8P1P014200GRB01
8P1P014200GRB01
    NORCOMP
    8P1P014200GRB01
8P1P014200GRB01 数据手册
DESCRIPTION: QUIK-LOQ - FEMALE - SOLDER CUP - PANEL MOUNT - PLASTIC UNITS = MM [INCHES] CHARACTERISTICS MATERIALS HOUSING : ABS+PC HOUSING COLOR : GREY NUT A : BRASS NUT A PLATING : NICKEL CONTACTS : COPPER ALLOY CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN. INSULATOR : PPS (HIGH TEMPERATURE) 8P1P YYY 2 0 0 YRB 01 1 = GOLD FLASH SERIES 14.00 [0.551] RoHS COMPLIANT NUT "B" COLOR G = GREY A = BLUE J = YELLOW N = BLACK R = RED V = GREEN # OF POSITIONS (Ex. 002) **SEE CHART A** 2 = FEMALE SOLDER CUP (PANEL MOUNT) PLASTIC SHELL MECHANICAL DURABILITY: 2000 CYCLES OPERATING TEMP. RANGE: -20 C ~ +120 C PROCESS TEMPERATURE : 260 C FOR 5 SECONDS MAX. TORQUE VALUE : 0.7 Nm [6.19 IN/lbs] 0.896 22.75 IP RATING: 50 0.797 20.25 0 4.0 1] 55 [0. 0.496 12.60 0.728 18.50 0.488 12.40 (ACROSS FLATS) 0.669 17.00 M14*1.0 1 TOLERANCE = +0.10, -0.0 [+0.004, -0.00] 0.276 7.00 (MAX. PANEL THICKNESS) CHART A 1 1 2 POSITION 22 AWG MAX. 10 AMP MAX. PIN = 1.30 [0.051] CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1200V WORKING VOLTAGE = 400V 3 POSITION 22 AWG MAX. 10 AMP MAX. PIN = 1.30 [0.051] CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1200V WORKING VOLTAGE = 400V 4 POSITION 22 AWG MAX. 8 AMP MAX. PIN = 0.90 [0.035] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1200V WORKING VOLTAGE = 400V RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 600V WORKING VOLTAGE = 200V **VIEW FROM TERMINATION END** = KEY LOCATION 1 14 POSITION 26 AWG MAX. 2 AMP MAX. PIN = 0.50 [0.020] PANEL CUTOUT NUT B NUT A 1 1 1 1 1 1 1 5 POSITION 22 AWG MAX. 7 AMP MAX. PIN = 0.90 [0.035] 6 POSITION 24 AWG MAX. 6 AMP MAX. PIN = 0.70 [0.028] 7 POSITION 24 AWG MAX. 5 AMP MAX. PIN = 0.70 [0.028] 8 POSITION 24 AWG MAX. 5 AMP MAX. PIN = 0.70 [0.028] 9 POSITION 26 AWG MAX. 3 AMP MAX. PIN = 0.50 [0.020] 10 POSITION 26 AWG MAX. 3 AMP MAX. PIN = 0.50 [0.020] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 850V WORKING VOLTAGE = 280V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 850V WORKING VOLTAGE = 280V NorComp DRAWN: M. SIGMON DATE: 07-29-16 SCALE: N.T.S. SHEET 1 DWG NO. OF 1 REV: 8P1PYYY200YRB01 2
8P1P014200GRB01 价格&库存
很抱歉,暂时无法提供与“8P1P014200GRB01”相匹配的价格&库存,您可以联系我们找货
