DESCRIPTION: QUIK-LOQ - MALE - CABLE MOUNT
UNITS = MM [INCHES]
820B YYY - 1 7 3 L YY 1
CHARACTERISSTICS
MATERIALS
HOUSING : BRASS
HOUSING PLATING : 196µ" NICKEL MIN.
SHELL & COLLET NUT: BRASS, 196µ" CHROME PLATED MIN.
CONTACTS : COPPER ALLOY
CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN.
INSULATOR : PPS (HIGH TEMPERATURE)
STRAIN RELIEF(BOOT) : THERMPLASTIC POLYURETHANE
1 = GOLD FLASH
SERIES
9.50 [0.374]
COLLET SIZE
**SEE CHART B**
# OF POSITIONS
(Ex. 002)
**SEE CHART A**
1 = MALE
RoHS COMPLIANT
CABLE MOUNT
MECHANICAL
DURABILITY: 5000 CYCLES
OPERATING TEMP. RANGE: -40 C ~ +200 C
PROCESS TEMPERATURE : 260 C FOR 5 SECONDS
MAX. TOURQUE VALUE : 0.5 Nm [4.4 IN/LBS]
SHIELDING: 75dB @ 10MHz
40dB @ 1GHz
NICKEL/CHROME PLATED SHELL
IP RATING: 50
1.378
35.00
CHART B
0.984
25.00
CHART A
= KEY LOCATION
1
1
1
2 POSITION
22 AWG MAX.
10 AMP MAX.
PIN
= 0.90 [0.035]
CONTACT
RESISTANCE = 6 mΩ
TEST VOLTAGE = 1000V
WORKING VOLTAGE = 330V
3 POSITION
22 AWG MAX.
8 AMP MAX.
PIN
= 0.90 [0.035]
CONTACT
RESISTANCE = 6 mΩ
TEST VOLTAGE = 1200V
WORKING VOLTAGE = 400V
4 POSITION
24 AWG MAX.
7 AMP MAX.
PIN
= 0.70 [0.028]
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 850V
WORKING VOLTAGE = 280V
RoHS COMPLIANT
N
C
0.315
8.00
(ACROSS FLATS)
0.315
8.00
(ACROSS FLATS)
0.374
9.50
COLLET
SIZE
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF NorComp AND
SHALL NOT BE REPRODUCED, COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
WIRE DIAMETER
30
2.50 [0.098] ~ 3.20 [0.126]
40
3.30 [0.130] ~ 4.20 [0.165]
50
4.30 [0.169] ~ 5.20 [0.205]
**VIEW FROM TERMINATION END**
1
1
1
1
5 POSITION
24 AWG MAX.
6.5 AMP MAX.
PIN
= 0.70 [0.028]
6 POSITION
28 AWG MAX.
2.5 AMP MAX.
PIN
= 0.50 [0.020]
7 POSITION
28 AWG MAX.
2.5 AMP MAX.
PIN
= 0.50 [0.020]
9 POSITION
28 AWG MAX.
2 AMP MAX.
PIN
= 0.50 [0.020]
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 850V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 850V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 800V
WORKING VOLTAGE = 260V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 600V
WORKING VOLTAGE = 200V
NorComp
DRAWN:
M. SIGMON
DATE:
02-02-16
SCALE:
N.T.S.
SHEET
1
DWG NO.
OF
1
820BYYY-173LYY1
REV:
6
很抱歉,暂时无法提供与“820B004-173L401”相匹配的价格&库存,您可以联系我们找货
