RM15WTPZ-12S(71)
RM15WTPZ-12S(71)
    HRS(广濑)
    CONN PLUG 12POS CABLE SKT
RM15WTPZ-12S(71) 数据手册
-Original Multi-purpose High-pin-count Miniature Waterproof Connectors RM-W Series Assembly type (straight plug/RM15W) Ø23 Ø21.5 57 (Low-height plug) Cable Ø21.5 Overview RM-W series connectors originally developed by Hirose offer miniature waterproof connectors to satisfy the requirements of high-capability in a small package. The locking structure adopts a thread coupling style, showing superior waterproof reliability. Cable Fig.1 Assembly type (right-angled plug/RM15W) 41 Cable Features Plugs : Available in 3 types - straight plug, straight lowheight plug, and right-angled plug. Receptacles : Single-body waterproof type is available to satisfy waterproof requirements in a single connector. Fixing methods : Available in 2 types-Jam nut type and screw tightening type with square flange. The Jam nut types offer a front or back mount application. Available numbers of contacts : 2, 3, 4, 8, 10, 12, 15, 20, 40, and 55 contacts in 2 contact plating types: gold or silver. Ø23 Flexible cable arrangements Cable ° In RM-W series, you can select an optimal product for your application through different kinds of both plugs and receptacles. 360 1. Rich variation 40 May.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 48 Fig.2 2. Waterproof structure When fully mated, the connectors meet the waterproof requirements of IP67 and IP68. Single-body waterproof receptacles also meet the requirements of IP67 and IP68. *IP67 : Submerged in 1m for 30 minutes. *IP68 : Submerged in 2m for 14 days. 3. Flexible cable arrangements The assembly type right-angled plugs permit exiting of the cable over a 360-degree range in any direction. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2018.7④ 1 RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Product Specifications (RM15WT size products) Voltage rating 600V AC, 840V DC (2 pos.) 500V AC, 700V DC (3, 4, 8 pos.) 350V AC, 490V DC (10 pos.) 350V AC, 490V DC (12 pos.) Current rating 10A (2, 3, 4 pos.) 5A (8, 10, 12 pos.) Operating temperature range (Note 1) -25ç to +85ç Storage temperature range (Note 2) -10ç to +60ç Rating May.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Characteristic Specification Conditions 1. Contact resistance 2mø max.(2, 3, 4 pos.) 4mø max.(8, 10, 12 pos.) 1A DC 2. Insulation resistance 1,000Mø min 500V DC 3. Withstanding voltage No flashover or insulation breakdown. 1,800V AC/1 minute (2 pos.) 2,000V AC/1 minute (3 pos.) 1,500V AC/1 minute (4, 8 pos.) 1,000V AC/1 minute (10, 12 pos.) 4. Vibration No electrical discontinuity for 10µs max. Frequency : 10 to 55Hz, single amplitude of 0.75mm, for 3 hours in 3 axis. 5. Shock No electrical discontinuity for 10µs max. Acceleration of 490m/s2, 11ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis. 6. Durability (insertion/withdrawal) 4mø max.(2, 3, 4 pos.) 8mø max.(8, 10, 12 pos.) 2,000 cycles 7. Temperature cycle Insulation resistance : 100Mø min. Temperature : -55ç ➝ Room temperature ➝ +85ç ➝ Room temperature Time : 30 ➝ 10 to 15 ➝ 30 ➝ 10 to 15 (Minutes) 5 cycles 8. Humidity Insulation resistance : 100Mø min.(Dray state) 96 hours at temperature of 40ç and humidity of 90% to 95%. 