PES.0M.305.XLCT
PES.0M.305.XLCT
    LEMO(雷莫)
    PES.0M.305.XLCT
PES.0M.305.XLCT 数据手册
PES.0M.305.XLCT www.lemo.com SUMMARY # Wires Low voltage 5 Image is for illustrative purpose only Series 0M Termination type Male crimp IP rating 68 when mated AWG wire size 26.00 - 22.00 Cable Ø 4.00 - 8.00 mm Status active Matching parts FMS.0M.305.XLMT Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PE*: Fixed receptacle, nut fixing and mold stop Keying 3 keys (beta=155, gamma=50, plug: female contacts, receptacle: male contacts) Housing Material Aluminium (nickel plated [SAE AMS QQ N 290], anthracite color) shell and nut, other pieces bronze/brass Weight 7.80 g Performance Configuration 0M.305 : 5 Low Voltage Insulator L: PEEK Rated Current 6.5 Amps Specifications Contact Type: Crimp Contact Retention: 22 N Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Min. Conductor: 0.14 mm^2 (AWG 26) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Test voltage (kV rms) Contact-contact: 1.25 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Test voltage (kV rms) Contact-shell: 1 Others Endurance (Shell): 3000 mating cycles Temp (min / max): -20°C / +200°C Humidity (max): 21 days at 95% Gunfire vibration: 25 Hz - 2000 Hz, 3 axis (Apache helicopter) Vibration-Sine: 30 g, 3 axes, 12 hr [10 Hz - 2000 Hz] Vibration-Random: 37.8 g rms - 3 axes, 4 hr amb [50 Hz - 2000 Hz] Shock Resistance: 300 g [ 3 ms] Lighting strike EIA 364-75: 10K amps - 6 times Thermal shock: 5 cycles: -65°C to +150°C EMI Shielding EIA 364-66A: >= 80 dB (1 GHz), >=70 dB (3 GHz), >= 58 dB (6 GHz), >= 40 dB (10 GHz) Salt Spray Corrosion: max. 48 hr DRAWINGS Dimensions A B C D E Lr Ls M P R S1 S2 e mm. 17 8.8 16.8 8 5 25.6 25.6 9.7 5.3 13.8 11.5 14 M13x0.75 in. 0,67 0,35 0,66 0,31 0,20 1,01 1,01 0,38 0,21 0,54 0,45 0,55 RECOMMENDED BY LEMO LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Tools Crimp Tool: DPC.91.701.V Crimp settings: AWG/Selector = 22-24-26/6-5-5 Positionner: DCE.91.070.5MVC Extractor: DCF.93.070.4LT Replacement contact: FGN.0M.555.ZZC Spanner wrench: Socket for torque wrench DCM.65.140.AZ LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
PES.0M.305.XLCT 价格&库存
很抱歉,暂时无法提供与“PES.0M.305.XLCT”相匹配的价格&库存,您可以联系我们找货
