DESCRIPTION: QUIK-LOQ - FEMALE - VERTICAL - PANEL MOUNT
UNITS = MM [INCHES]
CHARACTERISSTICS
MATERIALS
SHELL : BRASS
SHELL PLATING : NICKEL
NUT : BRASS
NUT PLATING : NICKEL
LATCH SLEEVE : BRASS
LATCH SLEEVE PLATING : NICKEL
CONTACTS : COPPER ALLOY
CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN.
INSULATOR : PPS (HIGH TEMPERATURE)
821B YYY - 2 1 3 R 00 1
1 = GOLD FLASH
SERIES
12.00 [0.475]
# OF POSITIONS
(Ex. 002)
**SEE CHART A**
2 = FEMALE
RoHS COMPLIANT
VERTICAL (PANEL MOUNT)
MECHANICAL
DURABILITY: 5000 CYCLES
OPERATING TEMP. RANGE: -40 C ~ +200 C
PROCESS TEMPERATURE : 260 C FOR 5 SECONDS
MAX. TORQUE VALUE : 4.5 Nm [39 IN/lbs]
SHIELDING: 75dB @ 10MHz
40dB @ 1GHz
NICKEL/CHROME PLATED SHELL
0.945
24.00
0.736
18.70
IP RATING: 50
0.126
3.20
.1
0.417
10.60
PANEL CUTOUT
TOLERANCE = +0.10, -0.0
[+0.004, -0.00]
0.197
5.00
(MAX. PANEL THICKNESS)
CHART A
= KEY LOCATION
1
1
1
2 POSITION
15 AMP MAX.
PIN
= 1.30 [0.051]
CONTACT
RESISTANCE = 5 mΩ
TEST VOLTAGE = 1500V
WORKING VOLTAGE = 500V
3 POSITION
12 AMP MAX.
PIN
= 1.30 [0.051]
CONTACT
RESISTANCE = 5 mΩ
TEST VOLTAGE = 1300V
WORKING VOLTAGE = 430V
4 POSITION
10 AMP MAX.
PIN
= 0.90 [0.035]
CONTACT
RESISTANCE = 6 mΩ
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF NorComp AND
SHALL NOT BE REPRODUCED, COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
6]
47
[0.
0.630
16.00
0.551
14.00
M12*1.0
0.413
10.50
(ACROSS FLATS)
12
**NOTE**
SEE PAGE 2 FOR BOARD LAYOUTS
**VIEW FROM TERMINATION END**
1
1
1
1
1
1
5 POSITION
9 AMP MAX.
PIN
= 0.90 [0.035]
6 POSITION
7 AMP MAX.
PIN
= 0.70 [0.028]
7 POSITION
7 AMP MAX.
PIN
= 0.70 [0.028]
8 POSITION
5 AMP MAX.
PIN
= 0.70 [0.028]
10 POSITION
2.5 AMP MAX.
PIN
= 0.50 [0.020]
14 POSITION
2 AMP MAX.
PIN
= 0.50 [0.020]
CONTACT
RESISTANCE = 6 mΩ
TEST VOLTAGE = 1250V
WORKING VOLTAGE = 415V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 1050V
WORKING VOLTAGE = 350V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 950V
WORKING VOLTAGE = 315V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 950V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 900V
WORKING VOLTAGE = 300V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 800V
WORKING VOLTAGE = 260V
NorComp
DRAWN:
M. SIGMON
DATE:
02-10-16
SCALE:
N.T.S.
SHEET
1
DWG NO.
OF
2
821BYYY-213R001
REV:
3
UNITS = MM [INCHES]
BOARD LAYOUTS
A
= KEY LOCATION
45° .
P
TY
0°
12 P.
TY
B
3
TY 6°
P.
B
B
B
A
3 POS
4 POS
5 POS
6 POS
A = 0.80 [0.031]
A = 0.80 [0.031]
A = 0.80 [0.031]
A = 0.80 [0.031]
B = 2.80 [0.110]
B = 3.00 [0.118]
B = 3.10 [0.122]
B = 3.40 [0.134]
B = 3.70 [0.146]
86
B
7 POS
B = 3.70 [0.146]
RoHS COMPLIANT
B
C
.7
8 POS
A = 0.80 [0.031]
B = 3.80 [0.150]
NorComp
A
1°
A
B
C
25
A = 0.80 [0.031]
3
TY 6°
P.
18°
TYP
45 P.
TY
60
TY °
P.
2.
.43
A
B
10
51
22
TY .5°
P.
2 POS
A = 0.80 [0.031]
A
N
C
72 P.
TY
A
A
60
TY °
P.
A
DRAWN:
10 POS
14 POS
A = 0.60 [0.024]
A = 0.60 [0.024]
B = 3.95 [0.156]
B = 4.40 [0.173]
C = 1.40 [0.055]
C = 1.90 [0.075]
M. SIGMON
DATE:
02-10-16
SCALE:
N.T.S.
SHEET
2
DWG NO.
OF
2
821BYYY-213R001
REV:
3
很抱歉,暂时无法提供与“821B003-213R001”相匹配的价格&库存,您可以联系我们找货