9. Water / dust protection When mated with corresponding connector. Complete dust protection. No water penetration when submerged for 48 hours at the depth of 1.8 meter. Note 1 : Includes temperature rise caused by the current flow. Note 2 : The term “storage” refers to products stored for long period of time prior to mounting and use. Operating temperature range and humidity range covers non-conducting condition of installed connectors in storage, shipment or during transportation. Materials / Finish Item Material Finish Remarks Body Zinc alloy, brass Chrome plated or nickel plated ------------------- Insulator Diallyl phthalate resin, or PPS ------------------- UL94V-0 (Color : Black) Contacts Brass, phosphor bronze, or copper alloy Silver plated or gold plated ------------------- Packing SIR (black or red), or NBR (gray) ------------------- ------------------- Note : Do not mix different contact plating. ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. RM 15 W T P** - 2 P (**) 1 2 3 4 5 6 7 1 Series name : RM-W 5 Number of Contacts 2 Shell size 6 Contact type P : Male contact S : Female contact 3 Lock type T : Screw Lock 4 Connector type P : Plug LP : Plug(right angle) R : Receptacle 2 1 7 Other specifications A two-digit number is added to indicate other specifications. RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Wrench opening dimension of 18mm Plugs - Straight Long Back Shell M20∞0.75 M19∞1 13 Ø21.5 2 Ø15.2 RM15WTPZA-10S(71) 45.3 (Representative example) Part No. HRS No. RM15WTPZA-2P(7*) No. of contacts Weight Part No. HRS No. No. of contacts Weight 109-1734-5 7* 2 43g RM15WTPZA-2S(7*) 109-1729-5 7* 2 45g RM15WTPZA-3P(72) 109-1602-4 72 3 45g RM15WTPZA-3S(7*) 109-1601-1 7* 3 47g RM15WTPZA-4P(7*) 109-1735-8 7* 4 44g RM15WTPZA-4S(8*) 109-1730-4 8* 4 RM15WTPZA-8P(7*) 109-1736-0 7* 8 43g RM15WTPZA-8S(7*) 109-1731-7 7* 8 RM15WTPZA-10P(7*) 109-1737-3 7* 10 RM15WTPZA-10S(7*) 109-1732-0 7* 10 RM15WTPZA-12P(7*) 109-1738-6 7* 12 RM15WTPZA-12S(7*) 109-1733-2 7* 12 44g 45g Applicable Strain Reliefs External cable clamp + internal, self-tightening JR16WCC-10(72) M20∞0.75 Ø23 Wrench opening dimension of 21mm A Drive screw(2) 17.5 (Representative example) HRS No. A JR16WCC-4(72) Part No. 114-2052-6 72 4 JR16WCC-6(72) 114-2053-9 72 6 JR16WCC-8(72) 114-2054-1 72 8 Weight 17.5g HRS No. A JR16WCC-10(72) Part No. 114-2055-4 72 10 JR16WCC-11(72) 114-2154-6 72 11 JR16WCC-12(72) 114-2056-7 72 12 Weight 17.5g Internal, self tightening JR16WCCA-10(72) M20∞0.75 Ø23 Wrench opening dimension of 21mm A May.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Specification number] ( *), - * (71)(81) : Silver plated contacts (72)(82) : Gold plated contacts 8 (Representative example) HRS No. A JR16WCCA-4(72) Part No. 114-2076-4 72 4 JR16WCCA-6(72) 114-2077-7 72 6 JR16WCCA-8(72) 114-2078-0 72 8 Weight 16g HRS No. A JR16WCCA-10(72) Part No. 114-2079-2 72 10 JR16WCCA-11(72) 114-2155-9 72 11 JR16WCCA-12(72) 114-2080-1 72 12 Weight 16g Note 1 : Cable jacket diameter : Use A ± 0.2mm Note 2 : When using the self-tightening strain relief verify the cable pull force requirements. 3 RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Wrench opening dimension of 18mm Plugs - Straight Short Back Shell M16∞0.75 M19∞1 13 Ø21.5 2 Ø15.2 RM15WTPZ-10S(71) 36.3 (Representative example) May.