FGG.0B.305.CLAZ
FGG.0B.305.CLAZ
    LEMO(雷莫)
    FGG.0B.305.CLAZ
FGG.0B.305.CLAZ 数据手册
FGG.0B.305.CLAZ www.lemo.com SUMMARY # Wires Low voltage 5 Image is for illustrative purpose only Series 0B Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts EGG.0B.305.CLL Download Request a quote Catalog See video assembly instructions PHG.0B.305.CLLZ TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 7.80 g Performance Configuration 0B.305 : 5 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 6.5 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Vtest (contact-shell): 700 V (AC), 1000 V (DC) Vtest (contact-contact): 1000 V (AC), 1400 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr 12NC part number: 4022.438.33237 DRAWINGS Dimensions A L M S1 S2 mm. 9.5 36 26 8 7 in. 0,37 1,42 1,02 0,31 0,28 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.0B.005.PA070 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Caps: BFG.0B.100.PCSG LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.0B.305.CLAZ 价格&库存
很抱歉,暂时无法提供与“FGG.0B.305.CLAZ”相匹配的价格&库存,您可以联系我们找货
FGG.0B.305.CLAZ
  • 1+337.817091+43.72690
  • 10+287.1167710+37.16428
  • 30+265.7075330+34.39307
  • 50+256.3074050+33.17633
  • 100+244.08437100+31.59418
  • 250+228.82249250+29.61869
库存:49
FGG.0B.305.CLAZ
    • 1+220.986951+28.33204
    库存:2
