIFICATIONS = Hi-Temp Strip Insulator Material: TSW: PBT HTSW: Natural LCP Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Voltage Rating: 550 VAC mated with SSW; 500 VAC mated with BCS; 515 VAC mated with ESQ; 450 VAC -RA/-RE mated with BCS or SSM; 400 VAC mated with CES Lead–Free Solderable: HTSW: Yes TSW: No, Lead Wave Only - PIN CENTERS TSW –1 –2 02 thru 25 = .200" (5.08 mm) Center Version (2.54) .100 x No. of Positions A (2.48) .098 (2.54) .100 C –D (5.08) .200 (5.02) .198 C –T (7.56) .298 (7.62) .300 C –Q 2 POSITIONS POWERED (7.56) .298 (7.62) .300 TSW ALSO AVAILABLE C HTSW B Straight Pin Versions Other Platings (MOQ Required) LEAD STYLE STRAIGHT PIN VERSIONS A B C LEAD STYLE STRAIGHT PIN VERSIONS A *–05 (8.51) .335 (3.30) .130 (2.67) .105 *–19 (26.16) 1.030 *– 06 (7.62) .300 (2.41) .095 (2.67) .105 *– 20 (31.24) 1.230 B (2.79) .110 *– 07 (10.92) .430 (2.54) .100 *– 21 (36.32) 1.430 (2.79) .110 *– 08 (13.46) .530 (5.08) .200 *– 22 (16.00) .630 (7.62) .300 – 09 (18.54) .730 (10.16) .400 *– 23 (11.30) .445 –10 (21.08) .830 (12.70) .500 *– 24 (12.15) .480 –11 (23.62) .930 (15.24) .600 *– 25 (16.00) .630 –12 (26.16) 1.030 (17.78) .700 ▲ – 26 (11.58) .456 (3.20) .126 –13 (31.24) 1.230 (22.86) .900 – 27 (33.78) 1.330 (25.40) 1.000 –14 (13.46) .530 – 28 (28.70) 1.130 (20.32) .800 *–15 *–16 F-221 (Rev 25MAY22) B A 5.2 A 5.7 A 5.2 A 6.3 A 5.2 A 4.6 A 4.3 A Note: Some lengths, styles and options are non-standard, non-returnable. B A ESW SSW SLW SSQ SSM BCS SNT Elevated Right-angle option Shunts B A CURRENT RATING (PER PIN) TSW mated with OTHER SOLUTIONS Specify LEAD STYLE from chart = .100" (2.54 mm) Center Version = .200" (5.08 mm) Centers, (Every other position filled) –S LEAD STYLE 01 thru 50 = .100" (2.54 mm) Centers, (All positions filled) HTSW - NO. PINS PER ROW (18.54) .730 *–17 (21.08) .830 *–18 (23.62) .930 (2.79) .110 (7.87) .310 (2.79) .110 (5.84) .230 (8.13) .320 (2.92) .115 (5.33) .210 (13.21) .520 – 29 (33.78) 1.330 (23.11) .910 (8.13) .320 – 30 (28.70) 1.130 (18.03) .710 C (20.83) .820 (25.91) 1.020 (30.99) 1.220 (5.84) .230 (6.73) .265 (8.13) .320 (5.84) .230 (8.13) .320 (15.74) .620 +– 41 (9.27) .365 (0.89) .035 (5.84) .230 (18.29) .720 +– 42 (11.94) .470 (1.27) .050 (8.13) .320 * Available with –LL (Locking Lead) Option Specify -07 for best mate with IDXX Series IDC Cable + Style –41 & –42 available with HTSW only. ▲ Except: Style –26 (0.46) .018 DIA Tail samtec.com?TSW or samtec.com?HTSW Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. - - - PLATING OPTION –F – RA or –RE = Single Row –L = Right-angle –D = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –NA = Double Row –G = Right-angle (Using straight body for coplanar mating with SSW-RA series) –T = 10 µ" (0.25 µm) Gold on post, Gold flash on balance = Triple Row –T –Q = Matte Tin –LL = Locking Lead See charts for available styles. Not available with single row 1 or 2 positions. Recommended hole size (1.02 mm ± 0.03 mm) .040" ± .001) = Double Row (5.08 mm).200"row space C (2.54) .100 x No. of Positions –S OTHER OPTION –S = Gold flash on post, Matte Tin on tail (3.02) .119 - ROW OPTION D –LC (3.09) .122 = Locking Clip (Styles –08 thru –13 & –22 only) (Requires 4 pin minimum) (Not available with T, –Q, –RA or–RE) E C –D –LA = –RA Option with –LL Option (6.10) .240 (5.56) .219 –“XXX” = Polarized Position E C –T (8.12) .320 (8.10) .319 E C –Q (8.12) .320 RIGHT-ANGLE VERSIONS (8.10) .319 TSW HTSW -RA LEAD STYLE E D – RA (1.52) .060 – RE (4.06) .160 RIGHT-ANGLE VERSIONS -RE LEAD STYLE – 09 –10 –11 –12 –13 –16 – 21 – 22 – 27 – 28 C – 08 Right-Angle Versions LEAD STYLE SINGLE (–S) C (5.84) .230 (8.13) .320 (5.84) .230 SINGLE E (4.83) .190 (7.37) .290 (9.91) .390 (12.45) .490 (17.53) .690 (2.54) .100 (22.61) .890 (2.29) .090 (20.07) .790 (14.99) .590 E (2.29) .090 DOUBLE (–D) TRIPLE (–T & –Q) E E (2.29) .090 (2.29) .090 – 09 (7.37) .290 (7.37) .290 (7.37) .290 –10 (9.91) .390 (9.91) .390 (9.91) .390 –11 (5.84) .230 –12 –13 *–16 – 21 *– 22 *– 25 – 27 – 28 – 29 (8.13) .320 (5.84) .230 (8.13) .320 (5.84) .230 (8.13) .320 (12.45) .490 (12.45) .490 (12.45) .490 (14.99) .590 (14.99) .590 (14.99) .590 (20.07) .790 (20.07) .790 N/A (5.08) .200 (5.08) .200 (5.08) .200 (25.15) .990 N/A N/A (4.83) .190 (4.83) .190 (4.83) .190 (2.54) .100 (2.54) .100 (2.54) .100 (22.61) .890 N/A (17.53) .690 (17.53) .690 (20.32) .800 N/A N/A – 30 (15.24) .600 (15.24) .600 * Available with –LA (Locking Lead) Option samtec.com?TSW or samtec.com?HTSW F-221 (Rev 25MAY22) Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
TSW-103-08-F-D-RA
物料型号:TSW/HTSW系列,包括不同引脚中心和引脚排列的版本。
器件简介:这些是通孔方形销头,具有2.54毫米的间距和1.27毫米的间距,适用于多种不同的电路板连接需求。
引脚分配:文档列出了不同系列的引脚中心和引脚排列,例如TSW和HTSW系列,以及它们的不同版本,如-1和-2中心版本。
参数特性:包括绝缘材料(PBT和天然LCP)、端子材料(磷青铜)、镀层(金或锡覆盖50微米镍)、操作温度范围(-55°C至+125°C或+105°C)、电压等级(与不同连接器配合时的不同值)和是否可焊(HTSW可以,TSW不可以,仅限铅波)。
功能详解:文档提供了不同连接器配合时的电流额定值,例如与ESW、SSW、SLW、SSQ、SSM和BCS配合时的电流值。
应用信息:文档提到了直销版本和其他镀层选项,以及提升直角选项和分流器等其他解决方案。
封装信息:提供了不同引脚版本的尺寸和形状,以及推荐的孔径。
TSW-103-08-F-D-RA 价格&库存
很抱歉,暂时无法提供与“TSW-103-08-F-D-RA”相匹配的价格&库存,您可以联系我们找货
TSW-103-08-F-D-RA
  • 1+4.662681+0.60601
  • 50+3.8821650+0.50457
  • 100+3.21321100+0.41762
  • 500+2.66738500+0.34668
  • 1000+2.464911000+0.32037
TSW-103-08-F-D-RA
    • 1+3.86640
    • 10+3.74760
    • 30+3.66120
    库存:18
