PKG.M1.0SL.LG
PKG.M1.0SL.LG
    LEMO(雷莫)
    PKG.M1.0SL.LG
PKG.M1.0SL.LG 数据手册
PKG.M1.0SL.LG www.lemo.com SUMMARY # Wires Low voltage 10 Image is for illustrative purpose only Series 1P Termination type Female solder IP rating 50 AWG wire size 0.00 - 28.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts PAG.M1.0SL.AC65G Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PK*: Fixed receptacle with two nuts (back panel mounting) Keying 1 key (alpha=0; Plug: male contact; Receptacle: female contact) Housing Material PEI (Polyetherimide), gray Variant G : Gray front nut Weight 5.31 g Performance Configuration 1P.M10 : 10 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 3 Amps Specifications Contact Type: Solder Contact Dia.: 0.5 mm (0.0201in) Bucket Dia.: 0.45 mm (0.018in) Max. Solid Conductor: 0.09 mm^2 (AWG 28) Max. Stranded Conductor: 0.09 mm^2 (AWG 28) R (max): 8.5 mOhm Test voltage (kV rms) Contact-contact: 0.85 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Air clearance min.: 0.45 mm Creepage distance min.: 0.45 mm Others Endurance (Shell): >2000 mating cycles Temp (min / max): -50°C / +170°C F ret (min): 50 N F ret (max): 150 N Steam sterilization: > 100 times (with potting on rear connection) DRAWINGS Dimensions A N a mm. 19.5 20.522.2 0-4.5 in. 0,77 0,81 0,00 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
PKG.M1.0SL.LG 价格&库存
很抱歉,暂时无法提供与“PKG.M1.0SL.LG”相匹配的价格&库存,您可以联系我们找货
PKG.M1.0SL.LG
    • 1+330.651261+42.37490
    • 10+319.0512610+40.88829
    • 25+298.1320325+38.20737
    • 50+279.7838250+35.85594
    库存:80
