A3B-16PA-2DS(71)
A3B-16PA-2DS(71)
    HRS(广濑)
    CONN 2MM HOUSING 16POS DUAL
A3B-16PA-2DS(71) 数据手册
2mm Pitch Miniature Connector A3 • A4 Series ■Features 1. Miniature Type and High Density Mounting These connectors are designed in a miniature and light weight product, and mounted in the high density. The crimping case is structured in the 2mm pitch grid, so that connectors can be arranged for use. Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2. Variation in Number of Contacts In addition to the dip type, SMT and crimping types are available with broad variations. 3. Stacking Variation When the connector is used for board to board, set 6mm between boards in conjunction with the pin header A3B, or 5.1mm between boards in conjunction with the pin header A3C. ■Product Specifications Rating Current rating 1A Voltage rating 200V AC Item Operating Temperature Range –55 to +85ç (Note 1) Storage Temperature Range –10 to +60ç (Note 2) Operating Moisture Range 40 to 80% Storage Humidity Range Specification 40 to 70% (Note 2) Condition 1. Insulation Resistance 1000MΩ min. 500V DC 2. Withstanding voltage No flashover or insulation breakdown. 3. Contact Resistance 15mΩ max 650V AC/1 minute 4. Vibration No electrical discontinuity of 10μs or more 5. Humidity (Steady state) Insulation resistance : 1000MΩ min. Frequency : 10 to 55Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions. 6. Humidity resistance No damage, cracks, or parts looseness. (–65ç : 30 minutes ➝ 15 to 35ç : 5 minutes max. (125ç : 30 minutes ➝ 15 to 35ç : 5 minutes max.) 5 cycles 7. Operating Life Contact resistance : 20mΩ max. 100 cycles 8. Resistance to Soldering heat No deformation of components affecting performance. (Steady state) 0.1A 96 hours at temperature of 40ç and humidity of 90% to 95% Solder bath : 260ç for 10 seconds Manual soldering : DIP : 350ç for 3 seconds SMT : 360ç for 5 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3 : Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Applications VTR, vehicle telephones, and other various kinds of electronic equipment ■Materials / Finish Part Insulator Polyamid Receptacle (Through hole) PBT Pin header (SMT) Finish Light brown Crimping socket PBT Black Pin header Brass Receptacle Crimping contact Phosphor bronze Selective gold plated Note : Slight variations in color of the plastic compounds do not affect form ,fit or function of the connector. C10 Remarks Black PPS (Note) Receptacle (SMT) Contact Material Pin header (Through hole) UL94V-0 --------------- A3 • A4 Series●2mm Pitch Miniature Connector ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ● Pin Header (DIP type) A3B - 12 P - 2 DS Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 2 3 4 1 Series Name: A3B : double row A4B : single row 5 A3C : double row (low profile product) 2 Number of contacts : Double row...4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28, 30, 32, 44, 40, 50 (44 and 50 contacts correspond to the right angle type only. Straight angle type corresponds to the A3C type.) Single row... 