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Specification number] ( *), - * (71)(81) : Silver plated contacts (72)(82) : Gold plated contacts Part No. HRS No. Part No. HRS No. RM15WTPZ-2P(7*) 109-1616-9 7* 2 RM15WTPZ-3P(7*) 109-1622-1 7* 3 32g RM15WTPZ-2S(7*) 109-1611-5 7* 2 34g 34g RM15WTPZ-3S(7*) 109-1621-9 7* 3 36g RM15WTPZ-4P(7*) 109-1617-1 7* RM15WTPZ-8P(7*) 109-1618-4 7* 4 33g RM15WTPZ-4S(8*) 109-1612-8 8* 4 8 32g RM15WTPZ-8S(7*) 109-1613-0 7* 8 RM15WTPZ-10P(7*) 109-1619-7 7* 10 RM15WTPZ-10S(7*) 109-1614-3 7* 10 RM15WTPZ-12P(7*) 109-1620-6 7* 12 RM15WTPZ-12S(7*) 109-1615-6 7* 12 No. of contacts Weight 33g No. of contacts Weight 34g Applicable Strain Reliefs External cable clamp + internal, self-tightening  JR13WCC-10(72) Wrench opening dimension of 17mm A Ø20 M16∞0.75 17 Drive screw(2) (Representative example) Part No. HRS No. A JR13WCC-4(72) 114-2045-0 72 4 JR13WCC-5(72) 114-2046-3 72 5 JR13WCC-6(72) 114-2047-6 72 6 Weight 17g Part No. HRS No. A JR13WCC-7(72) 114-2048-9 72 7 JR13WCC-8(72) 114-2049-1 72 8 JR13WCC-9(72) 114-2050-0 72 9 JR13WCC-10(72) 114-2051-3 72 10 Weight 17g Internal, self tightening JR13WCCA-10(72) M16∞0.75 A Ø20 Wrench opening dimension of 17mm 7.5 (Representative example) Part No. HRS No. A JR13WCCA-4(72) 114-2069-9 72 4 JR13WCCA-5(72) 114-2070-8 72 5 JR13WCCA-6(72) 114-2071-0 72 6 Weight 12g Part No. A 114-2072-3 72 7 JR13WCCA-8(72) 114-2073-6 72 8 JR13WCCA-9(72) 114-2074-9 72 9 JR13WCCA-10(72) 114-2075-1 72 10 Note 1 : Cable jacket diameter : Use A ± 0.2mm Note 2 : When using the self-tightening strain relief verify the cable pull force requirements. 4 HRS No. JR13WCCA-7(72) Weight 12g RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Plugs - Right Angle Wrench opening dimension of 21.8mm RM15WTLP-10S(31) M16∞0.75 Ø23 Ø15.2 19.15 Set screw(2) Hexagonal hole opposite side 1.27mm (1.27HEX) M19∞1 39.5 (Representative example) Part No. RM15WTLP-4P(31) RM15WTLP-4S(32) RM15WTLP-8P(31) RM15WTLP-8S(32) HRS No. No. of contacts 109-1886-3 31 4 109-1888-9 32 109-1887-6 31 8 109-1889-1 32 Weight 60.6g 61.6g 61.5g 63.2g Part No. RM15WTLP-10P(31) RM15WTLP-10S(31) RM15WTLP-12P(31) RM15WTLP-12S(31) HRS No. No. of contacts 109-0020-0 31 10 109-0999-4 31 109-0997-9 31 12 109-1911-9 31 Weight 62.1g 63.1g 62.3g 64.3g Note 1 : Packing material : NBR, body plating : nickel Note 2 : HRS recommended tool : 1.27mm Hex Wrench Note 3 : Recommended set screw tightening torque : 0.2 to 0.3N•m. Applicable Strain Reliefs External cable clamp + internal, self-tightening  M16∞0.75 Ø20 Wrench opening dimension of 17mm JR13WCC-10(72) A Drive screw(2) 17 (Representative example) Part No. JR13WCC-4(72) JR13WCC-5(72) JR13WCC-6(72) HRS No. 114-2045-0 72 114-2046-3 72 114-2047-6 72 A 4 5 6 Weight 17g Part No. JR13WCC-7(72) JR13WCC-8(72) JR13WCC-9(72) JR13WCC-10(72) HRS No. 114-2048-9 72 114-2049-1 72 114-2050-0 72 114-2051-3 72 A 7 8 9 10 Weight A 7 8 9 10 Weight 17g Internal, self tightening JR13WCCA-10(72) M16∞0.75 Ø20 Wrench opening dimension of 17mm A May.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Specification number] (**), -** (31) : Silver plated contacts (32) : Gold plated contacts 7.5 (Representative example) Part No. JR13WCCA-4(72) JR13WCCA-5(72) JR13WCCA-6(72) HRS No. 114-2069-9 72 114-2070-8 72 114-2071-0 72 A 4 5 6 Weight 12g Part No. JR13WCCA-7(72) JR13WCCA-8(72) JR13WCCA-9(72) JR13WCCA-10(72) Note 1 : Cable jacket diameter : Use A ± 0.2mm Note 2 : When using the self-tightening strain relief verify the cable pull force requirements. HRS No. 114-2072-3 72 114-2073-6 72 114-2074-9 72 114-2075-1 72 12g 5 RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Receptacles Front panel mount RM15WTRZ-10S(71) 2 A 6 Wrench opening dimension of 18mm 1 1 2 Ø22 2 9 M19∞1 (Representative example) May.