ECG.2B.316.CLV
ECG.2B.316.CLV
    LEMO(雷莫)
    CONN PNL MNT RCPT 16SKT R/A PCB
ECG.2B.316.CLV 数据手册
ECG.2B.316.CLV www.lemo.com SUMMARY # Wires Low voltage 16 Image is for illustrative purpose only Series 2B Termination type Female print 90° PCB IP rating 50 AWG wire size 30.00 - 22.00 PCB Altium Pattern Cable Ø 0.00 - 0.00 mm PCB KiCad Pattern Status active Catalog Matching parts FGG.2B.316.CLAD42Z Download Request a quote PCB Eagle Pattern TECHNICAL DETAILS Mechanics Shell Style/Model EC*: Fixed receptacle with two nuts and elbow contacts for printed circuit (back panel mounting) Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 20.10 g Performance Configuration 2B.316 : 16 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current Specifications Contact Type: Print (elbow) Contact Dia.: 0.7 mm (0.028in) R (max): 6.1 mOhm Vtest (contact-shell): 1250 V (AC), 1770 V (DC) Vtest (contact-contact): 950 V (AC), 1340 V (DC) Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E M Nmax S1 S3 e mm. 20 19.2 6.5 3.5 22.3 13.5 17 M15x1.0 in. 0,79 0,76 0,26 0,14 0,88 0,53 0,67 RECOMMENDED BY LEMO Tools Spanner 2: DCH.91.201.PA Spanner wrench: Socket for torque wrench DCM.65.170.AZ and DCM.2S.M15.6 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
ECG.2B.316.CLV 价格&库存
很抱歉,暂时无法提供与“ECG.2B.316.CLV”相匹配的价格&库存,您可以联系我们找货