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16 3 P, PA: Pin header 4 Contact pitch : 2mm 5 Contact type DS : Right angle type DSA : Straight type ● Receptacle (DIP type) A3 - 44 D - 2 DS 1 2 3 4 1 Series Name : A3 : double row A3C : double row 5 A3D : double row (for FFC, FFC) (Note) 2 Number of contacts : 3 : 44, 50 3C, 3D : 4, 6, 8, 10, 12, 14, 16, 18, 20, 24, 28, 32, 50 3 DA : Receptacle 4 Contact pitch : 2mm 5 Contact type DS : Right angle type DSA : Straight type (lead length : 3mm) DSC : Straight type (lead length : 2mm) DSE : Straight type (lead length : 1.27mm) Note : A standoff has been added to the center portion of the connector to provide stable mounting. ● Crimping Socket A3B - 44 D - 2 C 1 2 3 4 5 1 Series Name : A3B : double row 2 Number of contacts : Double row...4, 6, 8, 10, 12, 14, 18, 20, 24, 26, 28, 44 3 Contact alignment : D : double row 4 Contact pitch : 2mm 5 Connection type : C : crimping A4B : single row Single row... 2, 3, 4, 5, 6, 7, 8, 9, 10, 12, 15, 16, 18 S : single row C11 A3 • A4 Series●2mm Pitch Miniature Connector ●Crimping Contact A 3B - 2630 SCFC 1 2 3 4 1 Series Name : A 2 Series No. : 3B 3 Applicable cable size 2630 : 26 to 30 AWG 3236 : 32 to 36 AWG 4 Packaging type SCFC : Reel Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. SCC : Bag C12 ● Pin Header (SMT type) A 3 A - 44 P A - 2 SV 1 2 3 4 5 6 7 8 1 2 Series Name : A 3 Positioning Boss : A : With boss Series No. : 3 No symbol : Without boss 4 Number of contacts : 4, 6, 8, 10, 12, 14, 16, 18, 20, 24, 28, 30, 32, 44, 40, 50 5 P : Pin header 6 A : Selective gold plating 7 Contact pitch : 2mm 8 Contact type SV : Board virtical type ● Receptacle (SMT type) A 3 A - 32 D A - 2 SV 1 2 3 4 5 6 7 8 1 2 Series Name : A 3 Positioning Boss : A : With boss Series No. : 3 No symbol : Without boss 4 Number of contacts : 4, 6, 8, 10, 12, 14, 16, 18, 20, 24, 28, 30, 32 5 D : Receptacle 6 A : Selective gold plating 7 Contact pitch : 2mm 8 Contact type SV : Virtical type A3 • A4 Series●2mm Pitch Miniature Connector ■Pin Header Part No. A3B-04PA-2DSA(51) A3B-06PA-2DSA(51) A3B-08PA-2DSA(51) A3B-10PA-2DSA(51) A3B-12PA-2DSA(51) A3B-14PA-2DSA(51) A3B-16PA-2DSA(51) A3B-18PA-2DSA(51) A3B-20PA-2DSA(51) A3B-22PA-2DSA(51) A3B-24PA-2DSA(51) A3B-26PA-2DSA(51) A3B-28PA-2DSA(51) A3B-30PA-2DSA(51) A3B-32PA-2DSA(51) HRS No. No. of Contacts 4 621-0401-1 51 6 621-0402-4 51 8 621-0403-7 51 10 621-0404-0 51 12 621-0405-2 51 14 621-0406-5 51 16 621-0407-8 51 18 621-0408-0 51 20 621-0409-3 51 22 621-0410-2 51 24 621-0411-5 51 26 621-0412-8 51 28 621-0413-0 51 30 621-0414-3 51 32 621-0415-6 51 A 04.0 06.0 08.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 32.0 B 02.0 04.0 06.0 08.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 RoHS A 04.0 06.0 08.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 32.0 44.0 50.0 B 02.0 04.0 06.0 08.