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Specification number] ( *), - * (71)(81) : Silver plated contacts (72)(82) : Gold plated contacts Part No. HRS No. No. of contacts A Weight Part No. HRS No. No. of contacts RM15WTRZ-2P(7*) 109-1631-2 7* 2 21 13g RM15WTRZ-2S(7*) 109-1637-9 7* 2 RM15WTRZ-3P(7*) 109-1632-5 7* 3 22.1 15g RM15WTRZ-3S(7*) 109-1638-1 7* 3 22.1 RM15WTRZ-4P(7*) 109-1633-8 7* 4 21 14g RM15WTRZ-4S(8*) 109-1634-4 8* 4 21.75 RM15WTRZ-8P(7*) 13g RM15WTRZ-8S(7*) 109-1634-0 7* 8 RM15WTRZ-10P(7*) 109-1635-3 7* 10 RM15WTRZ-12P(7*) 109-1636-6 7* 12 20.65 14g 109-1640-3 7* 8 RM15WTRZ-10S(7*) 109-1641-6 7* 10 RM15WTRZ-12S(7*) 109-1642-9 7* 12 A Weight 21.75 15g 21.6 17g 15g Note : Recommended nut tightening torque : 3N•m Rear panel mount RM15WTRZA-10S(71) A 2 Ø27 24(HEX) 13 6.5 M19∞1 M21∞1 (Representative example) [Specification number] ( *), - * (71)(81) : Silver plated contacts (72)(82) : Gold plated contacts Part No. HRS No. No. of contacts RM15WTRZA-2P(7*) 109-1651-0 7* 2 RM15WTRZA-3P(7*) 109-1652-2 7* 3 RM15WTRZA-4P(7*) 109-1653-5 7* 4 21 RM15WTRZA-8P(7*) 109-1654-8 7* 8 RM15WTRZA-10P(7*) 109-1655-0 7* 10 RM15WTRZA-12P(7*) 109-1656-3 7* 12 Note : Recommended nut tightening torque : 3N•m 6 A Weight Part No. HRS No. No. of contacts 21 22g RM15WTRZA-2S(7*) 109-1657-6 7* 2 21.75 24g 22.1 24g RM15WTRZA-3S(7*) 109-1658-9 7* 3 22.1 23g RM15WTRZA-4S(8*) 109-1659-1 8* 4 21.75 22g RM15WTRZA-8S(7*) 109-1660-0 7* 8 RM15WTRZA-10S(7*) 109-1661-3 7* 10 RM15WTRZA-12S(7*) 109-1662-6 7* 12 20.65 23g A 21.6 Weight 26g 24g RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Receptacles (Square flange) Waterproof (When mated with corresponding plug) 9 2 A 6 3 Ø3 .6 2 .9 Ø1 4- 1 1 Ø19 2 28 20.6 28 20.6 3 RM15WTRZB-10S(71) M19∞1 [Specification number] ( *), - * (71)(81) : Silver plated contacts (72)(82) : Gold plated contacts Part No. HRS No. No. of contacts A Weight Part No. HRS No. No. of contacts RM15WTRZB-2P(7*) 109-1671-7 7* 2 21 19g RM15WTRZB-2S(7*) 109-1677-3 7* 2 RM15WTRZB-3P(7*) 109-1672-0 7* 3 22.1 21g RM15WTRZB-3S(7*) 109-1678-6 7* 3 22.1 RM15WTRZB-4P(7*) 109-1673-2 7* 4 21 20g RM15WTRZB-4S(8*) 109-1679-9 8* 4 21.75 RM15WTRZB-8P(7*) 19g RM15WTRZB-8S(7*) 109-1674-5 7* 8 RM15WTRZB-10P(7*) 109-1675-8 7* 10 RM15WTRZB-12P(7*) 109-1676-0 7* 12 20.65 20g 109-1680-8 7* 8 RM15WTRZB-10S(7*) 109-1681-0 7* 10 RM15WTRZB-12S(7*) 109-1682-3 7* 12 A Weight 21.75 21g 21.6 23g 21g Note 1 : Screw size : M3 Note 2 : Recommended nut tightening torque : 0.3 to 0.35N•m Waterproof (single body) 9 2 A 6 3 .9 Ø3 .6 1 Ø1 4- 2 Ø19 1 28 20.6 28 20.6 3 RM15WTRZB-10PA(71) 2 May.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Representative example) M19∞1 (Representative example) [Specification number] (**), -** (71) : Silver plated contacts (72) : Gold plated contacts Part No. HRS No. No. of contacts A Weight Part No. HRS No. RM15WTRZB-3PA(**) 109-1692 7 3 RM15WTRZB-4PA(**) 109-1693 0 4 22.1 20g RM15WTRZB-8PA(**) 109-1694 2 8 20.65 22g 21 21g RM15WTRZB-10PA(**) 109-1695 5 10 20.6 No. of contacts A Weight 24g Note 1 : Screw size : M3 Note 2 : Recommended nut tightening torque : 0.3 to 0.35N•m 7 RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Plug -- Disassembly / Assembly Clamp Gasket Tightening collar Insulator body (P) 3 min Contacts Screw Washer Cable jacket Conductors Wires A Coupling Back shell Strain relief clamp Cable Back shell May.