PAG.M1.4GL.AC52J
www.lemo.com
SUMMARY
# Wires
Low voltage
14
Image is for illustrative purpose only
Series
1P
Termination type
Male solder
IP rating
50
AWG wire size
0.00 - 28.00
Cable Ø
4.00 - 5.20 mm
Status
active
Matching parts
PLG.M1.4GL.LJ
Download
Request a quote
Eplan
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
PA*: Straight plug with cable collet
Keying
1 key (alpha=0; Plug: male contact; Receptacle: female contact)
Housing Material
PSU (Polysulfone), gray
Variant
J : Yellow collet nut
Weight
4.99 g
Performance
Configuration
1P.M14 : 14 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
2 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.5 mm (0.0201in)
Bucket Dia.: 0.45 mm (0.018in)
Max. Solid Conductor: 0.09 mm^2 (AWG 28)
Max. Stranded Conductor: 0.09 mm^2 (AWG 28)
R (max): 8.5 mOhm
Test voltage (kV rms) Contact-contact: 0.6
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Air clearance min.: 0.5 mm
Creepage distance min.: 0.5 mm
Others
Endurance (Shell): >2000 mating cycles
Temp (min / max): -50°C / +150°C
F ret (min): 50 N
F ret (max): 150 N
Steam sterilization: > 100 times (with potting on rear connection)
DRAWINGS
RECOMMENDED BY LEMO
Tools
2/2
很抱歉,暂时无法提供与“PAG.M1.4GL.AC52J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+289.949651+37.51604
- 国内价格 香港价格
- 1+262.503411+33.64135
- 10+253.2951810+32.46126
- 25+236.6895425+30.33315
- 50+222.1255050+28.46669
- 100+209.24421100+26.81587
