FTSH-110-01-L-DV
FTSH-110-01-L-DV
    SAMTEC(申泰)
    SMD,P=1.27mm
    特性:绝缘材料:黑色液晶聚合物。端子材料:磷青铜。电镀:50μ(1.27μm)镍上镀锡或镀金。额定电流(FTSH/CLP):每引脚3.4A(2引脚供电)。工作温度范围:-55°C至+125°C。无铅可...
FTSH-110-01-L-DV 数据手册
REVISION FQ DO NOT SCALE FROM THIS PRINT FTSH-1XX-XX-XXX-DV-XXX-XXX NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. PARTS MAY BE CUT TO POSITION. No OF POSITIONS 3. MAXIMUM CUT FLASH: .015[0.38], LOOSE FLASH MUST BE REMOVED. -02 THRU -50 4. MINIMUM PUSHOUT FORCE: 1.0 LB. (PER ROW) 5. MEASURED AT BEND RADIUS, NOT AT END OF PIN. 6. TUBE ONLY -04 THROUGH -50 POSITIONS (SEE TABLE 2). LEAD STYLE 7. SHEAR TAILS TO DIMENSION SHOWN. -01: .120 [3.05] 8. MAXIMUM BURR ALLOWANCE: .003 [0.08] -02: .075 [1.91] 9. GOLD PLATING TO BE ON POST, TIN PLATING TO BE ON TAIL. -03: .065 [1.65] 10. FILL WITH ALIGNMENT PIN HOLES TO TAIL SIDE. -04: .150 [3.81] 11. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, LOCKING CLIPS -05 .170 [4.32] ARE NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS -14: .150 [3.81](NOT AVAILABLE MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH LOCKING CLIPS. 12. VOIDS MAY OR MAY NOT BE PRESENT ON POSITIONS 5 THRU 8 AND CAN WITH -SM, FM, LM PLATING BE MIXED WITHIN AN ORDER. OPTIONS) 13. ON LEAD STYLES -02 THROUGH -03 THE T-1S15-18-XXX CAN BE SUBSTITUTED FOR T-1S15-16-XXX. PLATING SPECIFICATION 14. ON LEAD STYLES -01 AND -04, T-1S15-17 CAN BE SUBSTITUTED FOR T-1S15-15-XXX. -L: 10µ" SELECTIVE GOLD IN CONTACT AREA, 15. NO TIN PLATING ALLOWED ON THE POST FOR MATTE TIN ON TAIL LEAD STYLES -01, -02, -03 & -04 IN COMBINATION WITH THE -F: 3µ" SELECTIVE GOLD IN CONTACT AREA, T-1S15-XX-XXX TERMINAL. MATTE TIN ON TAIL 16. MAXIMUM HEIGHT VARIATION .005[0.13] BETWEEN ROWS. -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, 17. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, MATTE TIN ON TAIL BASED ON OPTIONS SELECTED. -H: 30µ" GOLD IN CONTACT AREA, 18. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY 3µ" GOLD ON TAIL STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM -LM: 10µ" SELECTIVE GOLD IN CONTACT AREA, C +0.13 No OF POS x .0500 +.005 -.014 [ -0.36 ] (No OF POS x .0500[1.27]) - .050[1.27] 02 50 .135 3.43 REF 01 FTSH-50-D .016 0.41 SQ REF (TYP) 2 MAX SWAY (EITHER DIRECTION) POLARIZING OPTION XXX INDICATES POSITION TO BE OMITTED (NOT AVAILABLE WITH EXX OPTIONS) (ONLY AVAILABLE WITH -F, -FM, -L, -LM PLATING OPTIONS) TAIL OPTION -DV: DOUBLE VERTICAL * = NOT ENGINEERING APPROVED