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 42.0 48.0 Kink Positions RoHS 2 1 or 2 alternately 2 alternately 2 or 3 alternately 3 alternately 3 or 4 alternately 4 alternately 4 or 5 alternately YES 5 alternately 5 or 6 alternately 6 alternately 6 or 7 alternately 7 alternately 7 or 8 alternately 8 alternately 11 alternately 12 or 13 alternately YES BPCB mounting pattern B±0.1 2±0.05 2±0.05 Note : Please, order the product per 100 pcs. Ø0.8 +0.1 _0 ●A3B Right Angle Type Part No. A3B-04PA-2DS(51) A3B-06PA-2DS(51) A3B-08PA-2DS(51) A3B-10PA-2DS(51) A3B-12PA-2DS(51) A3B-14PA-2DS(51) A3B-16PA-2DS(51) A3B-18PA-2DS(51) A3B-20PA-2DS(51) A3B-22PA-2DS(51) A3B-24PA-2DS(51) A3B-26PA-2DS(51) A3B-28PA-2DS(51) A3B-30PA-2DS(51) A3B-32PA-2DS(51) A3B-44PA-2DS(51) A3B-50PA-2DS(51) HRS No. 621-0351-5 51 621-0352-8 51 621-0353-0 51 621-0354-3 51 621-0355-6 51 621-0356-9 51 621-0357-1 51 621-0358-4 51 621-0359-7 51 621-0360-6 51 621-0361-9 51 621-0362-1 51 621-0363-4 51 621-0364-7 51 621-0365-0 51 621-0377-9 51 621-0383-1 51 No. of Contacts 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 44 50 Note 1 : Please order the product per 100 pcs. Note 2 : Diameter of 28 or more contacts is Ø0.95±0.04. BPCB mounting pattern B±0.1 2±0.05 2±0.05 Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●A3B Straight Type Note 2 Ø0.9±0.04 C13 A3 • A4 Series●2mm Pitch Miniature Connector Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●A4B Straight Type Part No. A4B-02PA-2DSA(51) A4B-03PA-2DSA(51) A4B-04PA-2DSA(51) A4B-05PA-2DSA(51) A4B-06PA-2DSA(51) A4B-07PA-2DSA(51) A4B-08PA-2DSA(51) A4B-09PA-2DSA(51) A4B-10PA-2DSA(51) A4B-12PA-2DSA(51) A4B-13PA-2DSA(51) A4B-14PA-2DSA(51) A4B-15PA-2DSA(51) A4B-16PA-2DSA(51) HRS No. 622-0401-8 51 622-0402-0 51 622-0403-3 51 622-0404-6 51 622-0405-9 51 622-0406-1 51 622-0407-4 51 622-0408-7 51 622-0409-0 51 622-0411-1 51 622-0412-4 51 622-0413-7 51 622-0414-0 51 622-0415-2 51 No. of Contacts 2 3 4 5 6 7 8 9 10 12 13 14 15 16 A 04.0 06.0 08.0 10.0 12.0 14.0 16.0 18.0 20.0 24.0 26.0 28.0 30.0 32.0 B 02.0 04.0 06.0 08.0 10.0 12.0 14.0 16.0 18.0 22.0 24.0 26.0 28.0 30.0 RoHS A 04.0 06.0 08.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 32.0 B 02.0 04.0 06.0 08.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 Kink Positions RoHS 2 1 or 2 alternately 2 alternately 2 or 3 alternately 3 alternately 3 or 4 alternately 4 alternately 4 or 5 alternately YES 5 alternately 5 or 6 alternately 6 alternately 6 or 7 alternately 7 alternately 7 or 8 alternately 8 alternately BPCB mounting pattern B±0.1 2±0.05 Ø0.8 +0.1 0 Note : Please order the product per 100 pcs. ●A4B Right Angle Type Part No. A4B-02PA-2DS(51) A4B-03PA-2DS(51) A4B-04PA-2DS(51) A4B-05PA-2DS(51) A4B-06PA-2DS(51) A4B-07PA-2DS(51) A4B-08PA-2DS(51) A4B-09PA-2DS(51) A4B-10PA-2DS(51) A4B-11PA-2DS(51) A4B-12PA-2DS(51) A4B-13PA-2DS(51) A4B-14PA-2DS(51) A4B-15PA-2DS(51) A4B-16PA-2DS(51) HRS No. 622-0351-1 51 622-0352-4 51 622-0353-7 51 622-0354-0 51 622-0355-2 51 622-0356-5 51 622-0357-8 51 622-0358-0 51 622-0359-3 51 622-0360-2 51 622-0361-5 51 622-0362-8 51 622-0363-0 51 622-0364-3 51 622-0365-6 51 No. of Contacts 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Note 1 : Please order the product per 100 pcs. Note 2 : Dinmeter is 0.95±0.04 for 14pos, or more. C14 YES BPCB mounting pattern B±0.1 2±0.05 Note 2 Ø0.9±0.04 A3 • A4 Series●2mm Pitch Miniature Connector Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Pin Header BPCB mounting pattern Note : Please order the product per 100 pcs. Unit : mm Part No. HRS No. No. of Contacts A B A3C-02P-2DSA(30) 621-0601-0 30 2 02.0 ---- A3C-04P-2DSA(30) 621-0602-3 30 4 04.0 02.0 A3C-06P-2DSA(30) 621-0603-6 30 6 06.0 04.0 A3C-08P-2DSA(30) 621-0604-9 30 8 08.0 06.0 A3C-10P-2DSA(30) 621-0605-1 30 10 10.0 08.0 A3C-12P-2DSA(30) 621-0606-4 30 12 12.0 10.0 A3C-14P-2DSA(30) 621-0607-7 30 14 14.0 12.0 A3C-16P-2DSA(30) 621-0608-0 30 16 16.0 14.0 A3C-18P-2DSA(30) 621-0609-2 30 18 18.0 16.0 A3C-20P-2DSA(30) 621-0610-1 30 20 20.0 18.0 A3C-22P-2DSA(30) 621-0611-4 30 22 22.0 20.0 A3C-24P-2DSA(30) 621-0612-7 30 24 24.0 22.0 A3C-26P-2DSA(30) 621-0613-0 30 26 26.0 24.0 A3C-28P-2DSA(30) 621-0614-2 30 28 28.0 26.0 A3C-32P-2DSA(30) 621-0615-5 30 32 32.0 30.0 A3C-44P-2DSA(30) 621-0622-0 30 44 44.0 42.0 A3C-48P-2DSA(30) 621-0625-9 30 48 48.0 46.0 A3C-50P-2DSA(30) 621-0628-7 30 50 50.0 48.0 RoHS YES C15 A3 • A4 Series●2mm Pitch Miniature Connector ■Receptacle Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●A3 Right Angle Type BPCB mounting pattern Unit : mm Part No. HRS No. A B A3-44DA-2DS(71) 621-0711-9 71 44 42 A3-50DA-2DS(71) 621-0714-7 71 50 48 Note : Please order the product per 100 pcs. C16 RoHS YES A3 • A4 Series●2mm Pitch Miniature Connector ■Receptacle Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. KA3C Type BPCB mounting pattern Unit : mm Part No. HRS No. A3C-04DA-2DSA(71) 621-0501-6 71 A3C-04DA-2DSC(71) 621-0531-7 71 A3C-06DA-2DSA(71) 621-0502-9 71 A3C-06DA-2DSC(71) 621-0532-0 71 A3C-08DA-2DSA(71) 621-0503-1 71 A3C-08DA-2DSC(71) 621-0533-2 71 A3C-10DA-2DSA(71) 621-0504-4 71 A3C-10DA-2DSC(71) 621-0534-5 71 A3C-12DA-2DSA(71) 621-0505-7 71 A3C-12DA-2DSC(71) 621-0535-8 71 A3C-14DA-2DSA(71) 621-0506-0 71 A3C-14DA-2DSC(71) 621-0536-0 71 A3C-16DA-2DSA(71) 621-0507-2 71 A3C-16DA-2DSC(71) 621-0537-3 71 A3C-18DA-2DSA(71) 621-0508-5 71 A3C-18DA-2DSC(71) 621-0538-6 71 No. of Contacts 4 6 8 10 A B 04.0 02.0 06.0 04.0 08.0 06.0 10.0 08.0 12 12.0 10.0 14 14.0 12.0 16 16.0 14.0 18 18.0 16.0 C RoHS Part No. HRS No. 3.0 A3C-20DA-2DSA(71) 621-0509-8 71 2.0 A3C-20DA-2DSC(71) 621-0539-9 71 3.0 A3C-24DA-2DSA(71) 621-0511-0 71 2.0 A3C-24DA-2DSC(71) 621-0541-0 71 3.0 A3C-24DA-2DSE(71) 621-0571-1 71 2.0 A3C-28DA-2DSA(71) 621-0513-5 71 3.0 A3C-28DA-2DSC(71) 621-0543-6 71 2.0 A3C-32DA-2DSA(71) 621-0515-0 71 3.0 2.0 YES A3C-32DA-2DSC(71) 621-0545-1 71 No. of Contacts A 20 A3C-50DA-2DSA(71) 621-0524-1 71 2.0 A3C-50DA-2DSC(71) 621-0554-2 71 3.0 A3C-50DA-2DSE(71) 621-0584-3 71 20.0 18.0 C RoHS 3.00 2.00 3.00 24 24.0 22.0 2.00 1.27 3.00 28 28.0 26.0 32 32.0 30.0 2.00 2.00 YES 3.00 1.27 A3C-32DA-2DSE(71) 621-0575-2 71 3.0 B 3.00 50 50.0 48.0 2.00 1.27 2.0 3.0 2.0 C17 A3 • A4 Series●2mm Pitch Miniature Connector Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●A3D Type C18 BPCB mounting pattern Unit : mm