PKG.M0.6SL.LG
PKG.M0.6SL.LG
    LEMO(雷莫)
    PKG.M0.6SL.LG
PKG.M0.6SL.LG 数据手册
PKG.M0.6SL.LG www.lemo.com SUMMARY # Wires Low voltage 6 Image is for illustrative purpose only Series 1P Termination type Female solder IP rating 50 AWG wire size 0.00 - 26.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts PAG.M0.6SL.AC52G Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PK*: Fixed receptacle with two nuts (back panel mounting) Keying 1 key (alpha=0; Plug: male contact; Receptacle: female contact) Housing Material PEI (Polyetherimide), gray Variant G : Gray front nut Weight 4.91 g Performance Configuration 1P.M06 : 6 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 6 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.0275in) Bucket Dia.: 0.6 mm (0.024in) Max. Solid Conductor: 0.14 mm^2 (AWG 26) Max. Stranded Conductor: 0.14 mm^2 (AWG 26) R (max): 6.5 mOhm Test voltage (kV rms) Contact-contact: 1.05 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Air clearance min.: 0.85 mm Creepage distance min.: 0.85 mm Others Endurance (Shell): >2000 mating cycles Temp (min / max): -50°C / +170°C F ret (min): 50 N F ret (max): 150 N Steam sterilization: > 100 times (with potting on rear connection) DRAWINGS Dimensions A N a mm. 19.5 20.522.2 0-4.5 in. 0,77 0,81 0,00 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
PKG.M0.6SL.LG 价格&库存
很抱歉,暂时无法提供与“PKG.M0.6SL.LG”相匹配的价格&库存,您可以联系我们找货
PKG.M0.6SL.LG
    • 1+221.592361+28.39335
    • 10+213.8177610+27.39716
    • 25+199.7978825+25.60075
    • 50+187.5038250+24.02547
    • 100+176.63656100+22.63301
    库存:98