C .050±.008 1.27±0.20 2 MAX SWAY (EITHER DIRECTION) SEE TABLE 1 C 90°±3° "A" C (SEE NOTE 16) .099 2.51 REF SEE NOTE 3 (2 PLCS) 5713755 / 5961339 MATTE TIN ON TAIL -FM: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -LTL: 10µ" SELECTIVE GOLD IN CONTACT AREA, TIN/LEAD (90/10+/-5%) TAIL -G: 10µ" GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -STL: 30µ" SELECTIVE GOLD IN CONACT AREA, TIN/LEAD (90/10 +/-5%) ON TAIL 49 2 MAX SWAY (EITHER DIRECTION) "B" CONTACT AREA (SEE NOTE 9 & TABLE 1) PATENT NUMBERS OPTIONS -P: PICK & PLACE PAD (4 POS MIN) (SEE FIG 11, SHT 4 & TABLE 5) -TR: TAPE & REEL PACKAGING (SEE NOTE 18) (NOT AVAILABLE WITH -EJC, -EC & -EPC. SEE NOTE 11) -FR: FULL REEL QTY. TAPE AND REEL (SEE NOTE17) -ES: END SHROUDS (SEE FIG 6, SHT 3) (MOLDED IN 5 POS MIN; -02 & -03 LEAD STYLE ONLY) (SNAP SHROUDS 9 POS MIN; -02 & -03 LEAD STYLE ONLY) -EJ: EJECTOR SHROUDS: SEE FIG 4, SHT 2) (10 POS MIN; -01 LEAD STYLE ONLY) -EJM: EJECTOR SHROUDS WITH MOLDED ALIGNMENT PIN (SEE FIG 5, SHT 2; 10 POS MIN; -01 LEAD STYLE ONLY) (NOT VALID WITH -A OPTION) -EJC: EJECTOR SHROUDS WITH LOCKING CLIP (SEE FIG 5, SHT 2 & NOTE 11) (10 POS MIN; -01 LEAD STYLE ONLY; NOT VALID WITH -A OPTION) -EC: LOCKING CLIP (SEE FIG 7, SHT 3 & NOTE 11) (9 POS MIN; -02 & -03 LEAD STYLE ONLY) -EP: GUIDE POST (SEE FIG 8, SHT 3; 9 POS MIN; -02 & -03 LEAD STYLE ONLY)(USE ONLY WHEN MATING WITH CLP) -EL: BOARD LOCK (SEE FIG 9, SHT 3) (9 POS MIN; -02 & -03 LEAD STYLE ONLY) (USE ONLY WHEN MATING WITH CLP) -EPC: GUIDE POST & LOCKING CLIP (SEE FIG 10, SHT 3 & NOTE 11; USE ONLY WHEN MATING WITH CLP) (9 POS MIN; -02 & -03 LEAD STYLE ONLY; NOT VALID WITH -A OPTION) -A: ALIGNMENT PIN (MOLDED OR STAKED; SEE FIG 3, SHT 2) (MOLDED: 3 POS MIN; STAKED: 6 POS MIN) (SAMTEC DISCRETION ON WHICH -A PIN USED) -K: KEYING OPTION FOR MATING WITH FFSD (SEE TABLE 3, SHT 2; 05 THRU 25 AVAILABLE AS STANDARD) (POSITION 13, 17, 20 & 25 AVAILABLE WITH -EXX OPTION) (LEAD STYLE -01 ONLY, SEE FIG 2, SHT 2 & NOTE 12) (ALIGNMENT PIN AVAILABLE WITH -K OPTION BUT MUST BE MOLDED) USE FTSH-50-CN-XX-X OR FTSHC-50-CN-XX-X) * -M:(MUST METAL PICK & PLACE PAD (5 POS MIN; USE MPP-22-5) (SEE FIG 12, SHT 4; NOT AVAILABLE WITH -K OPTION) +.005 SEE TABLE 6 FIG 1 +0.13 .115 - .003 2.92 - 0.08 (SEE NOTE 5) FTSH-1XX-XX-XXX-DV SHOWN UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 1 .XXX: .005 [.13] .XXXX: .0010 [.025] MATERIAL: * PROPRIETARY NOTE HAND FILL USING T-1S40 * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 5:1 INSULATOR: LCP UL 94 VO TERMINAL: PHOSPHOR BRONZE * = SEE NOTE 13 *** = SEE NOTE 14 .230 5.84 REF .23 5.8 (SEE NOTE 7) SEE NOTE 8 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 CL DOUBLE VERTICAL SMT TERMINAL STRIP DWG. NO. FTSH-1XX-XX-XXX-DV-XXX-XXX F:\DWG\MISC\MKTG\FTSH-1XX-XX-XXX-DV-XXX-XXX-MKT.SLDDRW BY: PURVIS 10/12/1995 SHEET 1 OF 5 USE SUB-FTSH-EJEHA (2 REQ'D PER ASSEMBLY, EACH USES 1 EHA-02 & 1 FTSH-EJ) REVISION FQ (No OF POS x 02 +.005 .0500[1.270]) - .014 [ +0.13 ] -0.36 .222 5.65 REF .440 11.18 REF .135 3.43 REF 01 CL (No OF POS x .050[1.27])+.621[15.77] ±.010[0.25] C .085 2.16 REF .200 5.08 REF (No OF POS x .050[1.27])+.772[19.61] REF .126 3.20 REF FTSH-50-D .392 9.96 REF SEE NOTE 12 FIG 2 FTSH-50-CN-XX-X OR FTSHC-50-CN-XX-X -EJ OPTION (SHROUDS OPEN) -K OPTION (LEAD STYLE -01 ONLY) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (POSITION 13, 17, 20 & 25 AVAILABLE WITH -EXX OPTION) CL FIG 4 -EJ OPTION (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (-01 LEAD STYLE ONLY) FTSH-50-D (SEE NOTE 10) CL .034 0.86 (No OF POS - 2) x .050[1.27] C SM-A9H .035 0.89 REF (STAKED ALIGNMENT PINS) 2 MAX SWAY (EITHER DIRECTION) LC-05-TM -EJC +.005 .050 1.27 REF FULL R (MOLDED ALIGNMENT PINS) -A OPTION (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (6 POSITION MINIMUM FOR STAKED ALIGNMENT PINS) (3 POSITION MINIMUM FOR MOLDED ALIGNMENT PINS) +0.13 0.00 .085 - .000 2.16 .034 0.86 F:\DWG\MISC\MKTG\FTSH-1XX-XX-XXX-DV-XXX-XXX-MKT.SLDDRW CL NO CLEARANCE ALLOWED HERE FTSH-50-D-XX FIG 3 USE SUB-FTSH-EJEHA-A (2 REQ'D PER ASSEMBLY, EACH USES 1 EHA-02 & 1 FTSH-EJ-A) USE SUB-FTSH-EJEHA (2 REQ'D PER ASSEMBLY, EACH USES 1 EHA-02 & 1 FTSH-EJ) C CL (No OF POS - 2) x .050[1.27] .076 1.93 REF .010 0.25 REF -EJC .05 1.3 REF -EJM FIG 5 -EJC & -EJM OPTIONS (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 4) (-01 LEAD STYLE ONLY) * .035 0.89 REF .035 0.89 REF -EJM PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 CL DOUBLE VERTICAL SMT TERMINAL STRIP DWG. NO. FTSH-1XX-XX-XXX-DV-XXX-XXX BY: PURVIS 10/12/1995 SHEET 2 OF 5 REVISION FQ (No OF POS x .050[1.27])+.231[5.87]±.008[0.20] .265 6.73 REF 02 .075 1.91 REF .188 4.78 REF .139 3.53 REF 01 C (No OF POS x .050[1.27])+.101[2.57]±.008[0.20] .288 7.32 REF C (No OF POS x .050[1.27])+.156[3.96] REF .032[0.81] REF CHAMFER FTSH-EP .120 3.05 REF .314 7.96 FIG 8 ES-FTSH .168 4.27 REF -EP OPTION (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 