EGG.2B.319.CLL
EGG.2B.319.CLL
    LEMO(雷莫)
    CONN PNL MNT RCPT 19SKT SLD CUP
EGG.2B.319.CLL 数据手册
EGG.2B.319.CLL www.lemo.com SUMMARY # Wires Low voltage 19 Image is for illustrative purpose only Series 2B Termination type Female solder IP rating 50 AWG wire size 30.00 - 22.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FGG.2B.319.CLAD82 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model EG*: Fixed receptacle, nut fixing Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 15.72 g Performance Configuration 2B.319 : 19 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 5 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Vtest (contact-shell): 1250 V (AC), 1770 V (DC) Vtest (contact-contact): 950 V (AC), 1340 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M N S1 S3 e mm. 18 19.5 8.5 26.7 1.8 24.6 13.5 17 M15x1.0 in. 0,71 0,77 0,33 1,05 0,07 0,97 0,53 0,67 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.19.T22.079QGZE TPR (medical) Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
EGG.2B.319.CLL 价格&库存
很抱歉,暂时无法提供与“EGG.2B.319.CLL”相匹配的价格&库存,您可以联系我们找货
EGG.2B.319.CLL
  • 1+548.53885
  • 5+546.51371
  • 25+519.77177
  • 50+517.50362
库存:19
EGG.2B.319.CLL
    库存:5
