A
B
C
D
E
F
G
H
RECOMMENDED PANEL CUTOUT
+0.3
[0.64
0.000
Max. Panel thickness : 8mm
[0.31 inch]
8
REAR VIEW
COUPE
INSULATOR KEY
(ALIGN WITH SHELL GROOVE)
MASS
B-B
Panel thickness
8 max.
[0.31]
8.5
[0.33]
3
2
5%
6.25 g
FRONT VIEW
MAIN KEY
22
[0,87]
14
[0,55]
7
VISUAL KEY
FRONT MOUNT RECEPTACLE
WITH CRIMP CONTACTS
M16
14.25+0.3
[0.560.0000 ]
C.2; Validé
SIDE VIEW
8
7
1
6
Jam nut - 22
on flats
[0,87]
Max. tightening torque 2.5 N.m
PART LIST
ITEM
NO.
DESCRIPTION
MATERIAL
2
HEX NUT
PANEL SEAL
POLYAMIDE- PA6
SHELL RECEPTACLE
PEI_ULTEM
1
3
14.3
[0.56]
VARIABLE KEYS
16.8
[0.66]
SIDE VIEW
SILICONE
WITH SOLDER CONTACTS
5
SCALE 2/1
ELECTRICAL:
INSULATION RESISTANCE :
MAX. CURRENT RATING :
CONNECTOR TESTING VOLTAGE :
CONNECTOR WORKING VOLTAGE :
PHYSICAL:
MAXIMUM WIRE SIZE USED :
ENVIRONMENTAL:
ENDURANCE:
SHOCK:
>500M ^
PER ANSI-EIA-364-D
SEE INSULATOR DRAWING
6
5
Extra compound
METHOD 21
2000 MATING CYCLES AS PER IEC
60512-5 test 9a
Dropping height 750 mm [29.53] per
IEC 60512 test 7b
4
PROTECTION INDEX:
4
IP 68 AS PER IEC 60529 (1BAR
DURING 1 WEEK)
In mated condition
In unmated condition with solder
contacts
ROHS & REACH COMPLIANT
OPERATING TEMPERATURE:
Optional color coding
-20°C +100°C (-4°F +212°F)
BIOCOMPATIBILITY: ALL SHELL PEI_ULTEM PARTS to USP Class VI / ISO 10993
3
Connector coding
3
Basic type
JMX
HH
1
G
XX
X
X
U
D
S
X
X
CountryJurisdiction
& Control List
FR
NOT LISTED
Shell type :HH Front mount receptacle
P/N : SEE TABLE : CONNECTOR CODING
Shell size
Keying : G
2
C
Contact layout : SEE INSULATOR DRAWING
Contact type : (M) Male, (F) Female
ISS
Contact style:
S (Solder), C (Crimp), P (Straight PCB contacts), Q (90° PCB contacs)
TITLE
TOLERANCES
UNLESS OTHERWISE SPECIFIED
No. OF PLACES
Standard collet
WHOLE No.
Back nut :S (standard)
mm [INCH]
Scale
3/1
ONE PLACE
1
Connector color coding
TWO PLACES
ANGLES
(A)Blue, (P)Purple, (G)Grey, (J)Yellow, (M)Brown, (N)Black, (R)Red,
(O)Orange,
(V)Green,U(Uncolored)
G
F
E
D
Update
Latest modification - by:
Q.LEBRETON
G.MARCHAND
Date:
13/01/17
C
FORMAT
A2
CUSTOMER DRAWING
MOD N $
2
FRONT MOUNT RECEPTACLE SIZE 1
JMX SERIES
General linear
Tolerances:
SEE TABLE
WWW.SOURIAU.COM
# 1°
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
Packaging :nothing:single packaging, B(Bulk) : 100pcs
DATE
Designed by:
LINEAR MESURE : mm [inch]
Material
H
27/03/17
SOURIAU DRG N°
C0001-PPP1-A
B
NPRDS / PROJECT
BE150710A
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
1
2
DWG. NO.
JBX1INSFSC
FEMALE INSULATOR, SOLDER CONTACT
CONTACT LAYOUT
02
03
04
F (FEMALE)
CONTACT TYPE :
05
CONTACT TERMINATION : S (SOLDER)
THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC.
IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION.
CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION.