6) (USE ONLY WHEN MATING WITH CLP) .194 4.91 (No OF POS x .050[1.27])+.257[6.53] REF (SNAP SHROUDS) .293 7.44 REF (No OF POS (PER FINISHED ASSEMBLY) +2) X .050 [1.27] REF 02 .1750 4.445 REF .319 8.09 (No OF POS x .050[1.27])+.223[5.66] .008[0.20] .0960 2.438 REF FIG 9 -EL OPTION (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 6) (USE ONLY WHEN MATING WITH CLP) 01 FTSH-49-ES-XX-X (No OF POS x .050[1.27])+.231[5.87]±.008[0.20] C (No OF POS x .050[1.27])+.156[3.96] REF .178 4.51 REF .0990 2.515 REF (MOLDED SHROUDS) -ES OPTION (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (USE -02 OR -03 LEAD STYLE ONLY) (9 POS MIN FOR SNAP SHROUDS) (5 POS MIN FOR MOLDED SHROUDS) (No OF POS x .050[1.27])+.131[3.32]±.008[0.20] C .280 7.11 REF .075 1.91 REF .288 7.32 REF FIG 6 FTSH-EC LC-05-TM (No OF POS x .050[1.27])+.079[3.30]±.008[0.20] FIG 7 -EC OPTION (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 6) F:\DWG\MISC\MKTG\FTSH-1XX-XX-XXX-DV-XXX-XXX-MKT.SLDDRW .032[0.81] REF CHAMFER FTSH-EP .120 3.05 REF .314 7.96 LC-05-TM .055 1.40 (No OF POS x .050[1.27])+.079[2.01]±.008[.20] FIG 10 -EPC OPTION (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 6) (USE ONLY WHEN MATING WITH CLP) * .055 1.40 .125 3.18 REF (No OF POS x .050[1.27])+.153[3.89] REF FTSH-EL FTSH-50-D (SEE NOTE 10) PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 CL DOUBLE VERTICAL SMT TERMINAL STRIP DWG. NO. FTSH-1XX-XX-XXX-DV-XXX-XXX BY: PURVIS 10/12/1995 SHEET 3 OF 5 REVISION FQ "M" REF .20 5.1 REF "P" .060 1.52 REF .065 1.65 REF .16 4.1 REF "M" REF = OVERALL LENGTH "P" ={("M" -.200 [5.08]) / 2} .020 [.51] .230 5.84 REF .13 3.3 REF PPP-25 .13 3.3 REF .20 5.1 REF PPP-25-KT -P FIG 11 .23 5.8 REF -P OPTION (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) CL FTSH-50-D FTSH-50-CN-XX -K-P-TR/FR (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2) PPP-25-NT *MOLDED SHROUD ONLY ** USE PPP-25-NT WITH -TR -P-TR PACKAGING ONLY (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) NOTE: TAPE & REEL ORIENTATION: POLARIZATION NOTCH TO THE RIGHT "M" REF "P" .32 8.1 REF .32 8.1 REF PPP-41 .16 4.1 REF -EJ-P & -EJX -P "M" REF = OVERALL LENGTH "P" ={("M" -.32 [8.1]) / 2} .020 [.51] (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIGS 4 & 5) "M" REF TAPE & REEL VIEW "P" .250 6.35 REF USER DIRECTION OF UN-REELING POCKET NOT DETAILED .100 2.55 REF MPP-22-5 "B" FTSH-50-D * "M" REF = OVERALL LENGTH "P" = {("M" - .250[6.35]) / 