FFA.0S.303.CLAC32
FFA.0S.303.CLAC32
    LEMO(雷莫)
    CONN INLINE PLUG 3PIN SLD CUP
FFA.0S.303.CLAC32 数据手册
FFA.0S.303.CLAC32 www.lemo.com SUMMARY # Wires Low voltage 3 Image is for illustrative purpose only Series 0S Termination type Male solder IP rating 50 AWG wire size 32.00 - 24.00 Cable Ø 2.30 - 3.20 mm Status active Matching parts ERA.0S.303.CLL Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet Keying Hermaphroditic keying (half moon insert) with male pin 1 Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 7.79 g Performance Configuration 0S.303 : 3 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 7 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Max. Solid Conductor: 0.25 mm^2 (AWG 24) Max. Stranded Conductor: 0.14 mm^2 (AWG 26) R (max): 6.1 mOhm Vtest: 1060 V (AC), 1500 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 9 34.5 24.5 6.5 in. 0,35 1,36 0,96 0,26 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.0S.ZZZ.PA065 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.03.T28.031PGCE PVC CMN.03.T28.031PGZE CMN.03.T28.031PNCE GREY Grey PVC Black 30141 PVC Grey 3041 PVC Grey 3050 PVC Black 3081 PVC Black CMN.03.T28.031PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.0S.303.CLAC32 价格&库存
很抱歉,暂时无法提供与“FFA.0S.303.CLAC32”相匹配的价格&库存,您可以联系我们找货
