222PR13NC032
222PR13NC032
    ALPHAWIRE(阿尔法电线)
    CONNPLUGMALE3POSGOLDSCREW
222PR13NC032 数据手册
Customer Specification PART NO: 222 Series Mini 7/8" Male Internal Threads 3 Pin Field Attachable Issue: 1 Issue Date: 4/18/2016 Effective Date: 5/18/2016 Drawing Technical Data Part Number 222PR13 222PR16 222PR9 Mechanical Housing Insert Contact Coupling Nut Connection Max AWG Electrical Contact Resistance Nom. Current @ 40°C Nominal Voltage Insulation Resistance UL File Environmental Degree of Protection Operating Temperature Cable Diameter Range 0.394" – 0.472" (10.0 – 12.0 mm) 0.472" – 0.551" (12.0 – 14.0 mm) 0.236" – 0.315" (6.0 – 8.0 mm) Glass Filled Nylon Nylon black Copper Alloy, Gold Plated Aluminum, anodized black Screw Terminal (Internal Threads) 16 (1.5mm2) ≤ 5 mΩ 12 A 600 V > 109 Ω E485156 (Except 222PR9) IP 67/ NEMA 6P -40C (-40F)/ +90C (+194F) ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: 222 Series Mini 7/8" Male Internal Threads 3 Pin Field Attachable Range CE REACH Regulation (EC 1907/2006) Issue: 1 issue Date: 8/4/2016 Effective Date: 8/4/2016 Ordering Information 222PR13 NC032 222PR16 NC032 222PR9 NC032 All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. Each Each Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2
222PR13NC032 价格&库存
很抱歉,暂时无法提供与“222PR13NC032”相匹配的价格&库存,您可以联系我们找货