Part No. HRS No. No. of Contacts A B A3D-04DA-2DSE(71) 621-0751-3 71 4 04.0 02.0 A3D-06DA-2DSE(71) 621-0752-6 71 6 06.0 04.0 A3D-08DA-2DSE(71) 621-0753-9 71 8 08.0 06.0 A3D-10DA-2DSE(71) 621-0754-1 71 10 10.0 08.0 A3D-12DA-2DSE(71) 621-0755-4 71 12 12.0 10.0 A3D-14DA-2DSE(71) 621-0756-7 71 14 14.0 12.0 A3D-16DA-2DSE(71) 621-0757-0 71 16 16.0 14.0 A3D-18DA-2DSE(71) 621-0758-2 71 18 18.0 16.0 A3D-20DA-2DSE(71) 621-0759-5 71 20 20.0 18.0 A3D-28DA-2DSE(71) 621-0763-2 71 28 28.0 26.0 A3D-44DA-2DSE(71) 621-0766-0 71 44 44.0 42.0 RoHS YES A3 • A4 Series●2mm Pitch Miniature Connector ■Crimping Socket Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●A3B-*D-2C Part No. A3B-04D-2C A3B-06D-2C A3B-08D-2C A3B-10D-2C A3B-12D-2C A3B-14D-2C A3B-18D-2C A3B-20D-2C A3B-24D-2C A3B-28D-2C A3B-44D-2C HRS No. 621-0305-8 621-0306-0 621-0307-3 621-0308-6 621-0309-9 621-0310-8 621-0311-0 621-0312-3 621-0313-6 621-0314-9 621-0330-5 No. of Contacts 4 6 8 10 12 14 18 20 24 28 44 A 04.0 06.0 08.0 10.0 12.0 14.0 18.0 20.0 24.0 28.0 44.0 B 02.0 04.0 06.0 08.0 10.0 12.0 16.0 18.0 22.0 26.0 42.0 RoHS YES Note 1 : * indicates the number of contacts. Note 2 : Please order the product per 100 pcs. Note 3 : Use other contacts in combination. (Example : 50 contacts = 44 contacts + 6 contacts) ●A4B-*S-2C Part No. A4B-02S-2C A4B-03S-2C A4B-04S-2C A4B-05S-2C A4B-06S-2C A4B-08S-2C A4B-10S-2C A4B-12S-2C A4B-15S-2C A4B-16S-2C A4B-18S-2C HRS No. 622-0301-3 622-0302-6 622-0303-9 622-0304-1 622-0305-4 622-0306-7 622-0307-0 622-0308-2 622-0311-7 622-0310-4 622-0309-5 No. of Contacts 2 3 4 5 6 8 10 12 15 16 18 A 04.0 06.0 08.0 10.0 12.0 16.0 20.0 24.0 30.0 32.0 36.0 B 02.0 04.0 06.0 08.0 10.0 14.0 18.0 22.0 28.0 30.0 34.0 RoHS YES Note 1 : * indicates the number of contacts. Note 2 : Please, order the product per 100 pcs. C19 A3 • A4 Series●2mm Pitch Miniature Connector ■Crimping Contact Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. SCC contact SCFC contact Note 1 : The plating specification is shown as follows: Note 2 : "30" is stamped on A3B-2630SCFC(SCC), (Contact area) : Gold plating and "36" is stamped on A3B-3236SCFC(SCC). (Others) : Nickel plating Part No. HRS No. Applicable Cable Type Quantity Crimping Tool RoHS A3B-2630SCFC 621-0301-7 26 to 30 AWG Reel 10000 Automatic crimper CM-105C+AP105-A3B-2630S A3B-2630SCC 621-0302-0 26 to 30 AWG Bag 100 A3B-3236SCFC 621-0303-2 32 to 36 AWG Reel 10000 YES A3B-TA2630HC Automatic crimper CM-105C+AP105-A3B-3236S BCrimping Tool Manual crimping tool A3B-TA2630HC Specification (CM-105 type) Automatic crimping machine CM-105C Features This tool is a new model to meet many user needs, and finely designed to enhance operativity and expand the application range for setup adjustment and various applicator installations. The easy to handle semi-automatic crimping machine can be used for crimping connection of various strip contacts. Specification Power supply 100V AC, single phase 200W Gross weight 75kg Machining range 2000 to 4000 contacts/hour Remarks Type Manual Automatic C20 Item Part No. Crimping