8
7
6
2
2
1
F
3
3
2
4
2
1
2-#20
3
3-#20
1
4
5
3
4
5 2
3
5
1
1
6
4-#22
5-#26
CONTACT ARRANGEMENTS
PANEL CONNECTOR REAR (WIRING SIDE) VIEW
4
3
2
4
SPECIFICATIONS:
2
MECHANICAL
Life:600 cycles minimum
Vibration: Mil-Std 202G Method 201A
Hex Nut Tongue: 5-6 in-lb
5
1
6-#26
7
7-#26
6
0.375 MIN.
9.53
Strip cable end and conductors as shown.
E
0.188±0.015
4.78±0.38
EN2 PANEL-MOUNT
CONNECTOR
Connector Type:
C - Cord
P - Panel*
L - In-Line**
Packaging Options:
Leave blank for Bulk
K - Kit (one unit/bag)
# of Contacts:
2-3 for #20
4 for #22
5-7 for #26
Coupling Ring option:
Leave blank for Ribbed
W - Winged
Gender:
M - Male
F - Female
SOLDER OR CRIMP
ENVIRONMENTAL
Operating Temperature Limits:-40ºC to +85ºC (-40ºF to +185°F),
see Current Rating Table.
Moisture Resistance: Mil-Std 202G Method 106G
Insulation Resistance: Mil-Std 202G Method 302
Thermal Shock: Mil-Std 202G Method 107G
Salt Atmosphere (Corrosion): Mil-Std 202G Method 101E
Wearthetight Ratings:
IP16, IP18, IP66, IP67, IP68 per IEC60529
NEMA 250 (6P), CFR 46 Part 110.20
EN2
CABLE
D Soldering or crimping conductors to contacts is recommended before insertion into connector.
If crimping, use hand or pneumatic crimp tool with crimp positioner per contact size.
If soldering after contacts are inserted in the connector, limit exposure of contacts
to soldering iron temperature to 4 sec. maximum. Soldering iron temperature should
not exceed 650°F (343°C).
Grommet Code - Cable O.D. Range:
DC - Daisy Chain (all 3 sizes)
G1 - 0.100-0.140 (2.5-3.6)
G2 - 0.140-0.180 (3.6-4.6)
G3 - 0.180-0.220 (4.6-5.6)
Contacts
2 #20
3 #20
0.250 MAX PANEL THICKNESS
6.35
4 #22
5-7 #26
Wire
(awg)
24
26
24
26
24
26
26
28
30
Current Rating (A)
at Operating Temperature (°C)
45°C max. 55°C max. 65°C max. 75°C max. 85°C max.
7
6
5
4
3.5
5.5
5
4
3
2.5
5.5
5
4
3
2.5
4
3.5
2.5
2
1
6.5
5.5
4.5
3.5
2
5
4.5
3.5
3
1.5
5
4.5
3.5
3
1.5
3
2.5
2
1.5
0.5
5
4.5
3.5
3
1.5
4.5
4
3
2
1
4.5
4
3
2
1
3
2.5
2
1.5
0.5
3
2.5
2
1.5
1
2.5
2
1.5
1
0.5
2
1.5
1
0.5
0.5
C
D
C
SOCKET CONTACTS
(FEMALE)
PIN CONTACTS
(MALE)
Insert wired contacts into connector housing using an insertion tool and per contacts arrangements.
Align and install connector into panel cut-out. Tighten hex nut 5 -6 in-lb.
0.790
20.07
0.588
14.94
0.625
15.88
0.200 [5.1] TYP
0.15 [3.8] FOR 5-7 #26 CONTACTS
0.20 [5.1] TYP
0.401
10.19
0.620
15.75
0.430
10.92
0.716
18.18
B
0.202 [5.1] BEFORE PANEL MOUNTING,
REDUCED BY 0.010 [0.25] AFTER MOUNTING
PC TAIL TYPE CONTACTS
SOLDER OR CRIMP TYPE CONTACTS
0.107
2.72
PIN 1 INDICATOR
TOOL
TOOL TYPE
EN3CR
HAND CRIMP TOOL
EN3CRAUTO
PNEUMATIC CRIMP TOOL
HAND CRIMP TOOL
LARGE FRAME
EN2CRL
EN2CRAUTOL
LARGE FRAME
EN3INS20
EN3INS26
CONTACT
INSERTION/EXTRUCTION
8
POSITIONER
CONTACT SIZE
WIRE SIZES
EN2POS20
EN3POS26
EN2POS20
EN3POS26
20 and 22
26
20 and 22
26
20 and 22 AWG
26, 28, and 30 AWG
20 and 22 AWG
26, 28, and 30 AWG
EN2POS20L
20 and 22
20, 22, 24, and 26 AWG
7
20 and 22
26
CUSTOMER DRAWING
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
UNLESS OTHERWISE SPECIFIED
SPECS UPDATED
10/03/13 PNK
WIDTH
MULT
- TWO PLACE DECIMALS
0.02
- THREE PLACE DECIMALS
0.005
09/20/12 PNK
SRC
TOOLS REVISED
05/14/12 PNK
DATE DRAWN
BY
CHKD
APVD
0A
PRELIMINARY
02/09/12 PNK
02/09/12
PNK
PNK
02/09/12
SRC
02/09/12
REV
ECO NUMBER
4
APVD
1.5:1
NAME
DO NOT SCALE DRAWING
SolidWorks CAD File
A
SPEC No.
