ERA.0S.403.CTL
ERA.0S.403.CTL
    LEMO(雷莫)
    ERA.0S.403.CTL
ERA.0S.403.CTL 数据手册
ERA.0S.403.CTL www.lemo.com SUMMARY # Wires High voltage 1 Image is for illustrative purpose only Series 0S Termination type Female solder High-Voltage IP rating 50 AWG wire size 30.00 - 22.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FFA.0S.403.CLAK52 Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model ERA*: Fixed receptacle, nut fixing Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 4.40 g Performance Configuration 0S.403 : 1 High Voltage Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Solder Test voltage (kV DC) 6 Test voltage (kV AC) 4.2 Air clearance min.: 6.8 mm Creepage distance min.: 7 mm Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A E L M e mm. 10 7 25 1.2 M9x0.6 in. 0,39 0,28 0,98 0,05 RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.0S.M09.4 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
ERA.0S.403.CTL 价格&库存
很抱歉,暂时无法提供与“ERA.0S.403.CTL”相匹配的价格&库存,您可以联系我们找货
