IPL1-116-01-L-D-RA-K
    SAMTEC(申泰)
    插件
IPL1-116-01-L-D-RA-K 数据手册
REVISION AJ DO NOT SCALE FROM THIS PRINT IPL1-1XX-XX-XXX-D-XX-X-XX (No OF POS x .100[2.54]) + .060[1.52] REF (No OF POS -1) x .100[2.54] REF .080 2.03 REF LEAD STYLE -01: THROUGH HOLE (USE T-1S64-XX-XX) -02: SURFACE MOUNT (SEE FIG 2, SHT 2) (USE T-1S64-XX-XX) 02 01 .250 6.35 REF CL .100 2.54 REF OPTION -P: POLARIZATION (SEE FIG 1) (USE IPL1-XX-D-P) (NOT AVAILABLE W/ -K OR -G, OPTIONS) -K: KEYED POLARIZATION (USE IPL1-XX-D-K) (SEE FIG 5, SHEET 3) (NOT AVAILABLE W/ -P OR -G, OPTIONS) -G: GUIDE POSTS (SEE FIG 6 & 7, SHEET 3) (USE IPL1-XX-D-GP) (NOT AVAILABLE W/-P, -K OPTIONS) (LEAVE BLANK FOR NO POLARIZATION (SEE FIG 4, SHEET 3), SAMTEC WILL ONLY SUPPORT EXISTING BUSINESS AS OF REV U) PLATING SPECIFICATION -F: FLASH SELECTIVE (USE T-1S64-XX-F) -L: LIGHT SELECTIVE (USE T-1S64-XX-L) -S: SELECTIVE (USE T-1S64-XX-S) -H: HEAVY GOLD (T-1S64-XX-H) -FM: FLASH SELECTIVE/MATTE TIN TAILS (USE T-1S64-XX-F) -LM: LIGHT SELECTIVE/MATTE TIN TAILS (USE T-1S64-XX-L) -SM: SELECTIVE/MATTE TIN TAILS (USE T-1S64-XX-S) -STL: SELECTIVE/ TIN/LEAD TAILS (USE T-1S64-XX-STL) 07 CL .040 1.02 REF .100 2.54 REF FIG 1 IPL1-106-01-XXX-D-P SHOWN IPL1-XX-D-P "A" .300 7.62 REF PACKAGING BLANK: TUBES (SEE NOTE 15) -TR: TAPE & REEL (SEE NOTES 15 & 16) (AVAILABLE WITH -02 LEAD STYLE ONLY) (MUST USE K-DOT-.256-.375-.005) (SEE FIG 8, SHT 3) -FR: FULL REEL QTY. TAPE & REEL (SEE NOTES 15 & 16) (AVAILABLE WITH -02 LEAD STYLE ONLY) (MUST USE K-DOT-.256-.375-.005) No OF POSITIONS -02 THRU -25 (PER ROW) (SEE NOTE 11) OPTION -RA: RIGHT ANGLE (SEE FIG 3, SHT 2) (AVAILABLE WITH -01 LEAD STYLE ONLY) ROW SPECIFICATION -D: DOUBLE (USE IPL1-XX-D) SEE NOTE 9 C SEE NOTE 5 .215 5.46 REF .320 8.13 REF .120 3.05 REF .025 0.64 SQ REF C C 2 MAX SWAY (EITHER DIRECTION) "A" 2 MAX SWAY T-1S64-07-XXX (EITHER DIRECTION) .100 2.54 C C .100 2.54 SECTION "A"-"A" C ((No OF POS -1) x .100[2.54]) .008[.20] NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. NOTE DELETED. 3. MINIMUM TERMINAL RETENTION: 1 LB. 4. PARTS TO BE MOLDED TO POSITION. 5. POST MUST BE WITHIN .005[.13] OF EACH OTHER. 6. ALL PIN TO PIN DIMENSIONS TO BE MEASURED FROM TIP TO TIP. 7. NOTE DELETED. 8. DIMENSION TO BE MEASURED AT BEND. 9. TIP TO BE FLUSH TO .015 BELOW TOP OF SHROUD. 10. BOTH ROWS TO BE SYMMETRIC WITHIN .010[0.25]. 11. THIS NUMBER REPRESENTS THE NUMBER OF POSITIONS PER ROW ONLY AND IS NOT INTENDED TO BE USED IN POSITION NUMBERING. 12. 1 OR 2 GATE PADS TO BE PRESENT AT VENDOR DISCRETION. 13. NOTE DELETED. 14. NOTE DELETED. 15. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM. 16. ATTACH LABEL-4X2 TO EACH REEL. CPC THIS SHEET UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS .XX: .01[.3] .XXX: .005[.13] .XXXX: .0020[.051] C3, C4, C5, C6, C7, C8 MATERIAL: ANGLES 2 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 INSULATOR: LCP UL94-V0, COLOR: BLACK -K INSULATOR: LCP UL94-V0, COLOR: NATURAL TERMINAL: PHOS BRONZE c:\enterprisevault\DWG\MISC\MKTG\IPL1-1XX-XX-XXX-D-XX-X-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100[2.54] DOUBLE