EXG.1B.307.HLN
EXG.1B.307.HLN
    LEMO(雷莫)
    EXG.1B.307.HLN
EXG.1B.307.HLN 数据手册
EXG.1B.307.HLN www.lemo.com SUMMARY # Wires Low voltage 7 Image is for illustrative purpose only Series 1B Termination type Female print PCB IP rating 50 AWG wire size 30.00 - 22.00 PCB Altium Pattern Cable Ø 0.00 - 0.00 mm PCB KiCad Pattern Status active Catalog Matching parts FGG.1B.307.CLAD42 Download Request a quote PCB Eagle Pattern TECHNICAL DETAILS Mechanics Shell Style/Model EX*: Elbow receptacle for printed circuit with two nuts (solder or screw fixing, back panel mounting) Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material PPS (Polyphenylene) shell, other pieces nickel plated [SAE AMS QQ N 290] brass Weight 14.57 g Performance Configuration 1B.307/EXG : 7 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 2 Amps Specifications Contact Type: Print (straight) Contact Dia.: 0.7 mm (0.028in) R (max): 6.1 mOhm Test voltage contact-contact : 1.45 kV rms Test voltage contact-body shell : 1.45 kV rms Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A B D E H I K L M N S3 e mm. 14 15 16.6 7.5 7.5 14 13.3 27 3.5 12.6 13 M11x0.5 in. 0,55 0,59 0,65 0,30 0,30 0,55 0,52 1,06 0,14 0,50 0,51 RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.65.120.AZ LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
EXG.1B.307.HLN 价格&库存
很抱歉,暂时无法提供与“EXG.1B.307.HLN”相匹配的价格&库存,您可以联系我们找货
