ERA.1S.303.CLL
ERA.1S.303.CLL
    LEMO(雷莫)
    ERA.1S.303.CLL
ERA.1S.303.CLL 数据手册
ERA.1S.303.CLL www.lemo.com SUMMARY # Wires Low voltage 3 Image is for illustrative purpose only Series 1S Termination type Female solder IP rating 50 AWG wire size 30.00 - 22.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FFA.1S.303.CLAC32 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model ERA*: Fixed receptacle, nut fixing Keying Hermaphroditic keying (half moon insert) with female pin 1 Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 8.28 g Performance Configuration 1S.303 : 3 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.0354in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm Vtest: 1200 V (AC), 1800 V (DC) Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M S1 S3 e mm. 14 16 7.5 21 1.5 10.5 14 M12x1.0 in. 0,55 0,63 0,30 0,83 0,06 0,41 0,55 RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.1S.M12.4 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.03.T28.031PGCE PVC CMN.03.T28.031PGZE CMN.03.T28.031PNCE GREY Grey PVC Black 130240 PVC Black 130250 PVC Grey 30110 PVC Grey 30141 PVC Grey 30260 PVC Black 3041 PVC Grey 3050 PVC Black 3081 PVC Black 3220 PVC Black 3280 PVC Black 60080 PVC Grey CMN.03.T28.031PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
ERA.1S.303.CLL 价格&库存
很抱歉,暂时无法提供与“ERA.1S.303.CLL”相匹配的价格&库存,您可以联系我们找货
