218KR11NC032
218KR11NC032
    ALPHAWIRE(阿尔法电线)
    CONNPLUGFMALE5POSGOLDSCREW
218KR11NC032 数据手册
Customer Specification PART NO: 218 Series Mini 7/8" Female 5 Pin Field Attachable Drawing Issue: 1 Issue Date: 4/18/2016 Effective Date: 5/18/2016 Technical Data Part Number 218KR11 218KR13 218KR16 218KR9 Mechanical Housing Insert Contact Coupling Nut O-Ring Connection Max AWG Electrical Contact Resistance Nom. Current @ 40°C Nominal Voltage Rated Voltage Test Voltage Insulation Resistance UL File Environmental Degree of Protection Operating Temperature Range CE Cable Diameter Range 0.315" – 0.394" (8.0 – 10.0 mm) 0.394" – 0.472" (10.0 – 12.0 mm) 0.472" – 0.551" (12.0 – 14.0 mm) 0.236" – 0.315" (6.0 – 8.0 mm) Polyamide Polyurethane Copper Alloy, Gold Plated Aluminum, anodized black NBR Screw Terminal 16 (1.5mm2) ≤ 5 mΩ 9A 240 V 250 V 1.5 kV eff./60 s > 109 Ω E485156 (Except 218KR9) IP 67/ NEMA 6P -40C (-40F)/ +90C (+194F) All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: 218 Series Mini 7/8" Female 5 Pin Field Attachable REACH Regulation (EC 1907/2006) Issue: 1 issue Date: 8/4/2016 Effective Date: 8/4/2016 Ordering Information 218KR11 NC032 218KR13 NC032 218KR16 NC032 218KR9 NC032 the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. Each Each Each Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2
218KR11NC032 价格&库存
很抱歉,暂时无法提供与“218KR11NC032”相匹配的价格&库存,您可以联系我们找货
