SDR-30
SDR-30
    CUIDEVICES
    CONN DIN 3PIN R/ANGLE PLUG
SDR-30 数据手册
Additional Resources: Product Page | 3D Model date 08/05/2022 page 1 of 3 SERIES: SDR | DESCRIPTION: STANDARD DIN CONNECTOR FEATURES • right angle • metal bushing • strain relief RoHS PART NUMBER KEY SDR - X X Base Number Pin Options 30 = 3 pins 50 = 5 pins 60 = 6 pins 70 = 7 pins 80 = 8 pins SPECIFICATIONS parameter conditions/description min rated input voltage typ rated input current contact resistance insulation resistance at 500 Vdc voltage withstand for 1 minute Vac A 30 mΩ MΩ -20 life 5,000 yes cuidevices.com units 1 100 operating temperature RoHS max 100 250 Vac 70 °C cycles Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: SDR | DESCRIPTION: STANDARD DIN CONNECTOR date 08/05/2022 | page 2 of 3 MECHANICAL DRAWINGS units: mm[inches] tolerance: ±0.2 mm MATERIAL PLATING pins brass nickel shell contact 1 steel nickel shell contact 2 steel nickel cap polyethylene insulator ABS resin cable protector PVC 18.3 0.720 9.0 0.354 30.5 1.201 22.5 0.886 6.0 0.236 SDR-50 SDR-30 45° 13.5 0.531 12.5 0.492 90° 13.5 0.531 16.0 0.630 SDR-60 12.5 0.492 16.0 0.630 SDR-70 SDR-80 45° 45° 60° 13.5 0.531 13.5 0.531 13.5 0.531 0.7 0.028 12.5 0.492 16.0 0.630 12.5 0.492 16.0 0.630 cuidevices.com 12.5 0.492 16.0 0.630 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: SDR | DESCRIPTION: STANDARD DIN CONNECTOR date 08/05/2022 | page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 09/01/2006 1.01 new template applied 01/30/2012 1.02 corrected center pin positioning on SDR-80, updated drawing 04/23/2015 1.03 updated datasheet 09/08/2017 1.04 brand update 02/19/2020 1.05 logo, datasheet style update 08/05/2022 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
SDR-30 价格&库存
很抱歉,暂时无法提供与“SDR-30”相匹配的价格&库存,您可以联系我们找货
