821B006-173L401
821B006-173L401
    NORCOMP
    821B006-173L401
821B006-173L401 数据手册
DESCRIPTION: QUIK-LOQ - MALE - CABLE MOUNT UNITS = MM [INCHES] CHARACTERISSTICS MATERIALS HOUSING : BRASS HOUSING PLATING : 196µ" NICKEL MIN. SHELL & COLLET NUT: BRASS, 196µ" CHROME PLATED MIN. CONTACTS : COPPER ALLOY CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN. INSULATOR : PPS (HIGH TEMPERATURE) STRAIN RELIEF(BOOT) : THERMOPLASTIC POLYURETHANE 821B YYY - 1 7 3 L YY 1 1 = GOLD FLASH SERIES 12.00 [0.475] COLLET SIZE **SEE CHART B** # OF POSITIONS (Ex. 002) **SEE CHART A** 1 = MALE RoHS COMPLIANT CABLE MOUNT MECHANICAL DURABILITY: 5000 CYCLES OPERATING TEMP. RANGE: -40 C ~ +200 C PROCESS TEMPERATURE : 260 C FOR 5 SECONDS MAX. TOURQUE VALUE : 1.5 Nm [13.2 IN/LBS] SHIELDING: 75dB @ 10MHz 40dB @ 1GHz NICKEL/CHROME PLATED SHELL 1.614 41.00 IP RATING: 50 CHART B 1.181 30.00 CHART A 1 1 CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1500V WORKING VOLTAGE = 500V 3 POSITION 20 AWG MAX. 12 AMP MAX. PIN = 1.30 [0.051] CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1300V WORKING VOLTAGE = 430V 4 POSITION 22 AWG MAX. 10 AMP MAX. PIN = 0.90 [0.035] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1300V WORKING VOLTAGE = 430V RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. WIRE DIAMETER 40 3.30 [0.130] ~ 4.20 [0.165] 50 4.30 [0.169] ~ 5.20 [0.205] 60 5.30 [0.209] ~ 6.20 [0.244] 70 6.30 [0.248] ~ 7.20 [0.283] **VIEW FROM TERMINATION END** = KEY LOCATION 1 2 POSITION 20 AWG MAX. 15 AMP MAX. PIN = 1.30 [0.051] 0.354 9.00 0.394 10.00 0.472 12.00 COLLET SIZE 1 1 1 1 1 1 5 POSITION 22 AWG MAX. 9 AMP MAX. PIN = 0.90 [0.035] 6 POSITION 24 AWG MAX. 7 AMP MAX. PIN = 0.70 [0.028] 7 POSITION 24 AWG MAX. 7 AMP MAX. PIN = 0.70 [0.028] 8 POSITION 28 AWG MAX. 5 AMP MAX. PIN = 0.70 [0.028] 10 POSITION 28 AWG MAX. 2.5 AMP MAX. PIN = 0.50 [0.020] 14 POSITION 28 AWG MAX. 2 AMP MAX. PIN = 0.50 [0.020] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1250V WORKING VOLTAGE = 415V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 950V WORKING VOLTAGE = 315V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 950V WORKING VOLTAGE = 315V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 900V WORKING VOLTAGE = 300V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 800V WORKING VOLTAGE = 260V NorComp DRAWN: M. SIGMON DATE: 02-03-16 SCALE: N.T.S. SHEET 1 DWG NO. OF 1 821BYYY-173LYY1 REV: 8
821B006-173L401
物料型号:821B系列
器件简介:QUIK-LOQ系列是电缆安装的连接器,具有不同的针位数量和最大电流容量。
引脚分配:文档提供了不同针位数量的连接器,包括3、4、5、6、7、8、10和14针位,以及它们对应的最大电流容量和导线规格。
参数特性: - 接触电阻:从5 mΩ到10 mΩ不等 - 测试电压:从900V到1500V不等 - 工作电压:从260V到500V不等 - 机械耐久性:5000次循环 - 操作温度范围:-40°C至+200°C - 过程温度:最多260°C持续5秒 - 扭矩值:1.5 Nm [13.2 IN/LBS] - 屏蔽效能:在10MHz时75dB,在1GHz时40dB
功能详解:QUIK-LOQ连接器设计用于高电流和高电压应用,具有高机械耐久性和宽温度范围。
应用信息:适用于需要高电流和高电压传输的应用场合。
封装信息:材料包括黄铜、铜合金接触点、PPS(高温)绝缘体和热塑性聚氨酯应变缓解套。外壳和套圈螺母采用196µ"镍最小镀层和7µ"金镀层。
821B006-173L401 价格&库存
很抱歉,暂时无法提供与“821B006-173L401”相匹配的价格&库存,您可以联系我们找货
