FGG.3B.322.CLAD10
FGG.3B.322.CLAD10
    LEMO(雷莫)
    FGG.3B.322.CLAD10
FGG.3B.322.CLAD10 数据手册
FGG.3B.322.CLAD10 www.lemo.com SUMMARY # Wires Low voltage 22 Image is for illustrative purpose only Series 3B Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Catalog Cable Ø 9.30 - 10.00 mm See video assembly instructions Status active Matching parts EGG.3B.322.CLL Download Request a quote Eplan TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 45.53 g Performance Configuration 3B.322 : 22 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 5.5 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Vtest (contact-shell): 900 V (AC), 1270 V (DC) Vtest (contact-contact): 1000 V (AC), 1400 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 18 58 43 15 14 in. 0,71 2,28 1,69 0,59 0,55 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.3B.ZZZ.PA140 Caps: BFG.3B.100.PCSG LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.3B.322.CLAD10 价格&库存
很抱歉,暂时无法提供与“FGG.3B.322.CLAD10”相匹配的价格&库存,您可以联系我们找货
