EJH-110-01-F-D-TH
EJH-110-01-F-D-TH
    SAMTEC(申泰)
    插件
    特性:绝缘体材料: .01 = 黑色LCP。 .02 = 自然色LCP。端子材料:磷青铜。镀层:在50 μin (1.27 μm)镍上镀锡或金。工作温度范围:-55°C至125°C。可无铅焊接:是...
EJH-110-01-F-D-TH 数据手册
REVISION AC DO NOT SCALE FROM THIS PRINT (No OF POS x .100[2.54]) + .694[17.63] REF .397 10.08 02 EJH-1XX-XX-XX-D-XX-XX-XX (No OF POS -1) x .100[2.54] REF -LC: LOCKING CLIP (FOR -SM ONLY) (SEE NOTE 10) -P: PICK & PLACE PAD (FOR -SM ONLY) (USE PPP-50, SEE FIGURE 6, SHEET 3) -K: POLYIMIDE FILM (SEE FIG 3, SHEET 3) (USE K-850-650) -TR: TAPE & REEL PACKAGING (SEE FIG 7, SHEET 3)) (FOR -SM-P, & -SM-K ONLY) (NOT AVAILABLE ON -SM-LC) (NOT AVAILABLE ON -25 POSITION) LEAD STYLE -01: STANDARD (USE EJH-XX-D) -02: EXTENDED (SEE FIG 11, SHEET 4) (USE EJH-XX-D-EXT & EHA-03-EXT) "A" .100 2.54 .020 0.51 REF .390 9.91 REF OPTION No OF POSITIONS -05 THRU -25 .150 3.81 (TYP) REF 01 "A" C .250 6.35 REF 2 MAX SWAY (TYP) (No OF POS x .100[2.54]) + .104[2.64] REF EJH-XX-D .025 0.64 SQ REF (TYP) .225 5.72 REF POLARIZED OPTION -XX = PIN OMITED PLATING SPECIFICATION -S: SELECTIVE GOLD, MATTE TIN TAIL (USE T-1S6X-XX-S-X) -F: FLASH SELECTIVE GOLD, MATTE TIN TAIL (USE T-1S6X-XX-F-X) -SM: SELECTIVE HEAVY GOLD, MATTE TIN TAIL (USE T-1S6X-XX-S-X) -FM: FLASH SELECTIVE GOLD, MATTE TIN TAIL (USE T-1S6X-XX-F-X) -L : LIGHT SELECTIVE GOLD MATTE TIN TAIL (USE T-1S6X-XX-L-X) TAIL OPTION -SM: SURFACE MOUNT (SEE FIG 1) -TH: THROUGH HOLE (SEE FIG 8, SHEET 2) -RA: RIGHT ANGLE (SEE FIG 9, SHEET 2) ROW SPECIFICATION -D: DOUBLE C .500 12.70 REF .505 12.83 C 90° .004[0.10] C PIN A (SEE TABLE 1) .467±.010 11.86±0.25 .060 1.52 SECTION "A"-"A" C LC-09-TM (No OF POS x .100[2.54]) + .400[10.16] REF .060 1.52 REF 90° FIG 1 EJH-110-01-X-D-SM-LC SHOWN POSITION 1 INDICATOR NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. COPLANARITY TO BE: .004 MAX FOR POSITIONS -05 THRU -10 .006 MAX FOR POSITIONS -15 THRU -25 3. MAXIMUM BURR ALLOWANCE: .0015 4. MINIMUM PUSHOUT FORCE: 1 LB 5. MAXIMUM ALLOWABLE BOW: .002 INCH/INCH AFTER ASSEMBLY. 6. PARTS TO BE TUBED WITH EJECTOR ARMS IN THE UP POSITION AS SHOWN. 7. REPRESS TO DIMENSION SHOWN. 8. NOTE DELETED. 9. MEASURE FROM THE TIPS OF THE TERMINALS. 10. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE –LC OPTION IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE –LC OPTION. 11. EJECTOR ARMS PRESENT ON ALL FINISHED ASSEMBLIES. REMOVED IN SOME CASES FOR CLARITY. .130 3.30 .280 7.11 .467±.010 11.86±0.25 -SM IN-PROCESS 1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01[0.3] 2 .XXX: .005[0.13] .XXXX: .0020[0.051] MATERIAL: * -SM IN-PROCESS 2 PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:2 -01 INSULATOR: VECTRA E130i, COLOR: BLACK -02 INSULATOR COLOR: NATURAL TERMINAL: PHOS BRONZE 510 3/4 HARD F:\DWG\MISC\MKTG\EJH-1XX-XX-XX-D-XX-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .100 