AMC36DAAN
AMC36DAAN
    SULLINS
    HI-TEMPCONNHDR.100DUAL72POS
AMC36DAAN 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO NO. DESCRIPTION DATE BY K 3749 UPGRADE PBT 1/12/2018 JH F F E E D D .200 5.08 B .050 1.27 A A C C HEAD .100 2.54 TAIL A .100 2.54 .025 0.64 .100 2.54 __C__D__N _ _ C _ _ D _ _ N-M500 _ _ C _ _ D _ _ N-M594 B SECTION A-A B A .100 2.54 .040 1.02 MIN .100 2.54 CUSTOMER COPY PCB LAYOUT RECOMMENDED A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. UL FLAMMABILITY RATING: 94V-0 5. DIELECTRIC WITHSTANDING VOLTAGE: 1800 VAC 6. CURRENT RATING: 3 AMPS 7. CONTACT RESISTANCE: 30 MILLIOHMS MAX. 8. INSULATION RESISTANCE: 5000 MEGOHMS MIN. 8 7 Pb RoHS COMPLIANT 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 9/8/2011 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE .100" MALE HEADER, STRAIGHT PART NUMBER SIZE C _ _C_ _D_ _N-(M500,M594) CAGE CODE 54453 SCALE: 3:1 3 A 2 DWG. NO. C10419 SHEET 1 OF 1 1 REV K FILE NAME: C10419, _ _C_ _D(AA,AB,AC,AD,AE,AF,AG,AH,AI,AJ,AK,FA,FB,FC,FD,FE,FF,FG,FH,FI,FJ,ZA,ZB,ZC,ZD,ZI,ZJ,ZO,ZQ,ZR)N-(OMIT,M500,M594)
AMC36DAAN 价格&库存
很抱歉,暂时无法提供与“AMC36DAAN”相匹配的价格&库存,您可以联系我们找货
