EDN.2M.310.XLM
www.lemo.com
SUMMARY
# Wires
Low voltage
10
Image is for illustrative purpose only
Series
2M
Termination type
Female crimp
IP rating
68 when mated
AWG wire size
24.00 - 20.00
Cable Ø
6.50 - 13.00 mm
Status
active
Matching parts
FMN.2M.310.XLC
Download
Request a quote
Eplan
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
ED*: Fixed receptacle with square flange
Keying
3 keys (beta=165, gamma=30, plug: male contacts, receptacle: female contacts)
Housing Material
Aluminium (nickel plated [SAE AMS QQ N 290], anthracite color) shell and nut, other pieces
bronze/brass
Weight
8.59 g
Performance
Configuration
2M.310 : 10 Low Voltage
Insulator
L: PEEK
Rated Current
8 Amps
Specifications
Contact Type: Crimp
Contact Retention: 30 N
Contact Dia.: 0.9 mm (0.035in)
Bucket Dia.: 1.1 mm (0.043in)
Min. Conductor: 0.25 mm^2 (AWG 24)
Max. Conductor: 0.5 mm^2 (AWG 20)
R (max): 4.8 mOhm
Test voltage (kV rms) Contact-contact: 1.8
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Test voltage (kV rms) Contact-shell: 1.2
Others
Endurance (Shell): 3000 mating cycles
Temp (min / max): -20°C / +200°C
Humidity (max): 21 days at 95%
Gunfire vibration: 25 Hz - 2000 Hz, 3 axis (Apache helicopter)
Vibration-Sine: 30 g, 3 axes, 12 hr [10 Hz - 2000 Hz]
Vibration-Random: 37.8 g rms - 3 axes, 4 hr amb [50 Hz - 2000 Hz]
Shock Resistance: 300 g [ 3 ms]
Lighting strike EIA 364-75: 10K amps - 6 times
Thermal shock: 5 cycles: -65°C to +150°C
EMI Shielding EIA 364-66A: >= 80 dB (1 GHz), >=70 dB (3 GHz), >= 58 dB (6 GHz), >= 40 dB (10 GHz)
Salt Spray Corrosion: max. 48 hr
DRAWINGS
Dimensions
A
B
C
G
H
K
Lr
Ls
N
P
SV
mm.
26.9
8.95
17.2
12.8
15.1
1.5
18.3
18.3
20.6
5.3
3.3
in.
1,06
0,35
0,68
0,50
0,59
0,06
0,72
0,72
0,81
0,21
0,13
RECOMMENDED BY LEMO
2/3
Tools
Crimp Tool:
DPC.91.701.V
Crimp settings:
AWG/Selector = 20-22-24/6-5-5
Positionner:
DCE.91.090.3MVM
Extractor:
DCC.09.05B.LAG
Replacement contact:
EGN.0M.660.ZZM
3/3
很抱歉,暂时无法提供与“EDN.2M.310.XLM”相匹配的价格&库存,您可以联系我们找货