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Tightening ring Table 1 Part No. RM15WTPZA-** RM15WTPZ-** Set screw(2) Cable B RM15WTLP-** No. of contacts A 3 6mm 2,4,8,10,12 3mm 3 6mm 2,4,8,10,12 10,12 3mm B 21mm 12mm 25mm Disassembly 1Fix the plug in the assembly fixture (RM15TP-T01 (HRS No.150-0098-0)), then remove the insulator body (P) and the back shell. 1. Right-angle plugs have set screws in the tightening ring at 2 locations. Loosen the set screws before removing the back shell. 2 Remove the 2 screws of the strain relief clamp, and then remove the clamp from the tightening collar. 2. 3. 4. 5. 8 Wiring 1 Assure that the cable outer diameter will fit the strain relief clamp, and is prepared as recommended in Table 1. It is recommended that the exposed conductors be pre-soldered, to assure easier insertion in the soldering cup. 2 Pass the parts over the cable in the order of: tightening collar, washer, bushing, back shell, and coupling. Refer to the drawings (above) for assembly orientation of all components. 3Solder the wires to the contacts of the insulator body (P). Use of heat-shrink tubing or another insulating media between the soldered contacts is suggested. Connector Assembly Straight Plugs 1 Place the completely wired insulator body (P) in the assembly fixture secured in a vise. Insert in the coupling, then back shell. The back shell should be tightened to a torque of 3N•m. Right-angle Plugs 1 Place the completely wired insulator body (P) in an assembly fixture secured by a vise. Insert in the coupling, then back shell (with tightening ring). When attaching the back shell, orient the cable in the desired direction and fasten the tightening ring to the insulator body (P) with a torque of 3N•m. After this, tighten and fix the 2 sets crews with a torque of 0.2 to 0.25N•m. Additional assembly recommendations : In applications where continuous extremely high vibrations may be encountered it is recommended that a thread locking compound be applied to male threads prior to assembly (Loctite 263 manufactured by Henkel Japan K.K. or equivalent) 2Assemble in the following order : gasket then washer, then the tightening-collar. During assembly, make sure to keep the tip of the cable sheath at least 3mm from the gasket, as shown in the figure (above). 3To prevent loosening of the male threads, apply Loctite 263 (Henkel Japan K.K. or equivalent) to the male threads of the back shell. Then tighten the tightening-collar to a torque of 3N•m with the clamp and the cable so that the cable cannot rotate. (Screw-tightening torque : 0.65 to 0.70N•m) Points to be checked 1This connector has a waterproof feature. Please verify that the assembled connector is waterproof by conducting the test described below. 