EEG.1K.308.CLL
EEG.1K.308.CLL
    LEMO(雷莫)
    EEG.1K.308.CLL
EEG.1K.308.CLL 数据手册
EEG.1K.308.CLL www.lemo.com SUMMARY # Wires Low voltage 8 Image is for illustrative purpose only Series 1K Termination type Female solder IP rating 68 when mated AWG wire size 30.00 - 22.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FGG.1K.308.CLAC60Z Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model EE*: Fixed receptacle, nut fixing (back panel mounting) Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 19.27 g Performance Configuration 1K.308 : 8 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 5 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Vtest (contact-shell): 1150 V (AC), 1630 V (DC) Vtest (contact-contact): 950 V (AC), 1340 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M N P S1 e mm. 20 20 6.2 27 3.5 25.1 10 14.5 M16x1.0 in. 0,79 0,79 0,24 1,06 0,14 0,99 0,39 0,57 RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.1E.M16.6 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.08.T22.059QGC TPR Grey CMN.08.T22.059QGZE TPR (medical) Grey CMN.08.T26.042QGZE TPR (medical) Grey 108220 PVC Black 108240 PTFE White 108260 PTFE White 16080 PVC Grey 180240 PVC Black 180260 PVC Black 280250 PVC Grey 335990 PVC Black 335991 PVC Black 42265 PVC Yellow 80140 PVC Grey 8050 PVC Black 8280 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
EEG.1K.308.CLL 价格&库存
很抱歉,暂时无法提供与“EEG.1K.308.CLL”相匹配的价格&库存,您可以联系我们找货
