SD-50J
SD-50J
    CUIDEVICES
    CONN CIRCULAR DIN 5 PIN FEMALE
SD-50J 数据手册
Additional Resources: Product Page | 3D Model date 02/19/2020 page 1 of 3 SERIES: SD-J │ DESCRIPTION: STANDARD DIN CONNECTOR FEATURES • plastic bushing • strain relief • 3~13 pin options RoHS PART NUMBER KEY SD - XX J Base Number Pin Options 30 = 3 pins 40 = 4 pins 50 = 5 pins 60 = 6 pins 70 = 7 pins 80 = 8 pins 81 = 8 pins 130 = 13 pins SPECIFICATIONS parameter conditions/description min rated input voltage max 100 rated input current contact resistance insulation resistance at 500 Vdc voltage withstand at 50/60Hz for 1 minute -5 yes cuidevices.com units Vac 2 A 50 mΩ 100 operating temperature RoHS typ MΩ 1,000 Vac 110 °C Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: SD-J │ DESCRIPTION: STANDARD DIN CONNECTOR date 02/19/2020 │ page 2 of 3 MECHANICAL DRAWINGS units: mm[inches] tolerance: ±0.1mm 35.5 1.398 11.8 0.465 MATERIAL PLATING pins brass silver shell steel nickel insulator (30~80, 130) PC insulator (81) ABS boot (30~80, 130) EVA boot (81) PE 24.5 0.965 15.8 0.622 0.7 0.028 7 3 8 5 6 1 4 2 45° 6.5 0.256 SD-30J 3 SD-40J 4 1 1 3 2 SD-50J 3 2 SD-60J 5 1 5 4 4 3 7 3 5 0.7 0.028 6 1 4 7 3 5 SD-81J 0.9 0.035 6 1 7 3 8 5 4 2 2 45° 8 60° 45° SD-80J SD-70J 45° cuidevices.com SD-130J 41° 6 1 4 2 45° 2 6 2 72° 1 2 3 4 1 5 6 7 8 12 9 10 11 13 Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: SD-J │ DESCRIPTION: STANDARD DIN CONNECTOR date 02/19/2020 │ page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 02/23/2006 1.01 new template applied 02/22/2012 1.02 corrected center pin positioning on SD-80J and SD-81J 10/01/2013 1.03 updated datasheet 05/13/2015 1.04 updated datasheet 09/08/2017 1.05 updated datasheet 07/24/2018 1.06 brand update 02/19/2020 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
SD-50J 价格&库存
很抱歉,暂时无法提供与“SD-50J”相匹配的价格&库存,您可以联系我们找货
