FGG.2B.312.CLAD52Z
FGG.2B.312.CLAD52Z
    LEMO(雷莫)
    CONN INLINE PLUG 12PIN SLD CUP
FGG.2B.312.CLAD52Z 数据手册
FGG.2B.312.CLAD52Z www.lemo.com SUMMARY # Wires Low voltage 12 Image is for illustrative purpose only Series 2B Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Catalog Cable Ø 4.30 - 5.20 mm See video assembly instructions Status active Matching parts EGG.2B.312.CLL Download Request a quote Eplan TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 29.81 g Performance Configuration 2B.312 : 12 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 7 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 1350 V (AC), 1910 V (DC) Vtest (contact-contact): 1250 V (AC), 1770 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 15 49 37 13 12 in. 0,59 1,93 1,46 0,51 0,47 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.2B.ZZZ.PA120 Caps: BFG.2B.100.PCSG Cables 12050 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.2B.312.CLAD52Z 价格&库存
很抱歉,暂时无法提供与“FGG.2B.312.CLAD52Z”相匹配的价格&库存,您可以联系我们找货
FGG.2B.312.CLAD52Z
    • 1+642.511941+76.06248
    • 10+619.9695110+73.39384
    库存:23
