FTSH-105-01-F-D-RA-K 数据手册
REVISION BQ
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. TERMINALS TO BE SHEARED TO MEET DIMENSION SPECIFICATION.
3. PARTS MAY BE CUT TO POSITION.
4. MINIMUM PUSHOUT FORCE: .5 LB.
5. EJ OPTION IS NOT AVAILABLE AS OF REVISION AG.
APPLICABLE VIEWS ARE REMAINING FOR REFERENCE TO BUILD
INTERNAL ASP ORDERS ONLY. THIS OPTION WAS FOR EXISTING
BUSINESS ONLY. ANY EXISTING CUSTOMERS WILL HAVE PART
NUMBERS SETUP AS INTERNAL ASP'S.
6. MAX BURR ALLOWANCE: .003" [.08"]
7. MAX CUT FLASH: .010 [.25]
8. MAX HEIGHT VARIATION BETWEEN ROWS: .005 [.13]
DO NOT
SCALE FROM
THIS PRINT
No OF POSITIONS
-02 THRU -50
(PER ROW)
PLATING SPECIFICATION
-F: 3µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-L: 10µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-H: 30µ" HEAVY GOLD IN CONTACT AREA,
3µ" GOLD ON TAIL
-FM: 3µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-LM: 10µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-SM: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-LTL: 10µ" SELECTIVE GOLD IN CONTACT AREA,
90 / 10 ± 5% TIN LEAD ON TAIL
No OF POS x .0500 [1.270] - .0500 [1.270]
50
.050 1.26
01
49
OPTIONS
-ES: END SHROUDS
(-02 & -03 LEAD STYLE ONLY- SEE FIG 2, SHT 2)
(9 POS PER ROW MIN)
(MUST USE FTSH-50-D)
-EL: SHROUD LOCK
(-02 & -03 LEAD STYLE ONLY- SEE FIG 4, SHT 2)
(9 POS PER ROW MIN)
(USE ONLY WHEN MATING WITH CLP)
-EP: GUIDE POST
(-02 & -03 LEAD STYLE ONLY- SEE FIG 5, SHT 2)
(9 POS PER ROW MIN)
-EJ: EJECTOR SHROUD
(SEE FIG 3, SHT 2)
(SEE NOTE 5)
-K: KEYING SHROUD
(-01 LEAD STYLE ONLY- SEE FIG 1, -K OPTION)
(POS 05, 08, 10, 13, 15, 17, 20, 25 ONLY)
(USE ONLY WITH -RA TAIL OPTION)
(MUST USE FTSH-XX-CN-XX)
LEAD STYLE
-01: .120 [3.05]
-02: .075 [1.91]
-03: .065 [1.65] MIN
-04: .150 [3.81]
C
[0.13]
No OF POS x .0500 [1.270] - .003 [.08] +.005
- .010 [0.25]
02
FTSH-1XX-XX-XX-D-XX-XX
TAIL OPTION
-RA: RIGHT ANGLE
-FC: FLEX CARD (MUST USE FTSH-50-D)
(-01 LEAD STYLE ONLY, FOR USE WITH FCF)
-FE: FLEX CARD ELEVATED (MUST USE FTSH-50-D)
.135 3.43
REF
ROW SPECIFICATION
-D: DOUBLE ROW
2 MAX SWAY
(EITHER DIRECTION)
.016 0.41 SQ
REF (TYP)
2 MAX SWAY
(EITHER DIRECTION)
CONTACT
AREA
C
"A"
(SEE TABLE 1 & NOTE 8)
C
90°±3°
2 MAX SWAY
(EITHER DIRECTION)
PIN #1
(SEE TABLE 3)
KEYING NOTCH
TO BE LOCATED
THIS SIDE, AWAY
FROM -RA TAILS
PIN #2
(SEE TABLE 3)
"B"
(SEE TABLE 2
& SEE NOTE 2)
C
.099 2.51
REF
.200 5.08 REF
FTSH-50-D
FTSH-XX-CN-XX
.050 1.27 C
C .050 1.27
FIG 1
FTSH-1XX-XX-XXX-D-RA SHOWN
-RA OPTION SHOWN
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
1
.XXX: .005 [.13]
.XXXX: .0010 [.025]
MATERIAL:
"B"
(SEE TABLE 2
& SEE NOTE 2)
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 5:1
INSULATOR: BLACK LIQUID CRYSTAL POLYMER
TERMINAL: PHOSPHOR BRONZE, ALLOY No. 510
F:\DWG\MISC\MKTG\FTSH-1XX-XX-XX-D-XX-XX-MKT.SLDDRW
-K OPTION SHOWN
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.050 x .050 C.L. DOUBLE HORIZONTAL TERMINAL STRIP
DWG. NO.
BY: BRATCHER 08/17/1995
SHEET 1 OF 3
FIG 3
REVISION BQ
FIG 2
-ES OPTION
AVAILABLE IN LEAD STYLE -02 & -03 ONLY
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1)
FTSH-50-D
-EJ OPTION
(FOR EXISTING CUSTOMERS ONLY)
AVAILABLE IN LEAD STYLE -01 ONLY
(SEE NOTE 5 ON SHEET 1)
FTSH-50-D
.222 5.65 REF
.139 3.531
REF
.188 4.78
REF
.091 2.31 REF
C
(No OF POS x .050[1.27])
+.061[1.55] ±.008[.20]
.245 6.22
REF
.188 4.78
REF
FTSH-ES
.440 11.18
REF
.168 4.27
REF
.178 4.51
.090 2.296
REF
No OF POS x .050[1.27] + .231[5.87]
±.008[.20]
FIG 4
-EL OPTION
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2)
No OF POS x .050[1.27] + .257[6.53] REF
No OF POS x .050[1.27] + .153[3.89] REF
USE FTSH-EJEHA SUB ASSEMBLY
(2 REQ'D PER ASSEMBLY - EACH
USES 1 EHA-02, 1 FTSH-EJ)
No OF POS x .050[1.27] + .621[15.77]
±.010[.25]
.075 1.91
REF
.188 4.78
REF
.188 4.78
REF
.330 8.38
REF
FTSH-EP
.120 3.05
.298 7.56
.125 3.18
REF
FTSH-EL
.303 7.68
.090 2.29 REF
No OF POS x .050[1.27] + .156[3.96] REF
No OF POS x .050[1.27] + .223[5.66]
±.008[.20]
.090 2.29 REF
FIG 5
-EP OPTION
SAME AS FIG 2)
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
SHEET 2 OF 3
REVISION BQ
PACKAGING TUBES
PT-1-24-03-38
PT-FTSH005-RA
PT-FTSH008-RA-EX
-K
-RA
-ES
PT-1-24-06-40
PT-FTSH008-RA-EX
PT-FTSH008-RA-EX
-EP
-EL
-EJ
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
SHEET 3 OF 3
