DESCRIPTION: QUIK-LOQ - FEMALE - SOLDER CUP - PANEL MOUNT
UNITS = MM [INCHES]
CHARACTERISSTICS
MATERIALS
SHELL : BRASS
SHELL PLATING : NICKEL
NUT : BRASS
NUT PLATING : NICKEL
LATCH SLEEVE : BRASS
LATCH SLEEVE PLATING : NICKEL
CONTACTS : COPPER ALLOY
CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN.
INSULATOR : PPS (HIGH TEMPERATURE)
821B YYY - 2 0 3 R 00 1
1 = GOLD FLASH
SERIES
12.00 [0.475]
# OF POSITIONS
(Ex. 002)
**SEE CHART A**
2 = FEMALE
RoHS COMPLIANT
SOLDER CUP (PANEL MOUNT)
MECHANICAL
DURABILITY: 5000 CYCLES
OPERATING TEMP. RANGE: -40 C ~ +200 C
PROCESS TEMPERATURE : 260 C FOR 5 SECONDS
MAX. TORQUE VALUE : 4.5 Nm [39 IN/lbs]
SHIELDING: 75dB @ 10MHz
40dB @ 1GHz
NICKEL/CHROME PLATED SHELL
0.913
23.20
0.736
18.70
IP RATING: 50
.1
6]
47
[0.
0.417
10.60
0.630
16.00
0.413
10.50
(ACROSS FLATS)
0.551
14.00
M12*1.0
12
PANEL CUTOUT
0.126
3.20
TOLERANCE = +0.10, -0.0
[+0.004, -0.00]
0.236
6.00
(MAX. PANEL THICKNESS)
CHART A
1
1
1
2 POSITION
20 AWG MAX.
15 AMP MAX.
PIN
= 1.30 [0.051]
CONTACT
RESISTANCE = 5 mΩ
TEST VOLTAGE = 1500V
WORKING VOLTAGE = 500V
3 POSITION
20 AWG MAX.
12 AMP MAX.
PIN
= 1.30 [0.051]
CONTACT
RESISTANCE = 5 mΩ
TEST VOLTAGE = 1300V
WORKING VOLTAGE = 430V
4 POSITION
22 AWG MAX.
10 AMP MAX.
PIN
= 0.90 [0.035]
CONTACT
RESISTANCE = 6 mΩ
RoHS COMPLIANT
N
C
**VIEW FROM TERMINATION END**
= KEY LOCATION
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF NorComp AND
SHALL NOT BE REPRODUCED, COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
1
1
1
1
1
1
5 POSITION
22 AWG MAX.
9 AMP MAX.
PIN
= 0.90 [0.035]
6 POSITION
24 AWG MAX.
7 AMP MAX.
PIN
= 0.70 [0.028]
7 POSITION
24 AWG MAX.
7 AMP MAX.
PIN
= 0.70 [0.028]
8 POSITION
24 AWG MAX.
5 AMP MAX.
PIN
= 0.70 [0.028]
10 POSITION
28 AWG MAX.
2.5 AMP MAX.
PIN
= 0.50 [0.020]
14 POSITION
28 AWG MAX.
2 AMP MAX.
PIN
= 0.50 [0.020]
CONTACT
RESISTANCE = 6 mΩ
TEST VOLTAGE = 1250V
WORKING VOLTAGE = 415V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 1050V
WORKING VOLTAGE = 350V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 950V
WORKING VOLTAGE = 315V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 950V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 900V
WORKING VOLTAGE = 300V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 800V
WORKING VOLTAGE = 260V
NorComp
DRAWN:
M. SIGMON
DATE:
02-05-16
SCALE:
N.T.S.
SHEET
1
DWG NO.
OF
1
821BYYY-203R001
REV:
3
很抱歉,暂时无法提供与“821B006-203R001”相匹配的价格&库存,您可以联系我们找货
