820B004-173L501
820B004-173L501
    NORCOMP
    820B004-173L501
820B004-173L501 数据手册
DESCRIPTION: QUIK-LOQ - MALE - CABLE MOUNT UNITS = MM [INCHES] 820B YYY - 1 7 3 L YY 1 CHARACTERISSTICS MATERIALS HOUSING : BRASS HOUSING PLATING : 196µ" NICKEL MIN. SHELL & COLLET NUT: BRASS, 196µ" CHROME PLATED MIN. CONTACTS : COPPER ALLOY CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN. INSULATOR : PPS (HIGH TEMPERATURE) STRAIN RELIEF(BOOT) : THERMPLASTIC POLYURETHANE 1 = GOLD FLASH SERIES 9.50 [0.374] COLLET SIZE **SEE CHART B** # OF POSITIONS (Ex. 002) **SEE CHART A** 1 = MALE RoHS COMPLIANT CABLE MOUNT MECHANICAL DURABILITY: 5000 CYCLES OPERATING TEMP. RANGE: -40 C ~ +200 C PROCESS TEMPERATURE : 260 C FOR 5 SECONDS MAX. TOURQUE VALUE : 0.5 Nm [4.4 IN/LBS] SHIELDING: 75dB @ 10MHz 40dB @ 1GHz NICKEL/CHROME PLATED SHELL IP RATING: 50 1.378 35.00 CHART B 0.984 25.00 CHART A = KEY LOCATION 1 1 1 2 POSITION 22 AWG MAX. 10 AMP MAX. PIN = 0.90 [0.035] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1000V WORKING VOLTAGE = 330V 3 POSITION 22 AWG MAX. 8 AMP MAX. PIN = 0.90 [0.035] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1200V WORKING VOLTAGE = 400V 4 POSITION 24 AWG MAX. 7 AMP MAX. PIN = 0.70 [0.028] CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 850V WORKING VOLTAGE = 280V RoHS COMPLIANT N C 0.315 8.00 (ACROSS FLATS) 0.315 8.00 (ACROSS FLATS) 0.374 9.50 COLLET SIZE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. WIRE DIAMETER 30 2.50 [0.098] ~ 3.20 [0.126] 40 3.30 [0.130] ~ 4.20 [0.165] 50 4.30 [0.169] ~ 5.20 [0.205] **VIEW FROM TERMINATION END** 1 1 1 1 5 POSITION 24 AWG MAX. 6.5 AMP MAX. PIN = 0.70 [0.028] 6 POSITION 28 AWG MAX. 2.5 AMP MAX. PIN = 0.50 [0.020] 7 POSITION 28 AWG MAX. 2.5 AMP MAX. PIN = 0.50 [0.020] 9 POSITION 28 AWG MAX. 2 AMP MAX. PIN = 0.50 [0.020] CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 850V WORKING VOLTAGE = 280V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 850V WORKING VOLTAGE = 280V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 800V WORKING VOLTAGE = 260V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 600V WORKING VOLTAGE = 200V NorComp DRAWN: M. SIGMON DATE: 02-02-16 SCALE: N.T.S. SHEET 1 DWG NO. OF 1 820BYYY-173LYY1 REV: 6
820B004-173L501 价格&库存
很抱歉,暂时无法提供与“820B004-173L501”相匹配的价格&库存,您可以联系我们找货
820B004-173L501
  • 1+320.003001+41.41008
820B004-173L501
    库存:53