2} ± .020[0.51] FIG 12 *-M: METAL PICK & PLACE PAD (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (NOT AVAILABLE WITH -K OPTION)(5 POS MIN) * = NOT ENGINEERING APPROVED F:\DWG\MISC\MKTG\FTSH-1XX-XX-XXX-DV-XXX-XXX-MKT.SLDDRW PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 CL DOUBLE VERTICAL SMT TERMINAL STRIP DWG. NO. FTSH-1XX-XX-XXX-DV-XXX-XXX BY: PURVIS 10/12/1995 SHEET 4 OF 5 REVISION FQ PT-FTSH006-DV-EJC-K-P PT-FTSH002-DV-A-P-M PT-FTSH004-DV-EX-A-P-M PT-FTSH002-DV-A-P-M PT-FTSH004-DV-EX-A-P-M PT-FTSH002-DV-A-P-M -ES, -ES-A -ES-P, -ES-A-P -DV (NONE) -A, -A-P -DV, -P PT-FTSH003-DV-EJC-K PT-FTSH007-DV-K-P -EJ, EJX AND -EJ-X PT-FTSH007-DV-K-P -K-P -K, -K-A (FOR -01 LEAD STYLE ONLY) ALL -EJ-K OPTIONS FIG 13 TUBE VIEWS "A" - .034 0.864 "A" - .034 0.864 "C" REF (SEE TABLE 1) "A" - .034 0.864 .125±.010 3.18±0.25 (SEE NOTE 7) .050±.005 1.270±0.127 IN PROCESS 3 IN PROCESS 2 W/O A PINS W/O A PINS IN PROCESS 1 W/O A PINS "A" - .084 2.134 "A" - .084 2.134 "A" -.084[2.134] "C" REF (SEE TABLE 1) * .175±.010 4.445±0.254 (SEE NOTE 7) .100±.005 2.540±0.127 IN PROCESS 1 WITH A PINS* IN PROCESS 2 WITH A PINS* * = FOR -01, -04, -05 AND -14 LEAD STYLES ONLY F:\DWG\MISC\MKTG\FTSH-1XX-XX-XXX-DV-XXX-XXX-MKT.SLDDRW IN PROCESS 3 WITH A PINS* PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2:1 IN-PROCESS VIEWS ARE FOR HANDFILL ONLY * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 CL DOUBLE VERTICAL SMT TERMINAL STRIP DWG. NO. FTSH-1XX-XX-XXX-DV-XXX-XXX BY: PURVIS 10/12/1995 SHEET 5 OF 5
FTSH-110-01-L-DV
1. 物料型号:文档描述了FTSH-1XX-XX-XXX-DV-XXX-XXX型号的配置选项,例如pick & place pad、tape & reel packaging、end shrouds、ejector shrouds等。
2. 器件简介:文档提供了器件的物理描述和配置选项,但没有提供具体的器件功能或应用场景。
3. 引脚分配:文档中提到了不同lead style的引脚分配,例如-01、-02、-03、-04、-05和-14,以及它们对应的尺寸和配置。
4. 参数特性:文档列出了多种参数特性,如gold plating on post, tin plating on tail, alignment pin options等。
5. 功能详解:文档中的功能详解部分主要涉及器件的配置选项和它们的适用情况。
6. 应用信息:文档提供了一些应用信息,如器件的自动化装配建议和包装选项。
7. 封装信息:文档包含了封装的详细图纸和尺寸,以及不同封装选项的描述。
FTSH-110-01-L-DV 价格&库存
很抱歉,暂时无法提供与“FTSH-110-01-L-DV”相匹配的价格&库存,您可以联系我们找货
FTSH-110-01-L-DV
  • 46+39.7334546+5.12572
  • 138+23.52279138+3.03450
  • 276+21.24377276+2.74050
  • 506+18.72056506+2.41500
库存:966
FTSH-110-01-L-DV
  • 6+20.921616+2.69894
库存:1470
FTSH-110-01-L-DV
  • 1+29.990681+3.86888
  • 100+17.79405100+2.29548
  • 250+16.08209250+2.07463
  • 500+14.20532500+1.83253
  • 1000+11.834971000+1.52674
  • 2500+9.876612500+1.27411
  • 5000+8.681435000+1.11993
库存:1471
