821K004-203R001
821K004-203R001
    NORCOMP
    821K004-203R001
821K004-203R001 数据手册
DESCRIPTION: QUIK-LOQ - FEMALE - SOLDER CUP - PANEL MOUNT - IP67 UNITS = MM [INCHES] 821K YYY - 2 0 3 R 00 1 CHARACTERISSTICS MATERIALS SHELL : BRASS SHELL PLATING : NICKEL NUT : BRASS NUT PLATING : NICKEL LATCH SLEEVE : BRASS LATCH SLEEVE PLATING : NICKEL CONTACTS : COPPER ALLOY CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN. INSULATOR : PPS (HIGH TEMPERATURE) O-RING: SILICONE 1 = GOLD FLASH SERIES 13.00 [0.512] # OF POSITIONS (Ex. 002) **SEE CHART A** 2 = FEMALE RoHS COMPLIANT SOLDER CUP (PANEL MOUNT) NICKEL/CHROME PLATED SHELL MECHANICAL DURABILITY: 5000 CYCLES OPERATING TEMP. RANGE: -40 C ~ +200 C PROCESS TEMPERATURE : 260 C FOR 5 SECONDS MAX. TORQUE VALUE : 7.0 Nm [61.0 IN/lbs] SHIELDING: 75dB @ 10MHz 40dB @ 1GHz 1.094 27.80 0.945 24.00 16 CHART A 34 ] 1 1 3 POSITION 20 AWG MAX. 12 AMP MAX. PIN = 1.30 [0.051] CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1300V WORKING VOLTAGE = 430V 4 POSITION 22 AWG MAX. 10 AMP MAX. PIN = 0.90 [0.035] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1300V WORKING VOLTAGE = 430V PANEL CUTOUT 0.177 4.50 = KEY LOCATION 1 CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1500V WORKING VOLTAGE = 500V 0 .6 0.575 14.60 0.295 7.50 (MAX. PANEL THICKNESS) 2 POSITION 20 AWG MAX. 15 AMP MAX. = 1.30 [0.051] PIN [ .1 0 0.787 20.00 M16*1.0 0.571 14.50 (ACROSS FLATS) 0.748 19.00 IP RATING: 67 TOLERANCE = +0.10, -0.0 [+0.004, -0.00] **VIEW FROM TERMINATION END** 1 1 1 5 POSITION 22 AWG MAX. 9 AMP MAX. PIN = 0.90 [0.035] 6 POSITION 24 AWG MAX. 7 AMP MAX. PIN = 0.70 [0.028] 7 POSITION 24 AWG MAX. 7 AMP MAX. PIN = 0.70 [0.028] 14 POSITION 28 AWG MAX. 2 AMP MAX. PIN = 0.50 [0.020] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1250V WORKING VOLTAGE = 415V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 950V WORKING VOLTAGE = 315V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 800V WORKING VOLTAGE = 267V RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. NorComp DRAWN: M. SIGMON DATE: 02-25-16 SCALE: SHEET N.T.S. REV: OF 1 DWG NO. 1 821KYYY-203R001 3
821K004-203R001 价格&库存
很抱歉,暂时无法提供与“821K004-203R001”相匹配的价格&库存,您可以联系我们找货
