12GM6MX
12GM6MX
    SWITCHCRAFT
    12GM6MX
12GM6MX 数据手册
0.056 1.4 2 2 3 1 0.276 7.0 TYP 3X 72° 45° 5 4 3 2 3 1 4 1 3 4 5 45° 60° 60° 4 3 5 2 30° 6 5 7 6 45° 45° 0.028 0.7 4 3 1 30° 1 5 2 4 3 2 1 2 45° 1 8 7 5 2 0.035 0.9 4 3 1 6 6 8 45° 41° 7 0.335 8.5 05GM3MX 05GM5MX 3 PINS AT 180 5 PINS AT 180 09GM4MX 4 PINS AT 216 12GM5MX 12GM6MX 5 PINS AT 240 15GM7MX 6 PINS AT 240 15GM8MX 7 PINS AT 270 20GM8MX 8 PINS AT 270 8 PINS AT 262 2.30 58.5 0.83 21.0 0.24 6.2 1.48 37.5 0.35 9.0 0.67 17.0 0.59 15.0 0.54 MAX 13.6 NOTES: CUSTOMER DRAWING 1. PARTS SHIPPED UNASSEMBLED: TWO PIECE METAL SHELL, PIN & INSERT ASSEMBLY AND HANDLE WITH FLEX RELIEF. 2. THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED 0.04 [1.0mm] x 0.12 [3.0mm] DEEP HOLE IN PIN FOR SOLDERING. 3. MATERIALS: HOUSING - THERMOPLASTIC, GREY FLEX RELIEF - THERMOPLASTIC, GREY TWO PIECE SHELL WITH CABLE CLAMP - STEEL, NICKEL PLATED INSERT - THERMOPLASTIC, BLACK PINS - COPPER ALLOY, TIN PLATED 4. THESE PRODUCTS ARE RoHS COMPLIANT. 1. ALL DIMENSIONS IN INCHES SIZE REV 26000 ECO NUMBER 3/3/06 DATE REVISIONS TJK BY - TWO PLACE DECIMALS 0.02 - THREE PLACE DECIMALS 0.005 4-29-13 DO NOT SCALE DRAWING SolidWorks CAD File NAME TEMPER BY TO SPEC No. SCALE 2:1 CHKD TO 4-29-13 APVD TJK 5-1-13 MALE DIN, 3-8 PIN CORD PLUG, PLASTIC HANDLE, RoHS B LBS/M MATERIAL SPEC No. FIRST USED ON TJK APVD MULT FINISH DATE DRAWN A WIDTH SHEET PART No. 1 OF 1 05GM_MX, 09GM_MX 12GM_MX, 15GM_MX, 20GM_MX REV A
12GM6MX 价格&库存
很抱歉,暂时无法提供与“12GM6MX”相匹配的价格&库存,您可以联系我们找货
12GM6MX
    • 1+128.066631+16.59988
    • 10+108.8236010+14.10561
    • 25+102.0065225+13.22199
    库存:48