2Because the force required to secure the strain relief clamp differs with the cable structure, please check the connector assembly before use to make sure there is no rotation. (Test verification of waterproof capability) Apply air pressure of 17.6kPa for 30 seconds from the mating end of the plug connector. No air should leak from inside the connector. Waterproof verification - plug assembly Apply air pressure of 17.6kPa for 30 seconds from the mating side of the plug assembly. There shall not be any air leakage from inside the connector when submerged in the water tank. Precautions The waterproof capability may be impaired if the cable sheath or gasket is damaged or contaminated when performing the assembly. Please handle carefully. RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Receptacle - recommended panel cut-outs Rear mounting, front nut Square flange, screw mounting 20.6±0.05 +0.1 0 Ø24 +0.1 0 Ø7.6 +0.1 0 Ø19.65 +0.05 0 Ø21 20.6±0.05 .1 +0 0 Ø17 4-M3∞0.5 Ø19.2 +0.1 0 Front mounting, rear nut 1.4±0.05 Panel thickness : 0.5 to 2mm Panel thickness : 0.5 to 2.5mm May.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. For RM15WTRZ receptacles For RM15WTRZA receptacles Panel thickness : 2.5 to 4mm For RM15WTRZB receptacles Note 1 : When attaching the receptacle to the panel, be certain to check that the gasket is in place in the groove. Do not pinch the gasket. Note 2 : The view of the above diagrams is from the receptacle mating side. Note 3 : The ▼ symbol in the above diagrams indicates the coupling guide position of the receptacles. Contact Arrangement and Specifications Shell size : 15 Contact arrangement 2 No. of contacts 3 Withstanding voltage 1,800V AC / 1 minute 2,000V AC / 1 minute Current rating 8 10A 10 12 1,000V AC / 1 minute 5A 1,000Mø min. Insulation resistance 2mø max. Contact resistance Solder pot inner diameter 4 1,500V AC / 1 minute 1.7mm 2.8mm 4mø max. 1.7mm 1.1mm Note 1 : The contact configuration as viewed from the wiring side. Note 2 : The ▼ symbol in the above diagrams indicates the coupling guide position of the receptacles. Note 3 : Withstanding voltages indicate test voltage values. Precautions 1. Switch off the power of the circuit before disconnecting or plugging- in the connectors. 2. Use a connectors with socket contacts at the power side of the circuit. 3. Make sure that the coupling is in completely cocked position. 4. Use correct plug / receptacle to assure dust and water protection. 9 RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Product Specifications (RM21WT to RM31WT size products) Rating Voltage rating 600V AC, 840V DC (40 pos.) 500V AC, 700V DC (15, 55 pos.) 350V AC, 490V DC (20 pos.) Current rating 5A Operating temperature range (Note 1) -25ç to +85ç Storage temperature range (Note 2) -10ç to +60ç May.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Characteristic Specification Conditions 1. Contact resistance 4mø max. 1A DC 2. Insulation resistance 1,000Mø min 500V DC 3. Withstanding voltage No flashover or insulation breakdown. 1,800V AC/1 minute (40 pos.) 1,500V AC/1 minute (15, 55 pos.) 1,000V AC/1 minute (20 pos.) 4. Vibration No electrical discontinuity for 10μs max. Frequency : 10 to 55Hz, single amplitude of 0.75mm, for 3 hours in 3 axis. 5. Shock No electrical discontinuity for 10μs max. Acceleration of 490m/s2, 11ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis. 6. Durability (insertion/withdrawal) 8mø max. 2,000 cycles 7. Temperature cycle Insulation resistance : 100Mø min. Temperature : -55ç ➝ Room temperature ➝ +85ç ➝ Room temperature Time : 30 ➝ 10 to 15 ➝ 30 ➝ 10 to 15 (Minutes) 5 cycles 8. Humidity Insulation resistance : 100Mø min. (Dray state) 96 hours at temperature of 40ç and humidity of 90% to 95%. 