of various contacts by replacing the applicator HRS No. Applicable Contact Applicable Cable Manual crimping tool A3B-TA2630HC 550-0200-7 A3B-2630SCC 26 to 30 AWG Automatic crimping machine CM-105C 901-0001-0 --------------- --------------- AP105-A3B-2630S 901-4016-2 A3B-2630SCFC 26 to 30 AWG AP105-A3B-3236S 901-4017-5 A3B-3236SCFC 32 to 36 AWG Applicator A3 • A4 Series●2mm Pitch Miniature Connector Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BShort Pin Please, order the product per 1000 pcs. Part No. HRS No. A3-SP(A) 621-0180-4 Material Housing Contact Finish PBT Black (UL94V-0) Phosphor bronze Selective gold plating RoHS YES B Polarizing Key A3-GPIN(A) Note : This product is provided in a set of 10 pieces in conjunction with a runner. The unit for sale consists of 10 sets, which are included in one pack. Part No. HRS No. Material RoHS A3-GPIN(A) 621-0178-2 Poly acetal (white) YES C21 A3 • A4 Series●2mm Pitch Miniature Connector Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Pin Header C22 BPCB mounting pattern e) ot (N e) ot (N Note : For automatic board placement, recommended boss dia. is 1.2 +0.1 -0 . PCB mounting pattern for 4 pos. Unit : mm Part No. A3A-04PA-2SV(71) HRS No. 621-1000-6 71 A3A-04PA-2SV(71) A3A-06PA-2SV(71) 621-1040-0 71 621-1001-9 71 A3A-06PA-2SV(71) A3A-08PA-2SV(71) 621-1041-3 71 621-1002-1 71 A3A-08PA-2SV(71) 621-1042-6 71 A3A-10PA-2SV(71) A3A-10PA-2SV(71) 621-1003-4 71 621-1043-9 71 10 10.0 08.0 -----------06.0 A3A-12PA-2SV(71) A3A-12PA-2SV(71) 621-1004-7 71 621-1044-1 71 12 12.0 10.0 -----------08.0 A3A-14PA-2SV(71) 621-1005-0 71 A3A-14PA-2SV(71) A3A-16PA-2SV(71) 621-1045-4 71 621-1006-2 71 14 14.0 12.0 A3A-16PA-2SV(71) A3A-20PA-2SV(71) 621-1046-7 71 621-1008-8 71 16 16.0 14.0 A3A-20PA-2SV(71) 621-1048-2 71 20 20.0 18.0 A3A-24PA-2SV(71) A3A-24PA-2SV(71) 621-1010-0 71 621-1050-4 71 24 24.0 22.0 -----------20.0 A3A-28PA-2SV(71) A3A-28PA-2SV(71) 621-1012-5 71 621-1052-0 71 28 28.0 26.0 -----------24.0 A3A-32PA-2SV(71) A3A-32PA-2SV(71) 621-1014-0 71 621-1054-5 71 32 32.0 30.0 -----------28.0 A3A-44PA-2SV(71) 621-1015-3 71 A3A-44PA-2SV(71) A3A-50PA-2SV(71) 621-1055-8 71 621-1016-6 71 44 44.0 42.0 A3A-50PA-2SV(71) 621-1056-0 71 50 50.0 48.0 No. of Contacts A B 4 04.0 02.0 6 06.0 04.0 8 08.0 06.0 C RoHS -----------02.0 -----------02.0 -----------04.0 -----------10.0 -----------12.0 -----------16.0 -----------40.0 -----------46.0 YES A3 • A4 Series●2mm Pitch Miniature Connector Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Receptacle BPCB mounting pattern e) ot (N Note : For automatic board placement, recommended boss dia. is 1.2+0.1 -0 . e) ot (N PCB mounting pattern for 4 pos. Unit : mm Part No. HRS No. A3A-04DA-2SV(71) 621-1100-0 71 A3A-04DA-2SV(71) 621-1140-5 71 A3A-06DA-2SV(71) 621-1101-3 71 A3A-06DA-2SV(71) 621-1141-8 71 A3A-08DA-2SV(71) 621-1102-6 71 A3A-08DA-2SV(71) 621-1142-0 71 A3A-10DA-2SV(71) 621-1103-9 71 A3A-10DA-2SV(71) 621-1143-3 71 A3A-12DA-2SV(71) 621-1104-1 71 A3A-12DA-2SV(71) 621-1144-6 71 A3A-14DA-2SV(71) 621-1105-4 71 A3A-14DA-2SV(71) 621-1145-9 