FGG.00.302.CLAD35Z
FGG.00.302.CLAD35Z
    LEMO(雷莫)
    FGG.00.302.CLAD35Z
FGG.00.302.CLAD35Z 数据手册
FGG.00.302.CLAD35Z www.lemo.com SUMMARY # Wires Low voltage 2 Image is for illustrative purpose only Series 00 Termination type Male solder IP rating 50 AWG wire size 34.00 - 28.00 Cable Ø 2.80 - 3.50 mm Status active Matching parts EGG.00.302.CLL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 3.93 g Performance Configuration 00.302 : 2 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 3.5 Amps Specifications Contact Type: Solder Contact Dia.: 0.5 mm (0.02in) Bucket Dia.: 0.4 mm (0.016in) Max. Solid Conductor: 0.09 mm^2 (AWG 28) Max. Stranded Conductor: 0.05 mm^2 (AWG 30) R (max): 8.7 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 950 V (AC), 1340 V (DC) Vtest (contact-contact): 1000 V (AC), 1400 V (DC) Others Salt Spray Corrosion: >1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 6.4 28.5 20.7 5.5 6 in. 0,25 1,12 0,81 0,22 0,24 RECOMMENDED BY LEMO Tools Caps: BFG.00.100.PCSG Cables CMN.02.T28.030PGCE CMN.02.T28.030PGZE PVC GREY Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 CMN.02.T28.030PNCE PVC Black PVC Grey CMN.02.T28.030PNZE 2080 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.00.302.CLAD35Z 价格&库存
很抱歉,暂时无法提供与“FGG.00.302.CLAD35Z”相匹配的价格&库存,您可以联系我们找货