1
1
FRONT SIDE
VIEW
2
2
3
4
2
3
1
1
2
3
2
C
1
2
F
4
1
3
2
MATERIAL :
5
4
3
KEY
KEY
KEY
REAR SIDE
VIEW
1
INSULATOR KEY
KEY
1
5
CUPRO NICKEL
CLIP:
COPPER ALLOY
INSULATOR:
PEEK
B
FINISH:
2
4
CONTACT:
3
GOLD
CONTACTS:
C
F
CONTACT
CATALOG NUMBER DESCRIPTION
JXX XX 1 X
ISO VIEW
YY F S X X X X
SEE SHELL DRAWING
SEE SHELL DRAWING
SHELL SIZE
CONTACT TERMINATION
C (mm)
1.3
1.3
0.9
0.9
F (mm)
1.1
1.1
0.8
0.8
MAX. AWG
24
MAX. CURRENT
RATING (A)
15
15
10
10
3
3
3.5
3.5
NUMBER OF CAVITY
2
3
4
5
MAX, CURRENT
RATING (A)
10
9
8
7
AIR CLEARANCE/CREEPAGE
DISTANCE min (mm)
(BETWEEN CONTACTS)
1.2
1
1
0.8
TEST VOLTAGE (V)
1200
CONTACT TYPE
CONTACT LAYOUT
C
REVISED PER ECN 13093
B
REVISED PER ECN 12286
A
RELEASED PER ECN 12264
REV
DESCRIPTION
RSK
03-01-17
RSK
06-10-15
SKV
03-10-15
EV
03-01-17
EV
06-10-15
EV
03-10-15
BY
DATE
CHKD
DATE
A
DRAWING TITLE
1100
1100
LINEAR
MEASURE:
ORIGIN
COUNTRY
JURISDICTION
CLASSIFICATION
X
FR
Not listed
N/A
EAR
ECCN =EAR99
US
2
These commodities, technology or software are exported from
the United States in accordance with the Export Administration
Regulations. Diversion contrary to U.S. law is prohibited
JBX, SIZE 1, FEMALE INSULATOR, SOLDER CONTACT
1100
mm
INCH
CAT NO.
JBX1INSFS
mm (INCH)
THIRD ANGLE PROJECTION
TOLERANCES
No. OF PLACES
mm [INCH]
ONE PLACE
#3 [ #.1]
TWO PLACES
#0.5 [ #.02]
THREE PLACES
#0.25 [ #.010]
ANGLES #1 $
CAGE NO: 09922
APPROVAL
CONTACT
RESISTANCE (m
INSULATOR
THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE
DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC.
CONTACT
KEYING
CUSTOMER
INTERPRET THIS DRAWING IN ACCORDANCE
WITH ASME Y14.5M - 1994.
02-02-15
DRAWN:
SKV
02-02-15
CHKD :
EV
02-02-15
DSGN :
EV
02-02-15
MFG :
DH
02-02-15
QC
BB
DRAWING SCALE: NA
DRAWING NO.
REV
JBX1INSFSC
WWW.SOURIAU.COM
1
1 OF 2
C
1
2
DWG. NO.
CONTACT LAYOUT
JBX1INSFSC
06
2
4
3
6
REAR SIDE
VIEW
6
2
5
3
4
3
4
6
4
12
4
2
8
3
C
7
7
6
5
3
F
3
2
10
12
7
6
4
5
1
9
8
2
10
6
KEY
1
9
4
5
8
11 12
4
5
8
2
6
3
6
9
10
KEY
1
7
2
7
10
3
1
8
9
KEY
1
7
2
5
KEY
1
5
1
7
8
4
3
10
1
2
5
7
KEY
11
5
3
4
C
B
F
CONTACT
C (mm)
0.7
0.7
0.7
0.5
0.5
F (mm)
0.81
0.81
0.81
0.5
0.5
MAX. AWG
22
22
22
28
28
MAX. CURRENT
RATING (A)
7
7
7
5
5
5
5
5
10
10
NUMBER OF CAVITY
6
7
8
10
12
MAX, CURRENT
RATING (A)
6
5
5
2.5
2.5
DISTANCE min (mm)
(BETWEEN CONTACTS)
0.75
0.75
0.54
0.58
0.59
TEST VOLTAGE (V)
1000
1000
900
900
900
INSULATOR
A
DRAWING TITLE
CAT NO.
LINEAR
MEASURE:
ORIGIN
COUNTRY
JURISDICTION
CLASSIFICATION
X
FR
Not listed
N/A
EAR
ECCN =EAR99
US
2
mm
INCH
JBX1INSFS
mm (INCH)
TOLERANCES
No. OF PLACES
mm [INCH]
ONE PLACE
#3 [ #.1]
TWO PLACES
#0.5 [ #.02]
THREE PLACES #0.25 [ #.010]
ANGLES #1 $
CAGE NO: 09922
APPROVAL
CONTACT
ISO VIEW
CONTACT
RESISTANCE (m
2
5
08
6
1
6
1
FRONT SIDE
VIEW
07
CUSTOMER
DRAWN:
SKV 02-02-15
CHKD :
EV 02-02-15
DSGN :
EV 02-02-15
MFG :
DH 02-02-15
QC
BB 02-02-15
DRAWING SCALE: NA
DRAWING NO.
REV
JBX1INSFSC
WWW.SOURIAU.COM
1
2 OF 2
C
很抱歉,暂时无法提供与“JMXHH1G12FSUDSU”相匹配的价格&库存,您可以联系我们找货