71 A3A-16DA-2SV(71) 621-1106-7 71 A3A-16DA-2SV(71) 621-1146-1 71 A3A-20DA-2SV(71) 621-1108-2 71 A3A-20DA-2SV(71) 621-1148-7 71 A3A-24DA-2SV(71) 621-1110-4 71 A3A-24DA-2SV(71) 621-1150-9 71 A3A-28DA-2SV(71) 621-1112-0 71 A3A-28DA-2SV(71) 621-1152-4 71 A3A-32DA-2SV(71) 621-1114-5 71 A3A-32DA-2SV(71) 621-1154-0 71 No. of Contacts A B 4 04.0 02.0 6 06.0 04.0 8 08.0 06.0 10 10.0 08.0 12 12.0 10.0 14 14.0 12.0 16 16.0 14.0 20 24 28 32 20.0 24.0 28.0 32.0 18.0 22.0 26.0 30.0 C RoHS -----------02.0 -----------02.0 -----------04.0 -----------06.0 -----------08.0 -----------10.0 YES -----------12.0 -----------16.0 -----------20.0 -----------24.0 -----------28.0 C23 A3 • A4 Series●2mm Pitch Miniature Connector BRecommended Temperature Profile 260 MAX250ç 240 220ç 220 200ç Temperature (ç) Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 200 180 HRS test conditions Test boardGlass epoxy 85mm∞60mm∞1.6mm thick Solder method : Reflow Solder composition : Paste, 96.5%Sn/3%Ag/0.5%Cu Metal mask : 0.2mm thick Reflow cycles : 2 cycles 160 140 150ç 0 90 to 120 sec. Preheating(150 to 200ç) MAX 60 sec. Soldering (220ç min) Time (sec.) The temperature profile is based on the above conditions. In individual applications the actual temperature may vary, depending on solder paste type, volume/thickness and board size/thickness. Consult your solder paste and equipment manufacturer for specific recommendations. BFunctional Block Chart Receptacle and Socket Side Pin Header Side A3 (A)-*DA-2SV Straight SMT Type A3 (A)-*PA-2SV Straight SMT Type A3 (A)-*DA-2DSA(DSC, DSE) Straight Through hole Type A3C-*P-2DSA Straight Through hole (low profile) Type A3B-*PA-2DSA Straight Through hole Type A3B-*D-2C Cable crimping type A3B-*PA-2DS Right Angle Through hole Type C24 A3 • A4 Series●2mm Pitch Miniature Connector Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BApplication Pattern (A3 series) Powered by TCPDF (www.tcpdf.org) A3(A)-*DA-2SV A3C-*DA-2DSA A3B-*D-2C A3(A)-*PA-2SV A3(A)-*PA-2SV A3(A)-*PA-2SV A3C-*DA-2DSA A3B-*D-2C A3(A)-*DA-2SV A3C-*P-2DSA A3C-*P-2DSA A3C-*P-2DSA A3(A)-*DA-2SV A3C-*DA-2DSA A3B-*D-2C A3B-*PA-2DSA A3B-*PA-2DSA A3B-*PA-2DSA A3(A)-*DA-2SV A3C-*DA-2DSA A3B-*D-2C A3B-*PA-2DS A3B-*PA-2DS A3B-*PA-2DS Note : When the connector is mounted on the board surface, the mounting height is a size designed in single connector. Solder paste used for installation will slightly change according to solder thickness. C25
A3B-16PA-2DS(71) AI解析
物料型号:HIROSE ELECTRIC CO., LTD.生产的2mm间距微型连接器,包括A3和A4系列。
器件简介: - 这些连接器设计为微型轻量级产品,适用于高密度安装。 - 压接式外壳采用2mm间距网格结构,便于连接器的排列使用。 - 提供DIP、SMT和压接型等多种类型,具有广泛的接触点数量变体。
引脚分配: - 引脚分配根据连接器类型(如A3B、A3C、A4B)和接触点数量(如2、4、6...50)有所不同。
参数特性: - 电流额定值:1A - 工作温度范围:-55至+85°C - 存储温度范围:-10至+60°C - 绝缘电阻:最小1000MΩ - 耐电压:无闪络或绝缘击穿,650V AC/1分钟
功能详解: - 提供了详细的环境测试条件,如湿度(40至80%)、振动测试、耐焊接热测试等。 - 描述了连接器的操作寿命和耐焊接热性能。
应用信息: - 适用于录像机、车载电话和其他各种电子设备。
封装信息: - 材料包括聚酰胺、聚苯硫醚、聚醚醚酮等。 - 表面处理包括黑色和浅棕色的选择性金镀。
产品编号结构: - 提供了如何根据产品编号确定产品规格的图表,并指导用户在订购时选择产品编号。
*介绍内容由AI识别生成
A3B-16PA-2DS(71) 价格&库存
很抱歉,暂时无法提供与“A3B-16PA-2DS(71)”相匹配的价格&库存,您可以联系我们找货
