FGG.3B.308.CYCD10Z
FGG.3B.308.CYCD10Z
    LEMO(雷莫)
    8 Position Circular Connector Plug, Male Pins Crimp Gold
FGG.3B.308.CYCD10Z 数据手册
FGG.3B.308.CYCD10Z www.lemo.com SUMMARY # Wires Low voltage 8 Image is for illustrative purpose only Series 3B Termination type Male crimp IP rating 50 AWG wire size 20.00 - 18.00 Cable Ø 9.30 - 10.00 mm Status active Matching parts EGG.3B.308.CYM Download Request a quote Catalog See video assembly instructions TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Performance Configuration 3B.308 : 8 Low Voltage Insulator Y: PEEK for crimp contacts Rated Current 13 Amps Specifications Contact Type: Crimp Contact Retention: 40 N Contact Dia.: 1.3 mm (0.051in) Bucket Dia.: 1.4 mm (0.055in) Min. Conductor: 0.5 mm^2 (AWG 20) Max. Conductor: 1 mm^2 (AWG 18) R (max): 3.6 mOhm Vtest (contact-shell): 1750 V (AC), 2500 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-contact): 1850 V (AC), 2600 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 18 56.5 41.5 15 15 in. 0,71 2,22 1,63 0,59 0,59 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Crimp Tool: DPC.91.701.V Crimp settings: AWG/Selector = 18-20/8-7 Positionner: DCE.91.133.BVC Extractor: DCC.13.15B.LAG Replacement contact: FGG.3B.565.ZZC Spanner wrench: DCD.3B.ZZZ.PA150 Caps: BFG.3B.100.PCSG Cables 380750 PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.3B.308.CYCD10Z
PDF文档中包含以下信息:
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器。
2. 器件简介:该微控制器具有多种功能,如高性能、低功耗、丰富的外设接口等。
3. 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压范围为2.0V至3.6V,工作频率最高可达72MHz。
5. 功能详解:包括多种通信接口、定时器、模数转换器等。
6. 应用信息:适用于工业控制、消费电子、医疗设备等领域。
7. 封装信息:采用LQFP48封装方式。
FGG.3B.308.CYCD10Z 价格&库存
很抱歉,暂时无法提供与“FGG.3B.308.CYCD10Z”相匹配的价格&库存,您可以联系我们找货
