EGG.0B.306.CLL
EGG.0B.306.CLL
    LEMO(雷莫)
    EGG.0B.306.CLL
EGG.0B.306.CLL 数据手册
EGG.0B.306.CLL www.lemo.com SUMMARY # Wires Low voltage 6 Image is for illustrative purpose only Series 0B Termination type Female solder IP rating 50 AWG wire size 34.00 - 28.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FGG.0B.306.CLAD52 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model EG*: Fixed receptacle, nut fixing Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 4.25 g Performance Configuration 0B.306 : 6 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 2.5 Amps Specifications Contact Type: Solder Contact Dia.: 0.5 mm (0.02in) Bucket Dia.: 0.45 mm (0.018in) Max. Solid Conductor: 0.09 mm^2 (AWG 28) Max. Stranded Conductor: 0.09 mm^2 (AWG 28) R (max): 8.7 mOhm Vtest (contact-shell): 650 V (AC), 920 V (DC) Vtest (contact-contact): 850 V (AC), 1200 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M N S1 S3 e mm. 10 12.5 7 20.7 1.2 19.1 8.2 11 M9x0.6 in. 0,39 0,49 0,28 0,81 0,05 0,75 0,32 0,43 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.06.T28.031PGCE PVC CMN.06.T28.031PGZE CMN.06.T28.031PNCE GREY Grey PVC Black CMN.06.T28.031PNZE CMN.06.T28.042QBCE TPR (medical) CMN.06.T28.044PGZE Grey CMN.06.T28.044PNZE 12080 PVC Grey 6280 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
EGG.0B.306.CLL 价格&库存
很抱歉,暂时无法提供与“EGG.0B.306.CLL”相匹配的价格&库存,您可以联系我们找货
EGG.0B.306.CLL
  • 1+251.174931+32.49332
  • 10+213.4644710+27.61489
  • 30+197.5443930+25.55539
  • 50+190.5522250+24.65084
  • 100+181.46389100+23.47513
  • 250+170.11463250+22.00693
  • 500+162.00749500+20.95815
库存:232
EGG.0B.306.CLL
  • 1+160.11275
  • 5+157.48846
  • 25+153.10424
  • 50+148.16808
库存:29
