B3F
B3F
    SWITCHCRAFT
    B3F
B3F 数据手册
8 7 6 5 4 3 2 1 F F E E 3 PIN 4 PIN 5 PIN 6 PIN 7 PIN 1 1/4-18 NEF THREAD 1.250 [31,75] D D 0.484 [12,29] 0.16 x 0.09 [3.9] x [2.4] 0.188 [4,78] C RECOMMENDED PANEL CUT-OUT C 1.45 [36,8] 0.11 [2,8] STANDARD SERIES SCREW - STAINLESS STEEL SHELL - STAINLESS STEEL LATCH BUTTON - ZINC, NICKEL PLATED INSULATOR - POLYESTER, GREEN SOLDER TERMINAL - BRASS, ELECTRO TIN LATCH SPRING - STAINLESS STEEL CONTACT PIN - PHOSPHOR BRONZE, SILVER PLATED HOUSING - ZINC NUT - ZINC, NICKEL PLATED RELEASE LEVER - STEEL NICKEL PLATED B 0.73 [18,6] B B _ F _ L A CUSTOMER DRAWING HOUSING FINISH: SEE NOTE 2 BLANK = NICKEL PLATE (STANDARD) BX = BLACK, RoHS NO. OF 3 4 5 6 7 UNLESS OTHERWISE SPECIFIED NOTES: CONTACTS: = 3 CONTACTS = 4 CONTACTS = 5 CONTACTS = 6 CONTACTS = 7 CONTACTS 1. ALL DIMENSIONS REF. UNLESS OTHERWISE SPECIFIED. L 2. BLACK HOUSING AND INSERT WITH SATIN NICKEL PLATED LATCH. L 3. THIS PRODUCT IS RoHS COMPLIANT. M 28302 07-08-20 PC TJK L 26158 10-4-06 TO TJK K ECO #22895 9-17-99 DA RB J 20627 2-1-96 SG SG REV ECO NUMBER DATE BY APVD REVISIONS 8 THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION 7 6 5 4 1. ALL DIMENSIONS IN INCHES -TWO PLACE DECIMALS 0.01 -THREE PLACE DECIMALS 0.005 -FRACTIONAL DIMENSIONS 1/64 -ANGLES 1 -ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 3. REMOVE ALL BURRS DO NOT SCALE DRAWING Pro/Engineer CAD File SIZE WIDTH MULT FINISH TEMPER MATERIAL SPEC No. FIRST USED ON SCALE DATE DRAWN BY CHKD 11-Dec-93 SG AA 7-11-94 NAME 2 A SPEC No. 2:1 APVD GHJ 7-11-94 B SERIES FEMALE QG, RoHS C LBS/M PART No. SHEET 1 OF B_F SERIES 1 1 REV M
很抱歉,暂时无法提供与“B3F”相匹配的价格&库存,您可以联系我们找货
B3F
  • 1+423.964691+55.07087
