219LR13NC032
219LR13NC032
    ALPHAWIRE(阿尔法电线)
    CONNPLUGMALE3POSGOLDSCREW
219LR13NC032 数据手册
Customer Specification PART NO: 219 Series Mini 7/8" Male 3 Pin Field Attachable Issue: 1 Issue Date: 4/18/2016 Effective Date: 5/18/2016 Drawing Technical Data Part Number 219LR11 219LR13 219LR16 219LR9 Mechanical Housing Insert Contact Coupling Nut O-Ring Connection Max AWG Electrical Contact Resistance Nom. Current @ 40°C Nominal Voltage Rated Voltage Test Voltage Insulation Resistance Cable Diameter Range 0.315" – 0.394" (8.0 – 10.0 mm) 0.394" – 0.472" (10.0 – 12.0 mm) 0.472" – 0.551" (12.0 – 14.0 mm) 0.236" – 0.315" (6.0 – 8.0 mm) Polyamide Polyurethane Copper Alloy, Gold Plated Aluminum, anodized black NBR Screw Terminal 16 (1.5mm2) ≤ 5 mΩ 12 A 240 V 250 V 2.5 kV eff./60 s > 109 Ω ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: 219 Series Mini 7/8" Male 3 Pin Field Attachable UL File Environmental Degree of Protection Operating Temperature Range CE REACH Regulation (EC 1907/2006) Issue: 1 issue Date: 8/4/2016 Effective Date: 8/4/2016 Ordering Information 219LR11 NC032 219LR13 NC032 219LR16 NC032 219LR9 NC032 E485156 (Except 219LR9) IP 67/ NEMA 6P -40C (-40F)/ +90C (+194F) All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. Each Each Each Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2
219LR13NC032 价格&库存
很抱歉,暂时无法提供与“219LR13NC032”相匹配的价格&库存,您可以联系我们找货