SPECS UPDATED
BY
TEMPER
SCALE
0B
DATE
LBS/M
MATERIAL
SPEC No.
FIRST USED ON
0C
REVISIONS
5
SRC
SIZE
FINISH
1. ALL DIMENSIONS IN INCHES
0D
6
B
RECOMMENDED
PANEL CUT-OUT
±0.003 [±0.08]
0.140
3.56
ALL DIMENSIONS FOR REFERENCE ONLY
A
E
MATERIAL
Connector Housing ----- Thermoplastic, black
Hex Nut: ------------------- Thermoplastic, black
Coupling Ring ------------ Thermoplastic, black
Cable Clamp -------------- Thermoplastic, black
Handle (back-shell) ----- Thermoplastic, black
Insulator ------------------- Elastomer, black
Seal Grommet ----------- Elastomer, black
Contacts ------------------- Copper Alloy, plated
Contact Size:
Contact Style:
20 - #20
Leave blank for Solder or Crimp
22 - #22
P - PC tail (Panel connectors only)
26 - #26
* for mating Cord connectors refer to EN2C SERIES drawing.
** Mating In-Line connectors not currently available.
CONTACTS
F
ELECTRICAL
Voltage Rating: 250 V AC/DC for 2 contact arrangement
125 V AC/DC for 3-7 contact arrangements
Insulation Resistance: 1000 mΩ minimum
Contact Resistance: 10 mΩ maximum
Current Rating: Refer to Current Rating Table
PART NUMBER SCHEME:
EN2 PANEL CONNECTOR FIELD ASSEMBLY INSTRUCTIONS:
1
EN2P SERIES CONNECTORS, RoHS
C
SHEET
PART No.
1
OF
EN2P SERIES
2
REV
0D
8
7
6
5
0.099
2.51
0.114
2.90
3
2
1
0.049
1.25
2
0.057
1.45
F
4
0.200
5.08
TYP
0.057
1.45
1
0.029
0.72
0.040
1.02
TYP
2
1
3
E
0.100
2.54
2 and 3-#20
PIN ARRANGEMENTS
(0.046 [1.17] RECOMMENDED PCB HOLE SIZE)
3-#20
2-#20
E
0.200
5.08
TYP
0.050
1.27
3
F
2
D
D
0.100
2.54
4
0.040
1.02
TYP
0.050
1.27
1
4-#22
PIN ARRANGEMENT
4-#22
C
30° TYP
30° TYP
3
4
3
4
0.164
4.17
5
2
B
1
C
30° TYP
3
4
0.164
4.17
0.164
4.17
5
2
6
1
5
2
6
0.020
0.51
TYP
1
7
5-#26
0.150
3.81
TYP
6-#26
B
5, 6, and 7-#26
PIN ARRANGEMENTS
(0.026 [0.66] RECOMMENDED PCB HOLE SIZE)
7-#26
CUSTOMER DRAWING
A
PANEL CONNECTOR FRONT VIEW (PCB COMPONENT SIDE)
(RECOMMENDED PCB HOLE LAYOUT WITHIN ±0.001 [0.025])
SPECS UPDATED
REV
ECO NUMBER
10/03/13 PNK
DATE
REVISIONS
8
7
6
5
4
BY
0.02
MULT
0.005
TEMPER
A
SPEC No.
SCALE
1.5:1
DATE DRAWN
BY
CHKD
APVD
02/09/12
PNK
PNK
02/09/12
SRC
02/09/12
NAME
SolidWorks CAD File
LBS/M
MATERIAL
SPEC No.
FIRST USED ON
SRC
APVD
WIDTH
FINISH
OD
SIZE
C
SHEET
PART No.
2
OF
EN2P SERIES
2
REV
0D
很抱歉,暂时无法提供与“EN2P4M22PK”相匹配的价格&库存,您可以联系我们找货
