HIF3F-10PA-2.54DS(71)
    HRS(广濑)
    CONN HEADER 10POS 2.54MM
HIF3F-10PA-2.54DS(71) 数据手册
Box type Pin Header to Prevent Mis-insertion HIF3F Series ■Features 1. Prevent to Reverse Insertion The pin header to prevent reverse insertion is equipped with contact protective walls to the HIF3E series. 2. Compatibility This pin header is compatible with HIF3B series. ■Applications Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Computers, terminal equipment, PPC, various kinds of electronic equipment, office automation machines, etc. ■Product Specifications Operating Temperature Range:–55 to +85ç (Note 1) Operating Moisture Range:40 to 80% Current rating: 1A Voltage rating: 200V AC Rating Item Storage Temperature Range:–10 to +60ç(Note 2) Storage Humidity Range:40 to 70% (Note 2) Specification Condition 1. Insulation Resistance 1000M ohms min. 500V DC 2. Withstanding voltage No flashover or insulation breakdown. 650V AC/1 minute 3. Contact Resistance 15m ohms max. 0.1A Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. No electrical discontinuity of 1μs or more 4. Vibration 5. Humidity (Steady state) Insulation resistance: 1000M ohms min. 96 hours at temperature of 40ç and humidity of 90% to 95% 6. Temperature Cycle No damage, cracks, or parts looseness. (–55ç: 30 minutes ➝15 to 35ç: 5 minutes max. 125ç: 30 minutes ➝15 to 35ç: 5 minutes max.) 5 cycles 7. Durability (Mating/un-mating) Contact resistance15m ohms max. 500 cycles 8. Resistance to Solder bath: 260ç for 10 seconds No deformation of components affecting performance. Soldering heat Manual soldering: 360ç for 5 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3: Information contained in this catalog represents general requirements for this Series.Contact us for the drawings and specifications for a specific part number shown. ■Material Part Material Finish Remarks Insulator PBT Black UL94V-0 Contact Brass Selective gold plating over nickel underplated --------------- ■Ordering Information HIF3F 1 - * P A - 2.54 DS 2 1 Series Name: HIF3F 2 Number of contacts: 10, 16, 20, 26, 30, 34, 40, 50, 60 3 P: Pin header 4 A: Selective gold plating B44 3 4 5 6 5 Contact Pitch: 2.54mm 6 Terminal type DS: Right angle type DSA: Straight type HIF3F Series●Box type Pin Header to Prevent Mis-insertion Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Straight Pin Header Unit: mm Part Number CL No. Number of Contacts A B C HIF3F-10PA-2.54DSA(71) 615-0061-3-71 10 20.5 17.5 10.16 HIF3F-16PA-2.54DSA(71) 615-0062-6-71 16 28.1 25.1 17.78 HIF3F-20PA-2.54DSA(71) 615-0063-9-71 20 33.2 30.2 22.86 HIF3F-26PA-2.54DSA(71) 615-0064-1-71 26 40.8 37.8 30.48 HIF3F-30PA-2.54DSA(71) 615-0065-4-71 30 45.9 42.9 35.56 HIF3F-34PA-2.54DSA(71) 615-0066-7-71 34 51.0 48.0 40.64 HIF3F-40PA-2.54DSA(71) 615-0067-0-71 40 58.6 55.6 48.26 HIF3F-50PA-2.54DSA(71) 615-0068-2-71 50 71.3 68.3 60.96 HIF3F-60PA-2.54DSA(71) 615-0069-5-71 60 84.0 81.0 73.66 RoHS YES Note: The slot size for false-insertion for 50 contact and 60 contact connectors is 26.96. B45 HIF3F Series●Box type Pin Header to Prevent Mis-insertion Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Right Angle Pin Header Unit: mm Part Number CL No. Number of Contacts A B C HIF3F-10PA-2.54DS(71) 615-0041-6-71 10 20.5 17.5 10.16 HIF3F-16PA-2.54DS(71) 615-0042-9-71 16 28.1 25.1 17.78 HIF3F-20PA-2.54DS(71) 615-0043-1-71 20 33.2 30.2 22.86 HIF3F-26PA-2.54DS(71) 615-0044-4-71 26 40.8 37.8 30.48 HIF3F-30PA-2.54DS(71) 615-0045-7-71 30 45.9 42.9 35.56 HIF3F-34PA-2.54DS(71) 615-0046-0-71 34 51.0 48.0 40.64 HIF3F-40PA-2.54DS(71) 615-0047-2-71 40 58.6 55.6 48.26 HIF3F-50PA-2.54DS(71) 615-0048-5-71 50 71.3 68.3 60.96 HIF3F-60PA-2.54DS(71) 615-0049-8-71 60 84.0 81.0 73.66 Note: The slot size for false-insertion for 50 contact and 60 contact connectors is 26.96. B46 RoHS YES
HIF3F-10PA-2.54DS(71) 价格&库存
很抱歉,暂时无法提供与“HIF3F-10PA-2.54DS(71)”相匹配的价格&库存,您可以联系我们找货
  • 1+8.52010
库存:2
