FMN.2M.319.XLCT
www.lemo.com
SUMMARY
# Wires
Low voltage
19
Image is for illustrative purpose only
Series
2M
Termination type
Male crimp
IP rating
68 when mated
AWG wire size
26.00 - 22.00
Cable Ø
6.50 - 13.00 mm
Status
active
Matching parts
PMN.2M.319.XLMT
Download
Request a quote
Catalog
See video assembly instructions
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FM*: Straight plug, key (N) or keys (P, R, S, T, U, V, W and X) with knurled grip and mold
stop
Keying
3 keys (beta=165, gamma=30, plug: male contacts, receptacle: female contacts)
Housing Material
Aluminium (nickel plated [SAE AMS QQ N 290], anthracite color) shell and nut, other pieces
bronze/brass
Weight
10.77 g
Performance
Configuration
2M.319 : 19 Low Voltage
Insulator
L: PEEK
Rated Current
4 Amps
Specifications
Contact Type: Crimp
Contact Retention: 22 N
Contact Dia.: 0.7 mm (0.028in)
Bucket Dia.: 0.8 mm (0.031in)
Min. Conductor: 0.14 mm^2 (AWG 26)
Max. Conductor: 0.34 mm^2 (AWG 22)
R (max): 6.1 mOhm
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Test voltage (kV rms) Contact-contact: 1.2
Test voltage (kV rms) Contact-shell: 0.95
Others
Endurance (Shell): 3000 mating cycles
Temp (min / max): -20°C / +200°C
Humidity (max): 21 days at 95%
Gunfire vibration: 25 Hz - 2000 Hz, 3 axis (Apache helicopter)
Vibration-Sine: 30 g, 3 axes, 12 hr [10 Hz - 2000 Hz]
Vibration-Random: 37.8 g rms - 3 axes, 4 hr amb [50 Hz - 2000 Hz]
Shock Resistance: 300 g [ 3 ms]
Lighting strike EIA 364-75: 10K amps - 6 times
Thermal shock: 5 cycles: -65°C to +150°C
EMI Shielding EIA 364-66A: >= 80 dB (1 GHz), >=70 dB (3 GHz), >= 58 dB (6 GHz), >= 40 dB (10 GHz)
Salt Spray Corrosion: max. 48 hr
DRAWINGS
Dimensions
A
B
C
D
F
Lr
Ls
M
P
X
mm.
17.6
14
17.2
13
15.5
27.5
27.5
10.1
3.9
7.1
in.
0,69
0,55
0,68
0,51
0,61
1,08
1,08
0,40
0,15
0,28
RECOMMENDED BY LEMO
2/3
Tools
Crimp Tool:
DPC.91.701.V
Crimp settings:
AWG/Selector = 22-24-26/6-5-5
Positionner:
DCE.91.070.5MVC
Extractor:
DCF.93.070.4LT
Replacement contact:
FGN.0M.555.ZZC
3/3
很抱歉,暂时无法提供与“FMN.2M.319.XLCT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1085.577731+139.09857
