ECC30DPNN
ECC30DPNN
    SULLINS
    CONNEDGEDUALFMALE60POS0.100
ECC30DPNN 数据手册
Female Card Edge .100” [2.54 mm] Contact Centers, .560” [14.22 mm] Profile, .400” [10.16 mm] Wide Body, Double Point Contact, Dip Solder/Wire Wrap/Right Angle/Card Extender Sullins Female Card Edge SPECIFICATIONS • • • • • Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board PPS, PBT or PA9T insulator 3 Amps current rating for one contact energized 30 milli Ohms maximum at rated current UL Flammability Rating: 94V-0 TERMINATION TYPE POINT OF CONTACT POINT OF CONTACT POINT OF CONTACT L L POINT OF CONTACT POINT OF CONTACT POINT OF CONTACT .150” [3.81] .200” [5.08] ACCOMMODATES .062” [1.57] PCB CARD EXTENDER (PN, PR) RIGHT ANGLE (PB, PG, PE, PJ, PU) DIP SOLDER/WIRE WRAP (PD, PF, PS, PM) TERMINATION TERMINATION TYPE PD DIP SOLDER PS DIP SOLDER PF L * POST LENGTH L ±.025”ʺ [0.64] FITS MIN. HOLE SIZE STANDOFF .160ʺ [4.06] .043ʺ [1.09] YES .190ʺ [4.83] .043ʺ [1.09] YES DIP SOLDER .270ʺ [6.86] .043ʺ [1.09] YES PM WIRE WRAP .560ʺ [14.22] .043ʺ [1.09] YES PB RIGHT ANGLE .100ʺ [2.54] .043ʺ [1.09] NO PG RIGHT ANGLE .140ʺ [3.56] .043ʺ [1.09] NO PE RIGHT ANGLE .180ʺ [4.57] .043ʺ [1.09] NO PU RIGHT ANGLE .250ʺ [6.35] .043ʺ [1.09] NO PJ RIGHT ANGLE .500ʺ [12.70] .043ʺ [1.09] NO PR CARD EXTENDER .225ʺ [5.73] N/A NO PN CARD EXTENDER .595ʺ [15.12] N/A NO * OTHER POST LENGTHS AVAILABLE, CONTACT FACTORY. MOUNTING STYLE (Standoffs included on straight terminations only.) Ø.125” [3.18] #4-40 .250” [6.35] .250” [6.35] CLEARANCE HOLE (H) 60 THREADED INSERT ( I) Ø.125” [3.18] .255” [6.48] SIDE MOUNTING (S) NO MOUNTING EARS (N) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .100” [2.54 mm] Contact Centers, .560” [14.22 mm] Profile, .400” [10.16 mm] Wide Body, Double Point Contact, Dip Solder/Wire Wrap/Right Angle/Card Extender PART NUMBER OPTIONS E B C 10 D PD H - Sxxx MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze R = PPS/Phosphor Bronze G = PA9T/Phosphor Bronze H = PBT/Beryllium Copper A = PPS/Beryllium Copper J = PA9T/Beryllium Copper (Consult factory for other materials.) Refer to Page 7 for Operating/Processing Temperatures CONTACT FINISH - RoHS Compliant MOUNTING STYLE (Opposite Page) H = Clearance Holes I = Threaded Inserts S = Side Mounting N = No Mounting All platings are Lead Free and have .000050” Nickel underplate Contact Surface B = .000010” Gold C = .000030” Gold Sullins Female Card Edge MODIFICATION CODE (Consult Factory) OMIT FOR STANDARD TERMINATION TYPE (Opposite Page) PD, PF, PS = .025” [0.64 mm] Square Dip Solder PM = .025” [0.64 mm] Square Wire Wrap PB, PG, PE, PJ, PU = .025” [0.64 mm] Square Right Angle PN, PR = .025” [0.64 mm] Square Card Extender Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte CONTACT CENTERS C = .100” [2.54 mm] NUMBER OF CONTACT POSITIONS See Chart Below READOUT (Opposite Page) D = Dual DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. .425 [10.80] INSERTION DEPTH E D B A .400 [10.16] C .180 [4.57] .560 [14.22] .250 [6.35] .050 [1.27] .100 [2.54] .025 [0.64] SQ. F REFER TO TERMINATION TYPE Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory. POSITIONS/ CONTACTS INCHES A±.008 B±.008 06/12 0.500 0.700 07/14* 0.600 0.800 08/16 0.700 0.900 10/20 0.900 1.100 12/24* 1.100 1.300 13/26* 1.200 1.400 15/30 1.400 1.600 17/34* 1.600 1.800 18/36* 1.700 1.900 20/40 1.900 2.100 22/44* 2.100 2.300 24/48* 2.300 2.500 25/50* 2.400 2.600 28/56* 2.700 2.900 30/60 2.900 3.100 31/62* 3.000 3.200 35/70* 3.400 3.600 36/72* 3.500 3.700 40/80 3.900 4.100 43/86 4.200 4.400 44/88 4.300 4.500 49/98* 4.800 5.000 50/100 4.900 5.100 55/110* 5.400 5.600 60/120* 5.900 6.100 61/122* 6.000 6.200 65/130* 6.400 6.600 70/140* 6.900 7.100 * Consult factory for availability. MILLIMETERS C±.015 D±.010 E±.020 F±.015 A±0.20 B±0.20 C±0.38 D±0.25 E±0.51 F±0.38 0.860 0.960 1.060 1.260 1.460 1.560 1.760 1.960 2.060 2.260 2.460 2.660 2.760 3.060 3.260 3.360 3.760 3.860 4.260 4.560 4.660 5.160 5.260 5.760 6.260 6.360 6.760 7.260 1.175 1.275 1.375 1.575 1.775 1.875 2.075 2.275 2.375 2.575 2.775 2.975 3.075 3.375 3.575 3.675 4.075 4.175 4.575 4.875 4.975 5.475 5.575 6.075 6.575 6.675 7.075 7.575 1.435 1.535 1.635 1.835 2.035 2.135 2.335 2.535 2.635 2.835 3.035 3.235 3.335 3.635 3.835 3.935 4.335 4.435 4.835 5.135 5.235 5.735 5.835 6.335 6.835 6.935 7.335 7.835 0.740 0.840 0.940 1.140 1.340 1.440 1.640 1.840 1.940 2.140 2.340 2.540 2.640 2.940 3.140 3.240 3.640 3.740 4.140 4.440 4.540 5.040 5.140 5.640 6.140 6.240 6.640 7.140 12.70 15.24 17.78 22.86 27.94 30.48 35.56 40.64 43.18 48.26 53.34 58.42 60.96 68.58 73.66 76.20 86.36 88.90 99.06 106.68 109.22 121.92 124.46 137.16 149.86 152.40 162.56 175.26 17.78 20.32 22.86 27.94 33.02 35.56 40.64 45.72 48.26 53.34 58.42 63.50 66.04 73.66 78.74 81.28 91.44 93.98 104.14 111.76 114.30 127.00 129.54 142.24 154.94 157.48 167.64 180.34 21.84 24.38 26.92 32.00 37.08 39.62 44.70 49.78 52.32 57.40 62.48 67.56 70.10 77.72 82.80 85.34 95.50 98.04 108.20 115.82 118.36 131.06 133.60 146.30 159.00 161.54 171.70 184.40 29.85 32.39 34.93 40.01 45.09 47.63 52.71 57.79 60.33 65.41 70.49 75.57 78.11 85.73 90.81 93.35 103.51 106.05 116.21 123.83 126.37 139.07 141.61 154.31 167.01 169.55 179.71 192.41 36.45 38.99 41.53 46.61 51.69 54.23 59.31 64.39 66.93 72.01 77.09 82.17 84.71 92.33 97.41 99.95 110.11 112.65 122.81 130.43 132.97 145.67 148.21 160.91 173.61 176.15 186.31 199.01 18.80 21.34 23.88 28.96 34.04 36.58 41.66 46.74 49.28 54.36 59.44 64.52 67.06 74.68 79.76 82.30 92.46 95.00 105.16 112.78 115.32 128.02 130.56 143.26 155.96 158.50 168.66 181.36 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 61
ECC30DPNN 价格&库存
很抱歉,暂时无法提供与“ECC30DPNN”相匹配的价格&库存,您可以联系我们找货
