821B004-273L501
821B004-273L501
    NORCOMP
    821B004-273L501
821B004-273L501 数据手册
DESCRIPTION: QUIK-LOQ - FEMALE - CABLE MOUNT UNITS = MM [INCHES] CHARACTERISSTICS MATERIALS HOUSING : BRASS HOUSING PLATING : 196µ" NICKEL MIN. SHELL & COLLET NUT: BRASS, 196µ" CHROME PLATED MIN. CONTACTS : COPPER ALLOY CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN. INSULATOR : PPS (HIGH TEMPERATURE) STRAIN RELIEF(BOOT) : THERMOPLASTIC POLYURETHANE 821B YYY - 2 7 3 L YY 1 1 = GOLD FLASH SERIES 12.00 [0.475] COLLET SIZE **SEE CHART B** # OF POSITIONS (Ex. 002) **SEE CHART A** 2 = FEMALE RoHS COMPLIANT CABLE MOUNT MECHANICAL DURABILITY: 5000 CYCLES OPERATING TEMP. RANGE: -40 C ~ +200 C PROCESS TEMPERATURE : 260 C FOR 5 SECONDS MAX. TOURQUE VALUE : 1.5 Nm [13.2 IN/LBS] SHIELDING: 75dB @ 10MHz 40dB @ 1GHz NICKEL/CHROME PLATED SHELL IP RATING: 50 1.575 40.00 CHART B CHART A 1 1 CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1500V WORKING VOLTAGE = 500V 3 POSITION 20 AWG MAX. 12 AMP MAX. PIN = 1.30 [0.051] CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1300V WORKING VOLTAGE = 430V 4 POSITION 22 AWG MAX. 10 AMP MAX. PIN = 0.90 [0.035] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1300V WORKING VOLTAGE = 430V RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. WIRE DIAMETER 40 3.30 [0.130] ~ 4.20 [0.165] 50 4.30 [0.169] ~ 5.20 [0.205] 60 5.30 [0.209] ~ 6.20 [0.244] 70 6.30 [0.248] ~ 7.20 [0.283] **VIEW FROM TERMINATION END** = KEY LOCATION 1 2 POSITION 20 AWG MAX. 15 AMP MAX. PIN = 1.30 [0.051] 0.354 9.00 0.394 10.00 0.492 12.50 COLLET SIZE 1 1 1 1 1 1 5 POSITION 22 AWG MAX. 9 AMP MAX. PIN = 0.90 [0.035] 6 POSITION 24 AWG MAX. 7 AMP MAX. PIN = 0.70 [0.028] 7 POSITION 24 AWG MAX. 7 AMP MAX. PIN = 0.70 [0.028] 8 POSITION 28 AWG MAX. 5 AMP MAX. PIN = 0.70 [0.028] 10 POSITION 28 AWG MAX. 2.5 AMP MAX. PIN = 0.50 [0.020] 14 POSITION 28 AWG MAX. 2 AMP MAX. PIN = 0.50 [0.020] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1250V WORKING VOLTAGE = 415V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 950V WORKING VOLTAGE = 315V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 950V WORKING VOLTAGE = 315V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 900V WORKING VOLTAGE = 300V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 800V WORKING VOLTAGE = 260V NorComp DRAWN: M. SIGMON DATE: 02-03-16 SCALE: N.T.S. SHEET 1 DWG NO. OF 1 821BYYY-273LYY1 REV: 8
821B004-273L501 价格&库存
很抱歉,暂时无法提供与“821B004-273L501”相匹配的价格&库存,您可以联系我们找货
821B004-273L501
  • 18+344.2912418+44.55310