x .100 EJECTOR HEADER ASSEMBLY DWG. NO. EJH-1XX-XX-XX-D-XX-XX-XX BY: ERIC M. 09/19/01 SHEET 1 OF 4 REVISION AC "C" PIN A (SEE TABLE 1) PIN A (SEE TABLE 1) .120 3.05 C C 2 MAX SWAY (EITHER DIRECTION) C "C" 2 MAX SWAY (EITHER DIRECTION) .100 2.54 (TYP) .650 16.51 REF C .100 2.54 (TYP) ((No OF POS -1) x .100[2.54]) .008[0.20] 90° .125 3.18 REF .125 3.18 REF .375 9.53 .16 4.1 (SEE NOTE 9) .09 2.3 REF SECTION "C"-"C" FIG 8 -RA IN-PROCESS 2 -RA IN-PROCESS 1 EJH-110-01-X-D-TH SHOWN [DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1] C 2 MAX SWAY (EITHER DIRECTION) PIN B (SEE TABLE 1) .225 5.72 REF 02 01 .850 21.59 REF PIN A (SEE TABLE 1) "F" 90° PIN B (SEE TABLE 1) .06 1.5 (SEE NOTES 7 & 9) .475 12.07 90° C .225 5.72 REF .09 2.3 REF -RA IN-PROCESS 3 C .06 1.5 (SEE NOTE 9) "F" * .09 2.3 REF FIG 9 SECTION "F"-"F" .100 2.54 (SEE NOTE 9) C EJH-110-01-X-D-RA SHOWN [DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1] PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 1.5:1 F:\DWG\MISC\MKTG\EJH-1XX-XX-XX-D-XX-XX-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .100 x .100 EJECTOR HEADER ASSEMBLY DWG. NO. EJH-1XX-XX-XX-D-XX-XX-XX BY: ERIC M. 09/19/01 SHEET 2 OF 4 REVISION AC .945 24.00 EHA-03 01 .665 16.88 REF "B" "B" "A" .104 2.65 REF FIG 2 OPEN LATCH VIEW IN-PROCESS VIEW: ARM ASSEMBLY & ROTATION .475 12.07 REF CL USER DIRECTION OF UN-REELING POCKET NOT DETAILED .385 9.78 REF 01 "S" (SEE NOTE) C "R" (SEE NOTE) FIG 3 NOTE: "R" = USE MEASURED DIMENSION (REF) "S" = {("R" -.475[12.07]/2) ±.020[0.51]} SECTION "B"-"B" SCALE 0.75 : 1 -K: POLYIMIDE FILM PACKAGING TUBE VIEWS FIG 7 -TR TAPE & REEL PACKAGING FIG 4 "R" (SEE NOTE) SURFACE MOUNT (SEE NOTE 6) TUBE: PT-1-24-01-121 PLUG: TP-13 C PPP-50 .390 9.91 "S" (SEE NOTE) .425 10.80 FIG 5 THROUGH HOLE .455 11.57 (SEE NOTE 6) TUBE: PT-1-24-02-74 PLUG: TP-26 FIG 6 NOTE: "R" = USE MEASURED DIMENSION (REF) "S" = {("R" -.390[9.91]/2) ±.020[0.51]} -P: PICK & PLACE PAD FIG 10 RIGHT ANGLE (SEE NOTE 6) TUBE: PT-1-24-01-131 PLUG: TP-26 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:0.666667 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .100 x .100 EJECTOR HEADER ASSEMBLY DWG. NO. EJH-1XX-XX-XX-D-XX-XX-XX BY: ERIC M. 09/19/01 SHEET 3 OF 4 REVISION AC (No OF POS X .100) + .815 REF .458 11.62 EHA-03-EXT (No OF POS X .100) + .225 REF EJH-XX-D-EXT .685 17.39 REF FIG 11 -02 LEAD STYLE (SAME AS FIG 1, UNLESS OTHERWISE STATED) (EJH-125-02-X-D-SM-LC SHOWN) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\EJH-1XX-XX-XX-D-XX-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .100 x .100 EJECTOR HEADER ASSEMBLY DWG. NO. EJH-1XX-XX-XX-D-XX-XX-XX BY: ERIC M. 09/19/01 SHEET 4 OF 4
EJH-110-01-F-D-TH 价格&库存
很抱歉,暂时无法提供与“EJH-110-01-F-D-TH”相匹配的价格&库存,您可以联系我们找货
