FTSH-120-01-L-D
FTSH-120-01-L-D
    SAMTEC(申泰)
    插件,P=1.27mm
    2X20P 间距:1.27MM 方针 直插
FTSH-120-01-L-D 数据手册
REVISION BQ NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. TERMINALS TO BE SHEARED TO MEET DIMENSION SPECIFICATION. 3. PARTS MAY BE CUT TO POSITION. 4. MINIMUM PUSHOUT FORCE: .5 LB. 5. EJ OPTION IS NOT AVAILABLE AS OF REVISION AG. APPLICABLE VIEWS ARE REMAINING FOR REFERENCE TO BUILD INTERNAL ASP ORDERS ONLY. THIS OPTION WAS FOR EXISTING BUSINESS ONLY. ANY EXISTING CUSTOMERS WILL HAVE PART NUMBERS SETUP AS INTERNAL ASP'S. 6. MAX BURR ALLOWANCE: .003" [.08"] 7. MAX CUT FLASH: .010 [.25] 8. MAX HEIGHT VARIATION BETWEEN ROWS: .005 [.13] DO NOT SCALE FROM THIS PRINT No OF POSITIONS -02 THRU -50 (PER ROW) PLATING SPECIFICATION -F: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -L: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -FM: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -LM: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -LTL: 10µ" SELECTIVE GOLD IN CONTACT AREA, 90 / 10 ± 5% TIN LEAD ON TAIL No OF POS x .0500 [1.270] - .0500 [1.270] 50 .050 1.26 01 49 OPTIONS -ES: END SHROUDS (-02 & -03 LEAD STYLE ONLY- SEE FIG 2, SHT 2) (9 POS PER ROW MIN) (MUST USE FTSH-50-D) -EL: SHROUD LOCK (-02 & -03 LEAD STYLE ONLY- SEE FIG 4, SHT 2) (9 POS PER ROW MIN) (USE ONLY WHEN MATING WITH CLP) (MUST USE FTSH-50-D) -EP: GUIDE POST (-02 & -03 LEAD STYLE ONLY- SEE FIG 5, SHT 2) (9 POS PER ROW MIN) (USE ONLY WHEN MATING WITH CLP) (MUST USE FTSH-50-D) -EJ: EJECTOR SHROUD (SEE FIG 3, SHT 2) (SEE NOTE 5) (MUST USE FTSH-50-D) -K: KEYING SHROUD (-01 LEAD STYLE ONLY- SEE FIG 1, -K OPTION) (POS 05, 08, 10, 13, 15, 17, 20, 25 ONLY) (USE ONLY WITH -RA TAIL OPTION) (MUST USE FTSH-XX-CN-XX) LEAD STYLE -01: .120 [3.05] -02: .075 [1.91] -03: .065 [1.65] MIN -04: .150 [3.81] C [0.13] No OF POS x .0500 [1.270] - .003 [.08] +.005 - .010 [0.25] 02 FTSH-1XX-XX-XX-D-XX-XX TAIL OPTION -RA: RIGHT ANGLE -FC: FLEX CARD (MUST USE FTSH-50-D) (-01 LEAD STYLE ONLY, FOR USE WITH FCF) -FE: FLEX CARD ELEVATED (MUST USE FTSH-50-D) (-01 LEAD STYLE ONLY, FOR USE WITH FCF) .135 3.43 REF ROW SPECIFICATION -D: DOUBLE ROW 2 MAX SWAY (EITHER DIRECTION) .016 0.41 SQ REF (TYP) 2 MAX SWAY (EITHER DIRECTION) CONTACT AREA C "A" (SEE TABLE 1 & NOTE 8) C 90°±3° 2 MAX SWAY (EITHER DIRECTION) PIN #1 (SEE TABLE 3) KEYING NOTCH TO BE LOCATED THIS SIDE, AWAY FROM -RA TAILS PIN #2 (SEE TABLE 3) "B" (SEE TABLE 2 & SEE NOTE 2) C .099 2.51 REF .200 5.08 REF FTSH-50-D FTSH-XX-CN-XX .050 1.27 C C .050 1.27 FIG 1 FTSH-1XX-XX-XXX-D-RA SHOWN -RA OPTION SHOWN UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 1 .XXX: .005 [.13] .XXXX: .0010 [.025] MATERIAL: * "B" (SEE TABLE 2 & SEE NOTE 2) PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 5:1 INSULATOR: BLACK LIQUID CRYSTAL POLYMER TERMINAL: PHOSPHOR BRONZE, ALLOY No. 510 F:\DWG\MISC\MKTG\FTSH-1XX-XX-XX-D-XX-XX-MKT.SLDDRW -K OPTION SHOWN 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 C.L. DOUBLE HORIZONTAL TERMINAL STRIP DWG. NO. FTSH-1XX-XX-XX-D-XX-XX BY: BRATCHER 08/17/1995 SHEET 1 OF 3 FIG 3 REVISION BQ FIG 2 -ES OPTION AVAILABLE IN LEAD STYLE -02 & -03 ONLY (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) FTSH-50-D -EJ OPTION (FOR EXISTING CUSTOMERS ONLY) AVAILABLE IN LEAD STYLE -01 ONLY (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (SEE NOTE 5 ON SHEET 1) FTSH-50-D .222 5.65 REF .139 3.531 REF .188 4.78 REF .091 2.31 REF C (No OF POS x .050[1.27]) +.061[1.55] ±.008[.20] .245 6.22 REF .188 4.78 REF FTSH-ES .440 11.18 REF .168 4.27 REF .178 4.51 .090 2.296 REF No OF POS x .050[1.27] + .231[5.87] ±.008[.20] FIG 4 -EL OPTION (USE ONLY WHEN MATING WITH CLP) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2) No OF POS x .050[1.27] + .257[6.53] REF No OF POS x .050[1.27] + .153[3.89] REF USE FTSH-EJEHA SUB ASSEMBLY (2 REQ'D PER ASSEMBLY - EACH USES 1 EHA-02, 1 FTSH-EJ) No OF POS x .050[1.27] + .621[15.77] ±.010[.25] .075 1.91 REF .188 4.78 REF .188 4.78 REF .330 8.38 REF FTSH-EP .120 3.05 .298 7.56 .125 3.18 REF FTSH-EL .303 7.68 .090 2.29 REF No OF POS x .050[1.27] + .156[3.96] REF F:\DWG\MISC\MKTG\FTSH-1XX-XX-XX-D-XX-XX-MKT.SLDDRW No OF POS x .050[1.27] + .223[5.66] ±.008[.20] .090 2.29 REF FIG 5 -EP OPTION (USE ONLY WHEN MATING WITH CLP) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 C.L. DOUBLE HORIZONTAL TERMINAL STRIP DWG. NO. FTSH-1XX-XX-XX-D-XX-XX BY: BRATCHER 08/17/1995 SHEET 2 OF 3 REVISION BQ PACKAGING TUBES PT-1-24-03-38 PT-FTSH005-RA PT-FTSH008-RA-EX -K -RA -ES PT-1-24-06-40 PT-FTSH008-RA-EX PT-FTSH008-RA-EX -EP -EL -EJ * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\FTSH-1XX-XX-XX-D-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 C.L. DOUBLE HORIZONTAL TERMINAL STRIP DWG. NO. FTSH-1XX-XX-XX-D-XX-XX BY: BRATCHER 08/17/1995 SHEET 3 OF 3
FTSH-120-01-L-D 价格&库存
很抱歉,暂时无法提供与“FTSH-120-01-L-D”相匹配的价格&库存,您可以联系我们找货
FTSH-120-01-L-D
    • 1+46.71000
    • 10+40.47840
    • 23+36.68760
    库存:32
    FTSH-120-01-L-D
    • 23+40.89177
    • 46+39.17485
    • 69+36.86547
    • 115+33.86690
    • 506+27.34985
    • 1012+22.54972
    • 2507+17.66496
    • 5014+12.59883
    库存:539