9. Water / dust protection When mated with corresponding connector. Complete dust protection. No water penetration when submerged for 48 hours at the depth of 1.8 meter. Note 1 : Includes temperature rise caused by the current flow. Note 2 : The term “storage” refers to products stored for long period of time prior to mounting and use. Operating temperature range and humidity range covers non-conducting condition of installed connectors in storage, shipment or during transportation. Materials / Finish Item Material Finish Remarks Body Brass Chrome plated or nickel plated ------------------- Insulator Diallyl phthalate resin ------------------- UL94V-0 (Color : Black) Contacts Brass, copper alloy Silver plated ------------------- Packing Chloroprene rubber or SIR ------------------- (Color : Black) Note : Do not mix different contact plating. ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. RM 31 W T P* - 40 S (** ) 1 2 1 3 4 5 6 7 1 Series name : RM-W 5 Number of contacts 2 Shell size 6 Contact type P : Male contact S : Female contact 3 Lock type T : Screw Lock 4 Connector type P : Plug R : Receptacle 7 Other specifications A two-digit number is added to indicate other specifications. RM 21 W T P - CP (10) (** ) 8 8 CP: Strain relief 10 9 7 : External cable clamp 9 () with () without : Internal cable clamp Numbers : Cable size RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors D Plugs - Straight Short Back Shell Set screw E 8 RM21WTP-15P(31) 9 7 15 11 1 13 10 14 ØB ØA Y 6 12 5 2 3 Z 4 C HRS No. 109-1401-2 31 109-1403-8 31 109-1402-5 31 109-1404-0 31 109-1571-2 71 109-1573-8 85 109-1572-5 71 109-1574-0 71 No. of contacts ØA ØB C E F 21 32 37.5 TM25∞2 M20∞0.75 15 20 40 Weight 86g 85g 88g 85g 152g 30.8 42 52 TM35∞2 M28∞0.75 55 Remarks Silver plated only 157g 150g Note : Recommended set screw tightening torque : 0.2 to 0.3 N•m. Applicable Strain Reliefs External cable clamp + internal, self-tightening JR16WCC-10(72) ØA ØB E Wrench opening dimension D C (Representative example) Part No. JR16WCC-4(72) JR16WCC-6(72) JR16WCC-8(72) JR16WCC-10(72) JR16WCC-11(72) JR16WCC-12(72) HRS No. 114-2052-6 72 114-2053-9 72 114-2054-1 72 114-2055-4 72 114-2154-6 72 114-2056-7 72 ØA 4 6 8 10 11 12 ØB 23 C 17.5 D 21 E Weight M20∞0.75 Remarks For RM21WT 17.5g (No locking screw attached) Note 1 : Cable jacket diameter:Use A ± 0.2mm. Note 2 : HRS recommended tool : 1.27mm Hex Wrench Note 3 : Recommended set screw tightening torque : 0.3 to 0.4N•m. Internal, self tightening E RM21WTP-CP(8)(71) Set screw ØB ØA May.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Representative example) Part No. RM21WTP-15S(31) RM21WTP-15P(31) RM21WTP-20S(31) RM21WTP-20P(31) RM31WTP-40S(71) RM31WTP-40P(85) RM31WTP-55S(71) RM31WTP-55P(71) D C (Representative example) Part No. RM21WTP-CP(8)(71) RM21WTP-CP(10)(71) RM21WTP-CP(12)(71) RM31WTP-CP(10)(71) RM31WTP-CP(12)(71) RM31WTP-CP(14)(71) RM31WTP-CP(16)(71) RM31WTP-CP(18)(71) HRS No. 109-1405-3 71 109-1406-6 71 109-1407-9 71 109-1575-3 71 109-1576-6 71 109-1579-4 71 109-1577-9 71 109-1578-1 71 ØA 8 10 12 10 12 14 16 18 ØB C D E 23 38 7.5 