ERA.3S.410.CTL
ERA.3S.410.CTL
    LEMO(雷莫)
    ERA.3S.410.CTL
ERA.3S.410.CTL 数据手册
ERA.3S.410.CTL www.lemo.com SUMMARY # Wires High voltage 1 Image is for illustrative purpose only Series 3S Termination type Female solder High-Voltage IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FFB.3S.410.CTAC10 Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model ERA*: Fixed receptacle, nut fixing Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 28.54 g Performance Configuration 3S.410 : 1 High Voltage Insulator T: PTFE Rated Current 10 Amps Specifications Contact Type: Solder Test voltage (kV DC) 15 Test voltage (kV AC) 10.5 Creepage distance min.: 16.5 mm Others Endurance (Shell): 5000 mating cycles LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A E L M e mm. 22 11.5 46.5 2 M18x1.0 in. 0,87 0,45 1,83 0,08 RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.65.200.AZ LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
ERA.3S.410.CTL 价格&库存
很抱歉,暂时无法提供与“ERA.3S.410.CTL”相匹配的价格&库存,您可以联系我们找货
ERA.3S.410.CTL