ROW TERMINAL ASSEMBLY DWG. NO. IPL1-1XX-XX-XXX-D-XX-X-XX BY: KEVIN B 03/11/02 SHEET 1 OF 3 REVISION AJ FIG 2 IPL1-106-02-XXX-D-P SHOWN [DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1] C -02: SURFACE MOUNT IN PROCESS 2 -02: SURFACE MOUNT IN PROCESS 1 SEE NOTE 9 +0° 90° - 4° .345 8.76 (SEE NOTE 8) C +0° 90° - 4° .110 2.79 .215 5.46 REF C .115 2.92 REF SEE TABLE 2 T-1S64-08-XXX .377 9.58 REF .125 3.17 .235 5.97 REF SEE NOTE 10 .377±.010 9.58±0.25 T-1S64-08-XXX 01 02 FIG 3 IPL1-106-01-XXX-D-RA-P SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) PACKAGING VIEWS (ASSEMBLIES TO HAVE POSITION #1 LOADED IN THE SAME DIRECTION AS ARROW ON TUBE, EXCEPT WITH -RA OPTION) PT-TSM004-DV PT-1-24-15-29 PT-1-24-04-40 .290 7.37 REF 07 PT-1-24-02-08 T-1S64-09-XXX T-1S64-10-XXX C "B" SEE NOTE 9 .215 5.46 REF C .100 2.54 .060 1.52 (SEE NOTE 8) .085 2.16 REF "B" SECTION "B"-"B" c:\enterprisevault\DWG\MISC\MKTG\IPL1-1XX-XX-XXX-D-XX-X-XX-MKT.SLDDRW CPC THIS SHEET C2, C9, C10, C14, C15 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100[2.54] DOUBLE ROW TERMINAL ASSEMBLY DWG. NO. IPL1-1XX-XX-XXX-D-XX-X-XX BY: KEVIN B 03/11/02 SHEET 2 OF 3 -RA: IN PROCESS 1 REVISION AJ -RA: IN PROCESS 3 -RA: IN PROCESS 2 C .110 2.79 90° SEE NOTE 9 SEE NOTE 9 C .215 5.46 REF .115 2.92 REF .640 16.26 -RA: IN PROCESS 4 C C .215 5.46 REF .530 13.46 REF .740 18.80 .730 18.54 REF .160 4.06 .060 1.52 .085 2.16 REF T-1S64-09-XXX T-1S64-10-XXX FIG 4 (IPL1-106-01-XXX-D SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) FIG 5 (IPL1-106-01-XXX-D-K SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 4) SAMTEC WILL ONLY SUPPORT EXISTING BUSINESS AS OF REV. U) 01 FIG 7 FIG 6 (IPL1-102-01-XXX-D-G SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (IPL1-106-01-XXX-D-RA-G SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 3) 01 02 01 -02 POS (DIFFERENT AS SHOWN) 02 01 02 .040 1.02 REF .040 1.02 REF (TYP) 01 02 CL 07 02 .110 2.79 REF IPL1-02-D-GP .110 2.79 REF 07 .090 2.28 REF 03 .090 2.28 REF IPL1-XX-D 07 .030 0.76 REF IPL1-06-D-K 03 IPL1-06-D-GP IPL1-02-D-K FIG 8 (IPL1-106-02-XXX-D-TR SHOWN) (MUST USE K-DOT-.256-.375-.005) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2) ((NO OF POS x .100[2.54] - .196[4.98]) / 2) .020 [0.51] CPC THIS SHEET .017±.020 0.43±0.51 C1, C11, C12, C13 .256 6.50 REF .350 8.89 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100[2.54] DOUBLE ROW TERMINAL ASSEMBLY DWG. NO. IPL1-1XX-XX-XXX-D-XX-X-XX BY: KEVIN B 03/11/02 SHEET 3 OF 3
1. 物料型号:文档中提到了多种型号,例如IPL1-1XX-XX-XXX-D-XX-X-XX,具体型号取决于不同的配置选项。
2. 器件简介:文档描述了一种双排端子组件,具有不同的引脚配置和安装选项。
3. 引脚分配:提供了详细的引脚分配图和尺寸,例如FIG 1和FIG 2展示了不同引脚风格的端子组件布局。
4. 参数特性:文档列出了多种参数,包括尺寸公差、材料规格(如绝缘体LCP UL94-V0,颜色黑色或自然色)和端子材料(磷青铜)。
5. 功能详解:文档中解释了端子组件的不同功能特性,如极性选项(-P, -K)、引脚样式(-01为通孔,-02为表面贴装)和镀层规格(如-F, -L, -S, -H)。
6. 应用信息:文档提供了应用指南,包括最小端子保持力、成型到位置的要求和包装信息。
7. 封装信息:描述了不同的封装选项,如管装、带式卷装等,并提供了相应的包装管和塞子信息。
IPL1-116-01-L-D-RA-K 价格&库存
很抱歉,暂时无法提供与“IPL1-116-01-L-D-RA-K”相匹配的价格&库存,您可以联系我们找货
    • 13+39.34413
    库存:50