M20∞0.75 Weight 22.5g 22g 21.5g Remarks For RM21WT 46g 31 42 12 M28∞0.75 45g 43.5g 42g For RM31WT Note 1 : Cable jacket diameter : Use A ± 0.2mm. Note 2 : Code cramp No. should be the same as connector shell No. Note 3 : When using the self-tightening strain relief verify the cable pull force requirements. Note 4 : Recommended set screw tightening torque : 0.2 to 0.3N•m. 11 RM-W Series● -Original Multi-purpose High-pin-count Miniature Waterproof Connectors Receptacles Front panel mount 2 Z 14 15 7 9 Y Y 7 9 6 14 10 13 5 10 12 1 15 1 11 13 ØA 5 12 11 4 2 4 6 Z 3 3 RM21WTR-15P(31) 8 8 C F D B E May.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Representative example) Part No. RM21WTR-15P(31) HRS No. 109-1445-8 31 No. of contacts RM21WTR-20P(31) RM31WTR-40S(85) RM31WTR-40P(71) RM31WTR-55S(71) RM31WTR-55P(71) 109-1446-0 31 109-1527-0 85 109-1525-5 71 109-1528-3 71 109-1526-8 71 20 ØA 15 B C D E 31 F 23.5 40 21 6.5 Weight TM25∞2 2.5 41 34 TM35∞2 55 Remarks 28g 31.5g 52g 50g 54g 53.5g Silver plated only Receptacle - recommended panel cut-out Front mounting, rear nut Part No. R C ØA B ØA B RC For RM21WTR 22.1 12.75 0.8 For RM31WTR 32.1 17.75 0.85 Note : Tolelance is +0.1/0. Panel thickness : 0.5 to 2mm For RM**WTR receptacles Note 1 : When attaching the receptacle to the panel, be certain to check that the gasket is in place in the groove. Do not pinch the gasket. Note 2 : The view of the above diagrams is from the receptacle mating side. Note 3 : The ▼ symbol in the above diagrams indicates the coupling guide position of the receptacles. Contact Arrangement and Specifications Shell size : 21 Shell size : 31 9 Contact arrangement 10 1 15 11 2 8 3 13 7 6 9 17 8 16 12 14 Number of contacts Withstanding voltage Current rating Insulation resistance Contact resistance Solder pot inner diameter 10 7 4 15 6 5 15 1,500V AC / 1 minute 18 19 1 11 2 12 3 20 14 13 4 5 20 1,000V AC / 1 minute 5A 1,000Mø min. 4mø max. 1.1mm 17 18 19 1 2 3 21 22 15 4 49 39 47 23 50 33 54 55 5 14 46 40 24 32 51 53 6 13 41 52 45 44 42 25 31 26 30 43 27 29 12 7 28 11 8 9 10 16 34 35 36 48 37 20 38 55 1,500V AC / 1 minute Note 1 : The contact configuration as viewed from the wiring side. Note 2 : The ▼ symbol in the above diagrams indicates the coupling guide position of the receptacles. Note 3 : Withstanding voltages indicate test voltage values.   Precautions 1. Switch off the power of the circuit before disconnecting or plugging- in the connectors. 2. Use a connectors with socket contacts at the power side of the circuit. 3. Make sure that the coupling is in completely locked position. 4. Use correct plug / receptacle to assure dust and water protection. ® 12 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 07/2018. Contents are subject to change without notice for the purpose of improvements.
RM15WTPZ-12S(71)
物料型号: - 该文档描述了Hirose Electric Co., Ltd. 制造的RM-W系列微型多用途高引脚数防水连接器。
器件简介: - RM-W系列连接器是为满足小型封装中高能力的需要而开发的,具有多种变化,包括不同类型的插头和插座,以及丰富的固定方式和电缆布局选项。
引脚分配: - 提供了2、3、4、8、10、12、15、20、40和55引脚的选项,并且有两种接触镀层类型:金和银。
参数特性: - 包括电压等级、电流等级、操作温度范围、存储温度范围、接触电阻、绝缘电阻、耐电压、振动、冲击、耐久性(插拔次数)、温度循环和湿度等。
功能详解: - 连接器采用螺纹耦合结构,具有出色的防水可靠性。当完全配合时,连接器满足IP67和IP68的防水要求。
应用信息: - 适用于需要高可靠性的应用,例如汽车领域。文档还提供了有关如何组装和使用连接器的详细信息。
封装信息: - 提供了不同类型插头和插座的尺寸和重量信息,以及适用的电缆固定方法和推荐工具。
RM15WTPZ-12S(71) 价格&库存
很抱歉,暂时无法提供与“RM15WTPZ-12S(71)”相匹配的价格&库存,您可以联系我们找货
